Paul Le Wol
NRG Member-
Everything posted by Paul Le Wol
Looking for a USCG 47’ motor lifeboat kit
Paul Le Wol replied to DanS's topic in Wood ship model kits
Hi Dan, welcome to MSW. Dumas makes a 36’ ( kit #1258 ) and a 44’ (kit # 1203). I have never built a Dumas kit so I can’t give an opinion on them. Good luck with your search. -
The only thing I would add is that your Half Hull project turned out great using single 1/32” planking. Unless you can source 3/64” wood I think you would have to go with 1/32” as 1/16” may be a bit difficult to shape to your bulkheads. Nice companion shot with the Rancho!
- 312 replies
- Chile
- Latin America
(and 6 more)
Jacques, congratulations on finishing the Peapod. The lobster trap is amazing!
- 65 replies
- Maine Peapod
- Midwest Products
Jacques, I am very happy to see that you are continuing to scratch build these very interesting working boats. Great introduction. Good luck with this project!
- 312 replies
- Chile
- Latin America
(and 6 more)
Hi knipster, welcome to MSW. This is a beautiful project you are about to start. The only thing I can think of regarding the planking showing would be that it may be difficult for it to remain consistent depending on the amount of sanding that is needed. If you head over to the new members section and introduce yourself you may get more responses to your questions. Good Luck!
Thank you John. This was an enjoyable little project.
- 201 replies
- Oyster Sharpie
- first scratch build
Thank you Keith and Gary. Always great to hear from you guys
- 201 replies
- Oyster Sharpie
Jim, congratulations on completing your Grand Banks Dory. A superb job!
- 56 replies
- grand banks dory
- Midwest Products
Doug, congratulations on finishing your Gretel. She is beautiful. Good luck with your next project!
Hi Everyone, just a small update. Thanks to all of you for the Comments and Likes. The water barrel was started a while ago and now is the time to mount it as it will be easier to lash it down before the foremast is stepped. The innards of the barrel where made from leftover parts from a previous build. They are mast hoops and their carrier sheets from Glad Tidings. The heads were made from 1/8” x 1/32” strips of wood glued together and then glued to the ends of the former. The staves were shaped, soaked , clamped in place and glued after drying. So it took a day to finish one strake. The stand for the barrel was also made from the carrier sheet for the mast hoops. Holes were drilled in the bottom back corner and a loop of rope was secured to the stands by a knot tied in each end after being pushed through the hole. The rope coming out from under the front of the barrel had an eye made in one end that was slipped over a pin that secures the barrel to the deck. The barrel hoops were made from 1/8” chart tape cut down to just under 1/16”. The ends of the tape were were glued with CA where they overlapped under the barrel. The barrel was then lashed down. Now that I think about it, the rest of the updates will be smaller. Lots of little things to do now. My thoughts and prayers are with everyone that was and is in harm’s way. Hope to see you soon.
- 201 replies
- Oyster Sharpie
Jacques,congratulations on finishing the half hull project. This is an exceptional result. Very impressive.
- 82 replies
- half hull planking project
- half hull
Hi Ian, thank you for your generous comment. I appreciate very much!
- 201 replies
- Oyster Sharpie
Glen, l see you’re on track for another great build!
- 185 replies
- Flying Dutchman
- Black pearl
Looking great Jacques. I keep thinking how good she looks sitting on that rough-sawn wood
- 286 replies
Hi Rik, thank you for posting this picture. It is a very beautiful and inspiring model. I hope that the rest of your visit was just as rewarding.
- 201 replies
- Oyster Sharpie
Hi Keith, thank you very much. In previous builds I felt like I was fighting the metal. Now I feel like I’m kind of getting along with it 😀
- 201 replies
- Oyster Sharpie
Hi Everyone, I hope everyone is safe and sound. Thanks to all for your Comments. Likes and visits. The last couple of weeks were spent making metal parts and attaching them. The king planks were also finished and the holes for the masts were trued up. The chainplates were attached so that they butt up against the bottom of the rail. A hook will be mounted in the top of the rail to accept the deadeyes. The bobstay stem plates were made and then mounted to the stem. Somewhere in there the bowsprit shroud plates were made and attached. The gammon iron was bent and mounted on the bowsprit and painted. Then the bowsprit was mounted and the gammon iron was finished. After all of that a coat of paint was applied to the hull on both sides. And lastly a roller fairlead was made for the center board rigging and attached to the cabin roof. I bought these 3mm sheaves from The Crafty Sailor a few years ago. He used to have some neat stuff there. Too bad that he’s gone. Next I’m going to have to think about mounting her on a stand and start on the masting. See you soon!
- 201 replies
- Oyster Sharpie
