Stevinne
Posts posted by Stevinne
  1. With the value of the British Pound falling in relation to the dollar, it might be a good time for U.S. modelers to look at Cornwall Model Boats. I've purchased a few things from them and always found their selection to be good, their everyday prices to be among the best around, the shipping costs across the Atlantic reasonable and the service great. I saw the Pound was trading at all-time lows today, so this might be a way to capitalize on economic turmoil, support a good vendor and get a bargain.
  2. A little more work. Trying to get the run of bulwarks right. Stained the deck with "Bright Pecan." I thought it would be lighter, but I'm sort of happy with it. Also ordered a reference book and also "Sovereigns of the Sea," just because it sounded interesting. The "Sovereigns" book was used and came with an interesting book mark tucked inside.
  3. 4 hours ago, Cbrand02 said:
    I've noted a few things as I've worked..
    1. The shape of the keel is pretty far off. It is tempting to sand it into shape, but I am afraid of destroying it somehow. I will probably just go at it with the sandpaper and hope for the best.
    2. I am somewhat satisfied with the finish, but it could be better. For example, even after tons of sanding and filling the transition from the bulwarks is still not perfectly smooth. There are tiny lines where things meet that are very difficult to see through the paint, but still there. Is there a solution for this? A layer of planking? A layer of some type of putty?
    3. Is it advised to prime the metal pieces? I find the acrylic paint removes easily.
    I don't know if you'll ever be able to get the bulwark lines to disappear. That sort of stuff never bothered me, because I've always approached a wooden ship - where I guess the lines to me show that it's handcrafted - differently than say a plastic model, where I do find seam lines bother me.
  4. She's looking great. For the gunwales, I'd recommend the soak/heat method. For the hole in the stern, I'd find a piece of wood of a similar size to the existing bulwark, cut it to fill the gap and once glued into place, dab either end of the break with diluted wood glue and lightly sand the area. If all works out well, it should help blend the patch into place and be virtually unnoticeable once you add paint.
  5. 8 hours ago, Cbrand02 said:
    That looks awesome! You've inspired me a bit, I pulled off all the deck fittings and bowsprit and airbrushed a base white, going to try and achieve the paintjob of the photo on the box. I can't really fix the uneven planking, but I can stain the little "buildings" and paint the capstan and anchor winch. What kind of materials did you consult to know how to rig/build it? It seems like there are tons of different versions of this ship; the box art has a version, the line drawings have a version, there are different photos online that seem to depict different variations of the ship, etc.. I guess I just choose one and go with it? Or flex my creative muscles?
    I've built other models, so for the rigging I pretty much used the schemes I'd learned doing similar rigs. Since America was basically a souped-up version of a New York pilot boat, I'd suggest looking up photos of Model Shipways "Phantom" New York Pilot boat model. She's good looking and a close approximation to this model. Yours looks good and you are well on your way to something that will look really nice on a bookshelf or mantle. If you plan on building other ship models, I'd recommend getting a copy of Frank Mastini's "Ship Modeling Simplified." It is a really great book and provides some real guidance for the various steps involved in tackling more-complicated ship models. When I give ship models as gifts I also always include a copy of that book.
  6. Started the deck planking. First step was running to the store for a permanent marker to add "tar" to the plank edges. There were no black Sharpies available, so I had to settle for some brand named "Jot." They smell pretty strong, so there's no chance I'm going to forget to cap the pen.
    I'm already concerned the kit hasn't come with enough deck planking, so I'm trying my best to stretch it. That's why the planking ends at the focsle door, since the closed door will hide what is inside. I do have to plank some of the deck under the sterncastle, since that entrance is open. But I'm saving that to see if my odd-sized left-over pieces can be used.
  7. Getting ready to plank the deck. The first step is removing the supports from the frames and then making sure the stubs are flush with the false deck. I found my sprue cutter did a good job clipping the wood nearly flush and then I used some chisels of various head shapes to remove whatever wood was left. I was happy that I took extra pains when installing the hull planking to ensure no glue was anywhere near the supports, since when snipping them they easily came away from the planks.
  8. Starboard side work mostly completed. Going to move on to planking the deck as this kit is proving to be pretty stingy with materials. While other kits I've worked on have always provided plenty of spare wood, I finished planking the lower hull with literally the last piece of wood provided.
    My preference is to continue planking the upper hull with mahogany, which will then be covered by printed decorations provided in the kit, but I'm not sure if I will have enough wood.
    If anyone has ever worked with pre-printed decorations on card paper, any advice on working with such material will be appreciated. So far, the only thing that I am sure of is that I will complete the hull sanding before installing the decorative card.
    I think it also important to note that I purchased this kit several years ago. I believe Mamoli is under new management, so I'm not sure if the wood supply situation has improved. I'm just surprised that materials are so tight, since even cheap kits I've purchased in the past always provided an excess of wood.
  9. More work on the starboard side. For some reason, I've found planking this ship to be a real chore. Happy that most of it seems done. I've also noticed that most of the photos I shoot for this log seem to come in upside down. I eventually figured out that's because I'm left-handed, so I use the shutter button on the left side. When I flip the phone and take pictures with the shutter button on the right side, the photos come in right-side up.
  10. Moving on to the starboard side. On the port side, I did the second layer of planking by running alternating touches of CA and wood glue on the plank and then applying it to the hull. I found that to be very messy, since anytime the plank touched some already applied wood, the glue would leave a mark. On this side, I'm tacking the plank to the bow with some CA, and then applying the glue to the hull and then pushing the planks into place and then running the plank-bending tool over them to make the glue set quickly. It seems to give me better control so far.
  11. I was looking over photos of the replica ship Batavia that Baker thoughtfully provided. My one takeaway was that I might need to rethink my plan to paint the gilded pieces provided with the kit. I thought ships of the era probably didn't have as much glitter as my kit implied, but the Batavia does seem to have more than I would have thought. Also, looking at the photos, I was wondering what is the point of this planking at the bow. It looks almost like a second layer of planking, maybe to provide extra protection when muscling through the waves? These photos were a big help, so I really appreciate being directed to them.
  12. Had a health scare recently, so while I was on Amazon ordering up some CA remover, I also ordered an electric shut-off timer that I can plug my planking heating tool into and not worry about inadvertently burning down the house around my family's ears if things go south for me again while I'm working on the model. When I was a kid, my great-grandmother's summer house had a similar analog egg-timer/electric outlet set up as part of a drop-down ironing board built into the kitchen wall. It struck me, even as someone very young, to be an eminently practical and elegant set up.
  13. Have a little time on my hands, so did some more work on the second layer of planking. Not as tight as I would have liked, but this is my first time working on this type of hull shape and it gave me trouble. I also need to clean up some stray wood glue (those white patches about 3/4s of the way down the bow). My next ship is going to require me to really school myself on planking technique. You also can't see it in this photo, but the second layer of planking has also shown me the necessity of really making sure I do a good job of fairing the bulkheads. This ship has more lumps and bumps than my 62-year-old frame, which is depressing. I had a question about the beakhead. I always imagined that on real ships, this was compass wood pretty much made of a single piece, but the photo on the kit box appears to show the beakhead either planked or with faux plank lines drawn. Not sure how to approach it.
  14. On 7/6/2022 at 7:54 AM, DennisL said:
    Hi Stevinne,
    Hasegawa definitely makes great kits.  I am currently building the IJN Akagi in 1/350 scale and have purchased all of the PE add on kits that go along with the kit.  It is somewhat of a PE hell once you get into it but the final results are quite stunning.  Hasegawa supplies 6 Kates in the original kit along with 3 type 99 dive bombers and 3 Zeros.  I added 2 extra plane kits a while back bringing my total of Kates to 18 and 9 zeros for the first strike at Pearl.
    Incidentally, if you want an excellent read on the Battle of Midway and the story of Lt. Tomonaga I highly recommend the book "Shattered Sword" by Tully & Parshall.  It is written from the Japanese perspective and really gets into the difference in philosophies of the Japanese with respect to both carrier design and plane design and the factors which led to the Japanese defeat at Midway.
    Dennis
    I've got Hasegawa's full-hull 1/700 Akagi waiting in the wings with the basic IJN photoetch to add to her. I've seen some amazing builds of the 1/350 kit. The PE really does help make it a beauty, though I imagine the build time for such a kit is probably at least equal to a wooden ship. I've been meaning to try "Shattered Sword" since I've been fascinated with Midway since reading "Incredible Victory" by Walter Lord as a kid. I recently picked up this memoir of a Kate pilot for my Kindle. My biggest problem is that books I'm interested in, like models I want to build, pile up faster than my free time expands. https://www.amazon.com/gp/product/B00THSCSS8/ref=kinw_myk_ro_title
  15. I'm currently building Hasegawa's 1:48 B5N2 "Kate" torpedo bomber. The plane has the markings of that flown by Lt. Jouichi Tomonaga, strike leader from the Hiryu at the battle of Midway. Her tail number is BI-310 in standard western letters and numbers. I'd say you can't go wrong trusting Hasegawa on a detail like that. Tomonaga was the guy whose plane had its fuel tanks damaged on the initial morning strike on Midway. He was able to return and land on Hiryu. When the Americans put the Akagi, Soryu and Kaga out of action and took out a large part of the Japanese strike aircraft, Tomonaga led the Hiryu's strike against the Yorktown, though the damage to the plane meant he didn't have enough fuel for the round trip flight. He managed to launch a topedo at Yorktown, though it missed, and was shot down by Jimmy Thach.  I've always thought the B5N2 was one the best-looking WWII planes, and the Hasegawa kit has been a great build.
