Everything posted by Rustyj
Echo by Rustyj - 1:48 - cross-section
Rustyj replied to Rustyj's topic in - Build logs for subjects built 1751 - 1800
Thanks Greg. Now I've gotta suck it up start raising them! -
USF Confederacy by Rustyj - FINISHED
Hey all sorry I missed your posts. With so much going on they slipped by. Sinan, Next ones are! Triton Cross section, Echo Cross Section and Bomb Vessel Granado Cross Section. All in various stages. Hi Bill and thank you. Guillermo, I think the black dye will be the next method I will try. Thanks Daniel. They are really nice woods to work with. Much appreciated Ed. Ben, If you think your job is a garbage scow you are sadly mistaken my friend!- 149 replies
- confederacy
- frigate
US Brig Syren by Rustyj - FINISHED - 1:64
Rustyj replied to Rustyj's topic in - Build logs for subjects built 1801 - 1850
Hi Peter, Thanks it was my pleasure and sorry I missed your post. -
All of the treenails have been completed and were made from boxwood. The end grain is quite a contrast. Here is the framing jig. I've also attached the keel to the building board. Moving on a bit slow but still moving! -
Echo by jml1083 - cross-section
Rustyj replied to jml1083's topic in - Build logs for subjects built 1751 - 1800
Hi Jim, Looking really good. I like your method of batch cutting. -
Thank you all. Pete. I just lay an old towel on the bench, grip the model with my left hand and cut with my right. That way I can twist and turn it as needed. A vise, for this, I find is to restrictive. If you had a piture of this you would think I'm trying to crawl inside.
- 332 replies
- Triton
- cross-section
Hi Grant. I am cutting mortices. You see some angle cuts on the ledges but that is my first step in cutting them out. I try to get the width correct and then I do the depth. Thanks.
- 332 replies
- Triton
- cross-section
Well here is a start on all of the carlings. You can see how I first cut out the plans and glue them in place and then work my way around cutting the notches and fitting the carlings. That's a start but there are a whole bunch more to do!
- 332 replies
- Triton
- cross-section
Thank all. You know we are our own worst critiques and if you don’t see‘em I not pointing them out! Oh and those who said I have beautiful knees have never seen me in a pair of shorts!
- 332 replies
- Triton
- cross-section
All of the knees are now finished and installed. Taking these pictures I noticed a couple of gaps I didn't notice before. Dang camera's. Next up will be to cut the notches for the carlings. Normally it's better to cut them while the ledges are off the model. That doesn't work so well for me. I end up with carlings that look like they are drunk. So I cut out the plans and glue them on the ledges and check them with a piece of wood laid over them to make sure I have a straight run. Them I cut the notches and fit the carlings. This will take awhile but I'll keep you informed.
- 332 replies
- Triton
- cross-section
What Ben! You can lend a hand. I don't remember there being any ratlines on the Confederacy!
- 147 replies
Thanks Floyd. Great to hear from you! -
Hi Jim, Greg, Pete, Ben and Mario. Thanks a lot. I sure hope it’s fun. I’m still thinking it will be past the sweep and gunports before the pressure will be less and the fun more. The treenails will be made from boxwood. I have had good luck with it so far. -
Ok we have a minor milestone here. I've assembled all of the frames now. The next step will be to treenail all of the chocks and then hopefully start raising some frames. -
Augie, Yes you do now back to work or your rum rations will be restricted!
