Bill97
Everything posted by Bill97
  1. Great job Marc on the coils. Always a pleasure just reading through your research and resulting build. Like yancovitch said, I am embarrassed to even post about my build. Maybe I should switch to macrame or jigsaw puzzles. 😊
  2. Same here my friend. 😀 Have a fantastic weekend. Hope your dad is doing well.
  3. Spent some time adding cleats to the shrouds. OcCre has the lines going down to the center “thing”. AOTS has some of the rigging lines going to cleats attached to shrouds.
  4. Very impressive Ab. I will definitely read through your tutorial. Glad to be on the receiving end of your advice.
  5. Did not know that Ab. That is fascinating. How are you able together the paint so nice. I thought they were wood.
  6. Ab are these photos of some of your builds? Absolutely beautiful!
  7. Thanks again Trevor. A lot of good information and advice. I know it is probably silly on my part but ever since I became a MSW member sharing my builds I try to be conscious of some accuracy. I envision posting photos of my build and a much more knowledgeable member saying t themselves “that is wrong, a ship would never be rigged like that”. Ian has been my go to for advice for several years. Appreciate all the help and advice you guys share. I know my furled sails need to have the “skin” pulled up tight over the cloth and I should adjust mine accordingly. By the way whenever I have a comment on my build from someone I had not seen before I like to check their profile to see where they live. Love your part of Canada. Been to Halifax a number of times. Especially like Peggy’s Cove.
  8. Thanks my friend. I am going with omit everything then. Just the sails I have furled to the yards. Still have to add the angled one on the back connected to the mizzen mast (forget right now what it is called).
  9. Paul have you been over to my Endeavour build to see how this turns out?
  10. Thank you Trevor. That is interesting and helpful. So are you saying I should set the stay sails and the jib to their stay and have the furled as well instead of leaving them off the ship?
  11. On my OcCre Endeavour I am going with all the sails furled on the yards with a lot of the rigging (clew, sheet, and tack) attached along with the buntlines rolled up with the sail. All the lines I am adding are tied at the appropriate belay point. My curiosity is the staysails. I see a number of photos of ships in this configuration. What comes of the rigging lines for the stay sails if the sail is not rigged to the stay? Are they just not there? I am trying to imagine the crew setting the stay sails including the rigging. How did they do it?
  12. Ian a general rigging question my friend. My plan at this point is not to add the staysails. I have seen several photos of the Endeavour replica and other square sail tall ships with out the staysail rigged. I assume this was often an option employed depending on conditions. My question is about what is done with the rigging lines that would be used on these sails? Are they somehow attached to the sail when it is set and the ropes then dropped to the belay points. Or are the ropes always there just not attached to the staysails? Similar question about the bowlines on the square sails. If I have them furled would they bowlines still be attached to the sail only extending from the end of the rolled up sail and still going to the belay points?
  13. 1 year anniversary today of the day I started my OcCre Endeavour. Will also be the day officially shown on my medical record that I lost my mind! 🤪 Rigging this beauty in accordance with the AOTS is a job not meant for the faint of heart. All those ropes will be tied down to their appropriate location. This is just the fire mast and the bowsprit.
  14. Ok gentlemen I need your help once again. I am looking at the rigging of the spritsail. In particular I am looking at line #7 in the first photo (spritsail course sheet) and trying to determine the belay points of both ends of this line. I have scoured the Endeavour AOTS and the OcCre instructions. Photo 2 from the AOTS shows one end of it tying off at point 12 on the side. I can’t find anything showing where the other end of the line ties off. In my other builds I checked both ends of the sheet are located near each other. On my Victory one end is secure and the other end passes through a hole in the bulwark where it then tied off to a cleat on the inside of the bulwark.
  15. Oh that explains it! Thanks Ian 😀
  16. Marc you have any idea why the MSW site does this. I knew you didn’t react to my post 7 times in a 5 minute period 😀. This happens from time to time.
  17. Well, as is often the case in my builds, I go two steps forward and and then one step back. I did the fore and main yard lifts following the OcCre instructions (photo 1). Then looking through the AOTS for something else I discovered I had rigged them incorrectly (Photo 2). The OcCre instructions shows the lift coming back down to the end of the yard a second time and passing through the block that will be used for the sheets. The AOTS shows what I expect is the correct way. Removing the lifts and doing them correctly.
  18. Hey Daniel hope all is well. Curious if any updates on your AV build? Enjoy so much reading through your build as I approach the start of mine.
  19. Slings, lifts, tyes, etc. installed at this point of the running rigging using a combination of OcCre instructions and the Endeavour AOTS. Thanks Ian and Allan for your advice.
  20. Allan I do enjoy a diorama. Here is my Heller Soleil Royal in a diorama. But as I look at it now, for authentic I should have had the yards turned a bit.
  21. Thanks so much again Allan. I have never displayed one of my models this way but in cases where I have the sails unfurled I should have the yards rotated forward one side or the other, not squared? As I glance around my “ship yard” I see all my ships have the yards squared, regardless of sail display and the lifts on both sides taut. This is not correct. Moving forward I should do that differently on future builds. On my current build, the Endeavour, I have all the sails furled and the yards squared. Should all the lifts be somewhat slack or taut?
  22. Thanks Alan. I am reading through your comment a couple times for clarification and understanding. As you see in my comments the lifts were pressed tight against the first shroud with the crossjack squared. I moved the anchor point on the cap forward just a bit so the lifts barely miss touching the shrouds when taut. This anchor point is nearer where the top mast passes through the cap and less wood thickness but I guess since they really did not carry weight this would be OK. Allan I am also curious while I have your attention, the Endeavour AOTS do s not show lifts for the topgallant yards. This is correct? Ian we can both pick up some tips from Allan. Thanks both of you for your help.
  23. Ok Ian this what I ended up with. What do you think? Not tied down yet
  24. Thanks Ian. My lifts do not run through the shrouds but twang (your great word) up against them. What I think I am going to do is put an eyebolt nearer the front of the top in the area where my tweezer is pointing and run the lift to it. The AOTS has the eyebolt under the top. Your opinion of this.
  25. Ian here is an additional picture of the crossjack from the Endeavour AOTS book and the number legend. It only shows a sling, lift, horses, stirrups, braces, and a truss. 🤷
