Paul Le Wol
NRG Member-
Everything posted by Paul Le Wol
Hi Phil, thank you for the advice. I’ve been using the Elmer’s rubber cement for temporarily sticking the paper to the wood. I’ve only been removing the paper and rubber cement where there wood needs to be glued. As you say it is easy to remove. Been using yellow PVA for gluing the wood. Once the hidden work is finished I’m going to switch to white PVA and/or CA. One drawback to the Elmer’s rubber cement is its odor although that goes away fairly quickly.
Hi Everyone, I hope you are all well. Thank you for all of your Comments, Likes, and support. I have been reading this report that @bruce d posted a link to in his topic “ 1915 steam schooner Wapama - detailed tech book and plans “. Thank you Bruce. Tons of details! In my opening post it should have been mentioned that the hull of Wapama was built by St Helens Shipbuilding Company in St Helens Oregon and towed by Steam Schooner Multnomah to San Francisco for completion. Work on the bulkheads has begun. They are made from the 1/8” plywood. They will be beefed up with 1/8” basswood later on to give the hull planking more gluing area. I started at the stern because it is the most complex part of the hull and didn’t want to get too far in case it needed some revisions. Left over 1/8” carrier sheets from Model Shipways are being used wherever possible. It is of nice quality. The area aft of the last bulkhead was “caged” with 1/8” x 1/8” basswood strips. The bulkheads that extend up to the cabin deck are all glued in place. The next bulkheads will just go up to the main deck. Thanks for dropping by. Hope to see you soon.
Hi Jacques, your Lancha Chilota looks great. Since the beginning of your build log you have posted photos of these boats resting on their sides at low tide. Have you ever considered displaying your model in this manner? Just thinking out loud 😀
- 312 replies
- Chile
- Latin America
(and 6 more)
Bob, congratulations on finishing your Duchess of Kingston. Beautifully done!
- 207 replies
- vanguard models
- Duchess of Kingston
She looks great when resting on the guards playa
- 312 replies
- Chile
- Latin America
(and 6 more)
Dream of building full size to reality of building models
Paul Le Wol replied to J Snyder's topic in New member Introductions
That would be a great project. I hope that you are able to start on it one day. -
J. Snyder, welcome to MSW! Whenever I hear Wapama I’m all ears. Good luck with whatever you decide to build. -
Hi Jacques, perhaps the owner of Quenita had the open stern to make deck cleaning easier?
- 312 replies
- Chile
- Latin America
(and 6 more)
This will be a waterline model of SS Wapama, built by Kaiser Shipyard #3 in Richmond California and launched in 1915. She plied the waters of America’s Pacific Northwest bringing lumber from the mills to markets in California. Passengers and general goods were also transported. I am using the Historic American Engineering Record drawings from the Library of Congress website. These drawings are scans of drawings produced by Don Birkholtz Sr. of Tri-Coastal Marine for the National Park Service. The TIF files were downloaded and opened in an old version of Adobe Elements. They were then cropped and converted to high quality PDFs. The PDFs were opened in a free version of Foxit reader and printed using the tile function. Lots of cutting and taping together. I wanted to use my 36” build board so the drawings ended up being 1/71 scale which results in a model approximately 36.5” LOA and because it is waterline, it will be about 17’ high. I had a very difficult time trying to source basswood plywood locally so I ordered 1/16” and 1/8” basswood plywood from Amazon that come in 12’ x 12” sheets. The 1/8” sheets were 7/64” x 11.75” x 11.75”. Overall it is of good quality. The bulkhead former is made from two layers of plywood and one layer of 1/32” basswood sheet which results in a thickness of 1/4”. The non-destructive tracing method was used to trace the plans onto the plywood. An awl was poked through the drawing and the resulting holes were joined together with a ruler and pencil. I’m using a retractable knife with the 1” black blades to cut the plywood so eight pieces of plywood were cut and then glued together. Notches for the masts and Samson post were cut into the former and then 1/16’ plywood spacers were glued on each side to register where the bulkhead sit . They also box in the slots for the masts and post. After cutting the plywood with the knife I used the Ultimation sander to square up the sides. Here is the former ready for the bulkheads to be attached. Next will be prepping the board for mounting the former. Hope to see you then.
A celebration is well deserved Jacques. Your planking is outstanding!
- 312 replies
- Chile
- Latin America
(and 6 more)
Looking good Andrew. There are builds of Miss Adventure at “rcuniverse.com” and “ rcgroups .com” . Not sure if they are finished but they were well on the way when I looked.
- 72 replies
- Miss Adventure
- Model Shipways
Hi Keith, welcome to MSW. When you start a new topic, I think you have to click on the drop down arrow to the left . Only it is selectable on my iPad
