Posts posted by cristikc
I made some models of sanding tools from HDD parts.
I will try to explain with picture how i made.
Also i made my "new" power supply from computer power supply.
take the cover off
remove heads
take out magnets and other parts
glue paper sand on one of the platans.
Al so for the vertical sanding, use a "medical tube"
the parts are ready
install the disk withe the sanding paper, glued.
Make one small cover, if you like
install also the vertical sanding tube
put the helping and protect cover, in position
Having two days free, i finally (after many years) made my power source for the hobby (from an pc power supply). It was not hard, but had no time (every time when i wanted to build - make the conections and the plugs and connectors, and the arrangment - it was something more important)
This is how it looks (and how everyone can do)
All the best for the end of the year
testing with all the HDD used for sanding
in final position
A HAPPY NEW YEAR to everyone.
Cristi
- DenPink, igorsr, marktiedens and 1 other
- 4
- maggsl_01, UpstateNY, marktiedens and 2 others
- 5
Hi Mike, as i said, it works very well, but just the PATA ones. The advantage is that you can make as many as you can, an you can change when the sand paper is not good. For the moment i have just two, because i mede also one for my son, and one for my son in law, but i want to make 4 or 5, and also to make some combinations
Cristi
I made the photos for hdd sander
two sanders from pata hdd,and one sata that is not ok.
also the computer power source, also 1 spare (new format sander disk) and some spares not "formated"
two pata hdd, from the connector side
left the sata connector (not ok) and right the pata connector ready formated
hope this will help everyone
Cristi
Hi Richard, i use the sander from some years, and it is ok. The only problem, if you want to buid one, is to use JUST the PATA (paralel ata - old type of hdd) and not SATA (the sata hdd start to spin and after 5-10 sec stops - this is the logic it works in computer) while the pata work ok. You can find what type you have, just looking to the connector. Also, you have to take out, the hdd head and magnet. If you need any more info, just write, here or in a pm
All the best Cristi. And Marry Christmas to all
ps. Ulises, from time to time you have to "reformat" the disk (change the sandpaper with new). But i also have different disks prepared with sanding paper of sand granulation (100, 120, 150, 180, 220) I have already prepared two more, with this sandpaper, and i have some ideas but for the end of the year i heve no time. Next year i will put some more pictures with the new ideas
Hi Garym, i like that you think as i think. Family and real life are more important, hobby is excelent, is something that recharge our battery, but has to be at the end, when all are ok. I look to your log, to learn more about Sovereign.
All the best from me and Marry Christmas
Cristi
- mtdoramike and DenPink
- 2
Mike, i have still to go to my job, stay with my granddaughter and her brother, do things for home, and
at the end is the pleasure (my hobby). I'd like to work a lot to finish Sovereign and start a new ship, but... that is life.
I love my family very much,and, as you know, we are the last with pleasures in family.
All the best Cristi
- mtdoramike, DenPink and garym
- 3
- marktiedens, Seventynet and UpstateNY
- 3
Hi Garym, exactly this are the problems, and i was wandering if you have the same problems. I have to make a lot of movements, and i still don't like, but that is. I have to finish somehow. I also have a lot of flashes, that i have to sand.
Thank's for the answer.
Cristi
- Kenneth Powell, Seventynet, garym and 3 others
- 6
Had just a little time to work
I had a big "help" from my granddaughter (i was trying to teach her small thinks, so this was very important to me)
also i was helped by her, to transform the Unimat in fret saw (and i build a table for it)
After this i warked a little
I am a little disapointed for the bras parts (there are not so accurated as i expected, and for the price of the kut)
Hope that Denis, Andy, Vince, Garym and other that have build this kit, can tell me how they found the bras decoration
Cristi
- marktiedens, edmay, igorsr and 1 other
- 4
Hi Ulises, excellent job.
Did you think for a display case?
Wait for your next project.
Cristi
- Seventynet, garym, edmay and 6 others
- 9
Hi Denis, wait your email.
I like help peo[ple, but for tehe moment i have to work a lot to my job
Stay with my granddaughter, and at the end "play" with tools to my hobby.
I hope i will try a small build, helped by my granddaughter , a scratch for "mantua combat post", from the
schematics sent by one kund "colleague" from here, Keven.
All the best,Cristi
Hi Denis, the kit look nice
I understand that you have to start a second "job", i also make the same.
There are parts in the build when i make the same think (repeat for days) and i need a change for some days.
Vince P is very good, as i saw, and maybe he did not think to change between two works.
Both you and Vince are very good, i look with interest to your logs.
All the best Cristi
I use a steamer and you can look here
http://modelshipworld.com/index.php/topic/494-steem-bending-tool-cristikc/?hl=cristikc
how it works. Cristi
- marktiedens, UpstateNY, md1400cs and 1 other
- 4
Sanding tools and power supply from computer parts - Cristikc
in Modeling tools and Workshop Equipment
take the cover off
remove heads
the parts are ready
