Lucius Molchany
Everything posted by Lucius Molchany
  1. Designed and routed the side plate.I have to stain and install it.
  2. Can you post a pic of the area in question?pre painting some of the planks is a wise move.
  3. Cool!Looking forward to seehow the mask job turned out!
  4. Yeah frisket may be tough to use on wood.. I use the blue 3M masking tape and it really leaves a clean line.
  5. Just be surevto test the technique before painting the model.
  6. Yes and cleaningvthe airbrush afterwards.
  7. One way to paint the bulwarks is to make apaper mask that follows the contours of the deck.I used this method on my Scientitic Sark and Model Shipways phantom and no paint or overspray was on the deck when the paper mask was removed.Just make it as a precise as you can to ensure a tight fit and do not lay down a wet coat near the deck mask.
  8. I decided to go with an asymmetrical look to my display base that I screwed to the keel.I am telling you what,I should have worked it out beforehand.It is a wonder that I did not damage the masts when I laid it on its side to drill the pilot holes and screw them into the keel!
  9. Very cool!I recently built one and it is a great kit!
  10. I guess!I have never encountered doublings on a flag pole but I guess the naval architech must have deemed it necessary
  11. Put on the spanker and the rear flag ploe.Wow it sure is heavy for a flag pole but that is what the plans show.
  12. Finishing up putting the spars and sails on the main mast Looking good
  13. Progress continues on putting on the ysrds and sails.I drill a tiny hole in thej mast abnd yard or spar to accept a tiny brad.the blocks and lines balance and hold it in the proper position.
  14. Put on the lower ywrd on the foremast.The blocks and lines support the yard structurally.
  15. Yes wooden ship mpdeling can be addictive and is so much more rewarding than a plastic model because of what the ship demands of you.
  16. I have never put cloth sails on a ship before so I decided to use the sails from AL Hermione.None of the sails would fit the lower boom so I took one of the jibs and furled it on the boom.Seemed to have worked fairly well.
  17. Well if they can build one for Johnny Depp they can build one for Russell Crowe.
  18. Man I sure wish that they would make sequel to Master and Commander.Russell said he would do it but the first film was not sucessful enough.
