jdbondy
Everything posted by jdbondy
  1. How are you parting the discs off of the brass rod? Is that a wire of some kind I am seeing in that image? Thanks in advance.
  2. Wow, what a beautifully executed fine detail of the rigging! Just another piece of the puzzle that is adding up to a fantastic masterpiece.
  3. It has been entirely too long since the last post. Life just seems to get in the way of progress on the model. The Mary Day’s deck is planked in teak, with fore and aft planks and one margin plank. To match the teak color, I used Swiss pear from my collection of wood obtained from Gilmer Wood in the Pacific NW. I parted off sheets from a block, then ran them through the Byrnes thickness sander to reach a consistent thickness of 3/64” (0.047”) that would determine the width of each plank. That way I wouldn’t end up with wandering plank lines (at least I am hoping). Then I used the table saw to part off individual deck planks that were initially too thick (about 0.05-0.06”), but then sanded down to the necessary thickness of 0.047”, again using the Byrnes sander. This surface would be the showing surface of the deck, which would ultimately be scraped smooth anyway. The first task was to install margin planking all the way around the inboard edges of the covering boards. It’s a very satisfying appearance seeing the Swiss pear wood adjacent to the gray covering board, and it exactly duplicates the appearance in real life. In order to simulate deck caulking, each plank edge was rubbed with a pencil, which burnished the upper corners of the plank, narrowing it very slightly at deck level. The graphite of the pencil effectively simulates the dark deck caulking. This process required some trial and error. Initially I was only rubbing one edge of a deck plank with the pencil, but I wasn’t happy with how the deck seams looked. So in this picture I am cutting out some of the planking that then got redone in the manner described above. I started the process of deck planking in the area of the aft deck. In this area, there is a king plank that is 1.5 times the width of the adjacent planks. It is 4.5” wide, while the rest of the planks are 3” in width. Determining the centerline is a bit tricky and involved running a string (fly tying line) from the center of the stem in the bow through to the area of the transom. Pin pricks were then used to mark the centerline, then subsequent prick marks to determine preset distances from the centerline. A helpful feature about planking the stern deck is that the aft ends of the planks could terminate arbitrarily, as visible above, because their ends will be covered by the lazarette. And the forward edges will be covered by the edge of the cabintop. Carrying the planking forward from the aft deck is tricky, because ideally the planking will follow a symmetric pattern as the planks articulate with the deckhouse and with the margin plank. One forgiving feature of my model is that there will be an unplanked area of deck on the port side at midships, in the same approximate area as the frame reveal in the hull. So in that area, there won’t be any issues of symmetry to worry about. Next, planking was laid out in the bow, again being careful about determining the centerline. In the bow, there is no king plank as there is on the aft deck. The planking as shown here covers openings for the foc’sle berth and the mast partners. Those areas will be cut away when the time comes. From here, I will finish planking the forward deck, then work the planking aft to gradually merge up with the planking that has already been laid in the stern. I am hoping that everything will meet up straight and true! You can see that I have planking laid out on the work surface that is of diminishing length, as the next pieces to go into the bow. Thanks to everyone I met while cruising on the Mary Day 2 weeks ago for inspiring me to get back to work and perhaps to posting a little more frequently! I hope some of you navigate your way to this build log and find it interesting.
  4. I would be interested in seeing more details on how you did the FC stanchions and rail, because that looks to me like a complicated process to get the stanchions vertical while accurately cutting the holes in the rail to accept them.
  5. Lovely appearance! I love those Veritas chisels.
  6. I had the pleasure of spending this past week on board the Mary Day with friends! There were a total of 19 passengers. I quickly became known as the guy who was measuring every single detail. Hopefully this will inspire renewed and rapid work on my model!
  7. Your polyurethane topcoat, is it oil based or water based? I just used some water based polyurethane on a non-ship model project, and the question arose in my mind.
  8. There hasn't been any time for working on the model this summer, as I have been working a lot so that others can have summer vacation time. But once summer is over, I am joining some friends in September for a week-long coastal cruise on the Mary Day! I am billing the trip as "research". Of course, I am submitting the bills to me, so not much benefit there. But the trip should result in lots of good documentation on things like the running rigging in actual use, as well as the yawl boat and its associated stern davits.
  9. This could be a game changer for me! Ordinarily I hate soldering because...well, I guess I just am not good at it. But the process has always felt so coarse. This is much finer!
  10. Just as a reminder of what we are ultimately headed for on this project, here is a photo of the Mary Day at anchor from last summer. Now working on painting the deck support structure, which will be followed by deck planking. And I need to start planning on painting the hull itself!
  11. Margin planking has been installed on the port side! This is very exciting because once I am finished with the margin planks on the starboard side, full deck planking can proceed rapidly (with a deck framing reveal on the port side). As you can see, some repainting of the deck framing that will be revealed is in order.
  12. I think I have that same small chisel you are using, from Lee Valley! What a great tool.
  13. Thanks everyone! All six covering board pieces have now been installed and now I am trimming away the excess wood from each piece in anticipation of installing the margin plank for the decking. I hope to post a brief update soon. And I hope that after having finished this task, things will accelerate appreciably.
  14. Most of us model buidlers know that the covering boards are the pieces of timber that cover the hull-deck joint structure. Chances are you know that they are very complicated things to build. This step of the build simply confirmed that. Covering boards usually are solid pieces of wood that are penetrated by holes that accommodate the stanchions that must travel through them. For me to produce them like that would have simply been impossible. These will be complicated enough to build as is. Essentially, I will fabricate the inboard side of the covering boards with “teeth” that project between the stanchions, then the outboard edge will be added in a separate step. The seam between the two pieces should be effectively hidden in the alcove formed by the stanchions and the bulwarks planking. Here I have covered the deck structure adjacent to the stanchions with tape because I was wishing to protect my paint job of the deck structure that would remain visible in an unplanked area of deck. The protection was needed because I knew I would need to fair down the ledges to the level of the sheer in order for the covering boards to fit, and I didn’t want to harm the paint job. In order to start the process, I needed to obtain the shape of the sheer from the plans. These were transferred using tracing paper to 3/64” stock. These shapes were then cut out excessively wide. This results in six overly-wide and overly-long pieces, with generous areas of overlap. Using double-sided tape, an individual piece was tacked down to the level of the deck structure. The forward and aft edges of each stanchion were marked, keeping track of station locations. Now the really slow part began. Under the microscope, I began cutting out notches to make the “teeth” that will extend between each stanchion. Again, each covering board piece was made so that its inboard edge was continuous. The outboard edge of the covering board will be added as a separate piece later on in the build. This piece shows many of the notches at full width, while others are still being widened. The width of each stanchion was relatively standard, but the gaps between the stanchions varied just enough to require extensive trial and error fittings. But wait, that’s not all. Once all of the notches are wide enough, now they each need to be made deep enough. And none were of exactly of the same depth, due to individual differences in the shapes and angles of the stanchions. This again required many trial and error fittings with the goal of leaving minimal gap between the covering board’s notch and the inboard surface of each stanchion. In the real ship, there is only about a 2 inch gap between the inboard surface of the stanchions and the margin plank of the deck. This is 1/32” in model scale. You can see the anticipated final inner edge of the covering board marked with a continuous pencil line here. Perhaps it is a little more clear in this image. At this point there is a lot of excess wood on the inboard edge of the covering board. Removal of this excess will have to wait until later, as trimming it all off at this time would leave a piece of wood that is impossibly fragile. The process of cutting the notches was accelerated when I realized I could use my table saw and miter to at least start the notches in a more efficient manner. After having cut the notches to proper spacing, width, and depth, it was time to prep and paint the stanchions. Paint would add just enough thickness to each surface of the stanchions to require further tuning of the notches. For primer, I used some old Badger Model-Flex gray, which had thickened considerably. It was diluted with water to a usable thickness, but it still maintained enough body to serve as an effective filler. Overall this achieved a pretty smooth surface, but some defects were hard to fill completely, even after using primer and model filler. I can’t remember how long it took to make all of these very bespoke pieces, but keep in mind that my last proper post was back in July… There is lots of overlap, way more than I really needed, which also slowed the process. The stanchions and the inboard surfaces of the bulwarks planking are a burgundy color. I slowly added drops of blue Tamiya paint into a small jar of Tamiya red to achieve the desired shade of burgundy. The one small jar may in the end not be enough, because I will also use it to paint the inboard surfaces of the bulwarks planking. It took 3-4 coats to get a good smooth surface. And as already mentioned, the notches had to be tuned again after painting the stanchions was finished. So despite my efforts to protect them, I had to scrape and sand away portions of the previously painted deck structure. In fact, re-shaping of the deck beams and ledges was necessary in order to get the covering boards to sit flush with the sheer. This ledge shows considerable downsloping toward the sheerline to accommodate the shape of the covering board. So there will need to be repainting of the deck structure that will remain visible, after all. The deck beams and ledges also required re-fairing of their curve once I had removed enough material to accommodate the covering board. The covering boards were painted with a medium gray. Excess paint that ended up in the notches had to be sanded away after this was done. At this point, I used the X-acto blade to begin removing some of the excess wood from the inboard edge of the covering boards. This helped make it easier to tune the pieces to sit against their underlying deck beams and ledges. It was also necessary to shape the undersurface of the covering boards to accommodate the camber of the deck structure. I carefully sanded the undersurface to change the cross section from rectangular to an angular undersurface. In addition to trimming away wood from the inboard edge, I also carved down the thickness of the remaining excess wood in a way that left an edge that corresponded to the final inboard edge of the covering board. This involved scoring the surface of the piece with the X-Acto, then coming along with a fine chisel and planing away the surface of the piece along the inboard edge. The edge is visible as the bright line in this photo. This will make it much easier to identify the final edge when the last bits of excess are trimmed away, and to create a smooth and fair surface against which the margin plank will rest. Next problem: now that I have this piece that sits fair when I press it down against the deck beams and ledges, how do I do the glue-up in a way that makes sure that I am not left with the kinds of gaps I can see in this picture? I don’t have that many fingers. I used a 1/16” thick piece of scrap wood to create a curved piece that roughly followed the curve of the rail, then glued it to the tops of the stanchions. This is a sacrificial piece that will hopefully come off easily when I am done with the next step. Some of the stanchions were a tiny bit shorter than their neighbors. These differences will be hidden by the rail and its supports that will be added later. Using scrap wood, wedges of wood thin enough to fit between the stanchions were created. In preparation for glue-up, the areas of the undersurface of the covering board that will need to be wetted with glue were marked with pencil. Then the mating surfaces of the deck structure were wetted as well. I put small amounts of glue into the notches of the covering board as well. The board was put in place, and the wedges were used to press them to the surface of the deck structure. Care was taken to make sure that the covering board was pressed in fully against the deck, as well as against the bases of the stanchions, without leaving any gaps. After suitable drying time, the wedges were removed and the sacrificial piece was easily separated from the tops of the stanchions with the X-Acto. I never would have been able to hand-paint such a clean appearance if I had simply glued up unpainted pieces of wood. Now I only have to do this five more times, with the remaining covering board pieces! The joints between the pieces in real life would have had an angled appearance resembling a scarf joint, but I won’t be able to duplicate that here. Once all the covering boards are installed, the next 2 jobs that would make sense are the beginning of the deck planking and also the bulwarks planking. I don’t know yet which I will do next, because it will probably take me awhile to get the rest of the covering boards in place.
  15. Great, thanks. I have also found that at these small scales you have to manufacture your own carving tools.
  16. Nice miniature carving work! What kind of tools do you use? Do you use a microscope or visors for magnification?
  17. Oh no, Mark! I am sorry to hear of the medical setback, after having met you this past October! But I went through the same thing myself in 2019 involving my left S1 nerve root so I feel your pain. If you have access to a work surface that is height adjustable, it may make a big difference.
  18. Thanks for the likes, everyone. Jerome, yes Barry and Jen still own and run the Mary Day. I am in regular contact with them and I hope to see them next month.
  19. Back in July I lost momentum on working on the hull of the model. Happily, one of the distracting projects was deciding to work on a carved version of the transom carving, shown above. This decoration was added to the schooner after its refit in the year 2000 time frame. I don’t know who created the carving for them. In the off season, the carving hangs on the wall at the skipper’s house. I took a picture of the carving hanging on the wall in the winter of 2022. Its actual dimensions are 5 ft 9 inches across and about 2 feet in height. Its approximate thickness is 3 inches total. At 3/16” scale, this will translate to a total width of just over 1 inch. I was able to take an image and reduce it to the appropriate scale, then I used tracing paper to copy the outline of the shield, pennant, and eagle. This was then transferred to a piece of boxwood about 1/8” thick. To be safe, I transferred the pattern to two pieces of wood in case I screwed something up along the way. So far, though, the backup piece has not been necessary. This and other pics that look like it were taken through the viewpiece of my microscope. The traced pattern is evident, and I have already started working out the right side of the eagle, shield, and pennant. Now both sides are getting worked out. This photo shows some relief involving the body and legs of the eagle. Now jump forward substantially, and lots of details have been worked in. Dots on the pennant indicate where the stars will be. The talons haven’t been worked out yet. As predicted, the carving has a maximal dimension of just over 1 inch. This is my microscope setup. Thanks to Margie Buckingham, widow of Doug Tolbert, who offered for sale this articulating microscope! A jeweler’s ball vise is essential for this kind of work. And now I am carving out the stars from the surface of the blue area of the pennant. The talons have also been defined. Painting is now under way. The blue is much too electric, so I added a small amount of black paint to it. White paint has been dropped into the recessed stars. I was warned that the paint may obscure the surface details of the eagle, but I was pleased with how it turned out. I have darkened the blue paint. Much better. And now I have carved away some of the splotches of paint that were on the backing wood. So after about 45 hours of work, it is pretty much finished! When the time comes to mount it, I plan to very carefully carve off the wood from the backside of the piece. The piece and its backing is glued to a separate piece of wood that is clamped in the vise. Rather than soaking the piece to free it from the other piece of wood, I plan to gradually carve it free. I will wait to do this step until it’s time to mount it because the freed piece will be exceedingly fragile on its own and I don’t want to risk damaging it. The workpiece started out as a 1/8” thickness piece of wood, and when I am done carving off the backside it will be around 1/16” in thickness. Wow. I am happy to report that I have regained momentum on the rest of the model project, so I should soon have a new post that is about the covering boards.
