Everything posted by BANYAN
Hi Jerome, there are others also writing in this era, including: Robert Kipping (as per John above) - "Rudimentary Treatise On Masting and Mast Making" 1853/1854/1858 editions John Fincham "A Treatise on Masting Ships and Mast Making" 1854 G.S. Nares (Commander, RN) "Seamanship" - 1868 More related to USN is: SB Luce "Seamanship" - 1868, and Brady "The Kedge Anchor" - 1852 edition Most of these are available as digital copies (PDF) produced by Google. The search engines now try and point you to 'print on demand' or paid versions, but if you persevere and look further down you can still find the free pdf versions easily enough. cheers Pat
Floor and frame spacing
BANYAN replied to BANYAN's topic in Building, Framing, Planking and plating a ships hull and deck
Thanks for responding Eberhard. Yes I have consulted several contemporary authors including Fincham, Peake and Scott-Russell. All speak in general terms and there are very few diagrams/illustrations showing framing of this time. Where there is framing discussion, unfortunately it is for standard construction and not that using bent timbers in lieu of frames and no one speaks of differing frame spacing. That is 2, 3 and 4ft spacing in the same vessel - these authors tend to suggest a regular spacing, which in this time is said to be between 2'7" and 3' 6", one set of spacings throughout. My question is really in terms of general convention and probably only able to be answered in subjective terms - that is, where do people think the more dense/closer (i.e 2ft) spacing is most applicable? Thanks again Pat -
Bump! Any clues anyone? cheers Pat -
Hi all. I am in the midst of redrawing the plans for HMCSS Victoria (steam screw sloop) and wishing to add some additional details. Unfortunately, due to copyright issues, I cannot post the plan here. Please Note: These questions relate to ship building practices of the mid-19th century. The Specification for her build required floor (centres) to be spaced 2, 3 and 4 feet apart as shown on the 'section' drawing. Unfortunately this drawing/plan has been lost and they are not shown on the profile/sheer plan. Additionally, the bent timbers (in lieu of frames) were to be placed midway between the floors, and the spaces filled in solid. The floors only extended to the 'round' (or the head of the first buttock) due to the unusual way this vessel was built. The final bit of info I have found was a small tid-bit in the record of proceedings of a Court of Inquiry in which the Inspecting Officer (naval architect) in one of his responses stated the floors in the after part were about 2 feet apart. My questions: 1. What would be the likely spacing in various parts of the vessel? I have assumed that perhaps the keel between the rudder post forward to the forward bulkhead of the machinery space (combined stoke-hole & engine room) would have had 2 foot spacing, then forward of that to perhaps just forward of the pivot gun having 3 foot spacing and 4 feet ahead of that (to the start of the cant/half frames which was the most forward station shown on the existing plan)? 2. The floors were sided 12" and the bent timbers 8". The meat of the timbers would thus occupy 20" of the 24" spacing. This means the filler in these sections would be sided just 2" (x 12" moulded/deep). Is this viable/feasible do you think? Any comments or suggestions about this would be most gratefully received. cheers Pat
Keith, the gingerbread for the Victoria model was done using various sized cotton threads and yarns soaked in PVA - not my work but that of a fellow club member. The pliability of the threads allows it to easily conform to any shape, and the size of the thread/yarn allows different thickness to be built up easily. Seal it, paint it and hey presto - worked for us but we are not at your scale, so may not give the clean results you want at your bigger scale. The required shape/ske;letion lines were first drawn on the hull/fitting then the thread applied. The attached show some of this in progress A lot more clean up was done before the final coats of paint.. Simply offering another option. cheers Pat
Hi Karel and John. if you look at your earlier photo (post #59 second photo) commenting on the railing sizes etc. you can see the foot (well the flukes at least) of an anchor on deck. To me, those flukes look like those of a Trotman anchor (or possibly of a Porter anchor which was the forerunner to the Trotman). The crop of that photo (attached) certainly has the hallmarks of the early Trotman type anchor. cheers Pat
Hi Keith, I have been following along in the background and enjoying your journey with this one. Your build is coming along very nicely. If you will permit me another suggestion might be to use a section of clear plastic (shirt box or the light) for a section of the shed roof to allow visibility to your boiler? You could paint a little bit of the edges to give that ragged edge look a lot of illustrators use to imply a 'peeled away' section. cheers Pat
That's looking terrific Steven, a very nicely finished model (which has been well researched). cheers Pat
- 508 replies
Another unique and wonderfully presented SIB Glen, you've earned your tot with this one. I have enjoyed the journey. cheers Pat
- 235 replies
- Banshee II
- Bottle
That's looking great Glen, and you have created a great little stage for those pesky penguins to perform on Seriously, I very much like the combination of the Texas backdrop and the wharf, a unique and very effective concept. cheers Pat
- 235 replies
- Banshee II
- Bottle
Wow Keith, that hull looks magnificent - those photos really show off the sleek profile and beautiful flow of her lines. While the cat's away, the mice will play - my Admiral will have blown a safety valve. Great advice on the use of the round sanding sticks (pencils) to true the shape of the portholes. cheers Pat
Working with blackend brass.
BANYAN replied to SiriusVoyager's topic in Metal Work, Soldering and Metal Fittings
When I did my Endeavour I pre-blackened the deadeye straps and chain plates separately (using Birchwood Casey Gun Black). I then installed the deadeyes and used a holding jig (made from scrap wood) to hold the straps and chain plates then soldered them together. The small area around the solder point (well away from the deadeyes) could then be retreated after cleaning. As this method did not require any twisting etc of the wire I did not have to worry about that particular issue. The deadeye strips had the loop with two legs that formed a short vertical strap that was then attached to the chain plates - not sure if your deadeye strips are of a similar design? A similar approach may work for you? Unfortunately much of the related photos and discussion around this part of my build were lost in the 'Great crash of MSW 1' so unable to post photos. Also, I use resistance soldering which less aggressive than using a pencil or other flame torch. A electric soldering wand will keep the heat down especially if it is a variable power type. cheers pat -
Hi Greg, I have been following along without commenting but have to now That is a very nicely finished diorama, even if based on a small easy to assemble kit. The overall finish is superb with all detail nicely shown. cheers Pat
- 12 replies
- Kriegsfischkutter
- ICM
Bravo Glen, those front piles look so authentic and scale correct. Looking good mate. cheers Pat
- 235 replies
- Banshee II
- Bottle
Thanks Glen, a great relaxing holiday and just what I needed. I hope you don't mind but ... Snap! I think the first photo following is of the same point of land (that you show in your posted piccy) taken from a slightly different shooting point, and a sunset to boot. Nothing special, just taken from my phone camera. cheers Pat
- 235 replies
- Banshee II
- Bottle
Hi all, I found the discussion I referred to. It is in a book titled 'Ship Joinery' by S.G. Duckworth (1923) - see chapter X (page 118). PDF copies can be found online. While it is not truly describing vessels of the 19th century, I think the essentials of the joinery practices will not have changed much, if at all. In this he states: Ladders are made in various sizes, the spread being usually from 1 ft. 6 in. to 2 ft. 6 in.; the rise to be comfortable should not be greater than 9 in.; and the slope should be such that the angle between the ladder side and a plumb-line will not be less than 37°. Later, starting at page 126, he discusses stairs which is far to large a section to paraphrase here. Essentially he writes that the 'straight' stairs' typically had a rise of 7" and a going (horizontal distance between the faces of two risers) as 9". He also provides excellent drawings of the style and parts of the staircases and associated companionways. I hope this helps cheers Pat
What a collaboration of minds this project is! I am convinced you guys will arrive at the most probable hull form and equipment fit with this sort of preparation and contributions. @druxey and @@ClipperFan, I am not 100% sure of this, but I seem to recall a discussion on the subject of stairs and ladders in one of the pdf copies of wood ship construction or wood joinery (ship related) books written about this era. As soon as I have caught up on the neglected chores etc. resulting from my trip I will have a look and see if I can find it. cheers Pat
