Everything posted by Jack H
Desktop CNC Router, Engraver, Mill
Jack H replied to pompey2's topic in Modeling tools and Workshop Equipment
I want to add that, when you have mastered the 3 axis NC machining, you will look forward to 4 axis engraving machine, but once you have 4 axis engraving machine, it is eager to 5 axis engraving machine (like me), but the mother-board of 3 axis and 4 axis /5 axis is not the same and as far as I know, there is no way to upgrade-You have to replace a lot of parts, and it will cost you a lot of money(to upgrade 3 axis to 4 axis ) , but the 5 axis engraving machine is very expensive, and the CNC program of 5 axis is very difficult, so, I suggest you buy 4 axis engraving machine, because the 4 axis engraving machine basically can make all KITs of the ship model. -
Hi pompey2 I saw your picture of engraving machine. The drawback of this engraving machine is that the less rigidity. When the carving is deep relief or cutting, the vibration of the machine will affect the accuracy. I suggest that you choose the carving machine made by steel casting, the machining precision will be higher and more durable. It's just a little more expensive (if in China). But if you use a laser as Z axis, it would be better to use an aluminum alloy machine. If you need to make 2D or 3D sculpture, I suggest you choose a 4 - axis engraving machine. The 4 - axis engraving machine can make a perfect relief (sculpture) and figurehead. If there is a chance, I will do a demonstration for you(There are great differences between the 3 and the 4 axes engraving machine in making relief-excluding the figurehead).The sculpture made by 3 - axis engraving machine, the side will be stretched. If you are very interested in that machine, ask them to carve a sample for you. -
Great work! beautiful sculptures and ship model, and good reference drawings. thanks
- 27 replies
- carrvring
- micro wood carvring
(and 3 more)
HMS Naiad 1797 by albert - FINISHED - 1/48
Jack H replied to albert's topic in - Build logs for subjects built 1751 - 1800
Excellent! And happy new year to you! HJX -
Thanks Erebus and Terror Nils Mark Gaetan Bordeleau and Hubac'sHistorian! I finished second steps, because my machine is 4 axis, so many parts need to be engraved again. In general, Maybe i can get better sculpture by using new model new processing program and the V type milling cutter. If the eyeball is to be engraved, 0.1mm V type milling cutter is needed, but I use 0.3mm milling cut now. The rssult of the left arm after additional carving.
Hi Mike You can always bring us an amazing ship model (maybe that's ship or ship model ? in 1:1 scale last time?)
- 969 replies
- hahn
- oliver cromwell
Thanks shipyard Gary! I have two of them,The construction and fitting of the English man of war, 1650-1850 and The 74 gun ship bellona,The previous one is very professional, However, it is a little regrettable that there are few descriptions on keel splicing. I checked out the introduction of these books, ordered 3 of them. And buy another one. I have some questions about 74gun/64gun/90gun,I'll consult you after reading these books. thanks!
Hello shipyard Gary Great work! I am looking for some books or plans about British 1 -3 rate ship in 18th century,can you tell me the 3 books that are marked in red in the picture? thanks!
SOLEIL ROYAL 1669 by michel saunier
Jack H replied to michel saunier's topic in - Build logs for subjects built 1501 - 1750
Hi I don't know what software you used, as far as I know, if you want to make 3D models and mill it by NC machining, you also need 3D modeling software.I recommend X+zbrush,the X is cad software such as autocad/rhino/solidworks/UG/...,ZBrush is used to make sculptures,it works very well and is much cheaper than 3DMAX /maya... and other software. These software are generally expensive, if you don't work in some companies that use CNC (they can buy these machines and software), maybe you don't have the chance to learn these professional software. I benefited from my friend who have a furniture factory, he had a lot of CNC machines and software that made me learn how to use these software. -
The 4 axis engraving machine can make almost all the parts of a ship model-- except sail, the 3 axis engraving machine can produce most of the parts of the ship model. Some parts which are difficult to be produced by traditional manual methods, but they are machined quickly and accurately with the engraving machine. For example, some special shaped parts of the bow and stern. -
Hi pompey2 I've used a desktop engraving machine, -4 axis.The machine is all made of cast steel. The price is about $1200, excluding pc and software.The Mach3 license will cost about $175.You also need a computer, but you can use the old one, Mach3 does not require high performance for PC. You also need programming software and design software,it's the costs that need to be considered.Most importantly, you must design and learn to program.In China, tuition for embossed programming is more than $1000. Only for the engraving machine itself,If you are only occasionally used to process some wood parts, such as cutting frames, and making some relief, the Aluminum Alloy Structure Carving machine is more cheaper. but as far as I know,the engraving machine, the price under 500 dollars, is called a "toy machine". The benefits of engraving machines are unquestionable, accurate, labor-saving and high efficiency. Able to process relief and make complex parts. -
Hi ALBERT It‘s really wonderful,very exquisite and beautiful! -
ancre Chebece 1750 by Jeronimo - FINISHED
Jack H replied to Jeronimo's topic in - Build logs for subjects built 1501 - 1750
Great. Are you going to make the two parts separately and then merge it into one shipmodel? -
hello AnobiumPunctatum,the scene was made in Unreal Engine 4-an excellent 3D game or virtual display development software, and it is free to everyone, but if you sell anything developed by UE4, you must pay 5% of the proceeds to epic. The UE4 development scene can achieve amazing results, but I'm simply making it without grainy map for the model.Most importantly, the scene created by UE4 simulates the actual ship model - just like in a museum, and all you see is dynamic and live.If you add more programs, it will become an " intelligent" scene, such as using animation to demonstrate the structure of components, to retrieve drawings or presentations, and to match music or sound...Non-professional-people like me can make this kind of scene.
Hi Gaetan! First of all, I'd like to point out my own point of view. I think it is most important for everyone to enjoy in the process of making ship model- according to their own preferences or wishes.So, whether it's manual or with some power tools, it's great to complete making a ship model.And I never think learning software is an end, because the ultimate goal of using 2d/3d is to make an actual models-In a sense, 3D software is another "electric tool". Making that demo is one of my experiments.I have decided to develop HMS XXX 1765 with a respected member, and it is very helpful for my partner to check out the components of my development in real-time, as he wishes-- because I can't express what i want to say clearly in English. As you say,it takes years to develop a good 3D drawing or 3D modeli,maybe 3-5 years.So now I'm not doing a complete project, just using 3D software to calculate the keel, frames drawings. And you ask "how long it could be for an experienced man like you to draw a complete set of a 3D ship plan?",that is a tough question.If there are authoritative detailed 2D drawings, maybe I can finish it in 1-2 months if I don't have to do other work every day. If it just make 2D parts into 3D, maybe a few days. But that is not the case, in fact a lot of 2D drawings I didn't really understand-even the anchor drawings such as 74 gun. some ship model drawings were simplified, such as stitching method of frame, France and Britain are not the same, the British in each period is not the same, and the arrangement method is not the same, encounter this kind of problem, the project will be suspended. So many ship model books are not written by one person ,the drawing and modeling may be done by someone else-because there is no such a comprehensive person. As far as I'm concerned, my modeling should be ok, I can make a model by 3D (including sculpture), and I am confident that I can make any parts with NC, but my lack of knowledge of the ship model, because in China, buy ship model books is very difficult, I bought the book at Amazon, orders will be cancelled after 3-6 months...So I can't say I can make a good set of drawings. Actually, your schedule of 74 gun is very fast. My 64 gun has stopped for nearly 3 months.Because I have to work every day, and my wife has ordered that if I make the ship model in the office again, she will...I mainly focus on the development drawings, and if i have a workshop and more spare time, I think I will continue to make the ship model. With regard to the future and application of 3D technology, you can decide by yourself use it or not according to your actual situation. HJX
Hi Gaetan You've mentioned the concept of 3D drawings before,I made a attempt to make a simple experiment based on my understanding of the 3D drawings-A simple UE4 scene.Of course, the demo now is not the full functionality I imagined,this is just a simple demonstrationt. This demo allows you to use your mouse and keyboard to override controls, look at components from different angles, and improve spatial understanding of the structure.I made an operation video, but I couldn't upload it to Youtube-If necessary, I can send it to you via the Forum,Here are some video screenshots.
