chris watton
Everything posted by chris watton
  1. Cheers, I never know until they go on sale. The last time I did an 18-gun brig was 25 years ago, so I wanted to make sure this one's a little more special and not a rehash of what I have done before. I do try to implement stuff I have thus far learned from previous designs, and also take on board constructive criticism of certain aspects. Harpy will be the latest iteration of that learning curve - plus I wanted to do this little fighter justice, being the longest served of her class and the most widely travelled, in action from the French Revolutionary to the end of the Napoleonic Wars. Plus she has great lines, being not nearly as 'Flat' as the Cruiser Class, but more like an much larger Speedy Class, lines wise. When I started this, my first stipulation to myself was that I wanted to include a stove. This meant that I would need to show the lower deck, so the model also has scale upper deck beams (4mm thick pear) and adding more lower detail, which does increase the material count by quite a margin. The deck planking pattern is actually copied from an original copy of a Cruiser Class deck plan, which includes the deck planking lines. As per usual now, anything directly glued to the inner and outer bulwarks have slots for their respective positions, eliminating the need to measure where they go, and because they are slotted as well as glued, the channels and pin racks are very strong and secure. I did make one change from the original plans, and that was to add stern davits, as I have a painting of her showing these, and I have no doubt these would have been added at some point in her long career. I will include at least one 3-d printed cutter, perhaps two, one for the deck and one for the stern davits. (Modeller can always leave the stern davits off, if they so wish) As I said at the start, I have no idea how this will sell, but I certainly didn’t want to simply produce yet another run of the mill kit with just bulkheads, keel and upper deck, like the ones I did 25 years ago - no fun in that. This will be my 17th and final kit for this year. Jim will be doing a build log for this later this year - I still have much to do before then, though.
  2. OK, I have just competed the hull designs for Harpy (1796), now onto masts. Here are a few pics of the (sacrificial) 'pre-prototype', again, used only to check fit of designed parts, so this has really been taken apart and put together a lot. (And is in fact the third of my builds for this) Again, the only planking required will be at the level below the main wale down, with everything above this all pre cut/engraved, including the main wale (this is why they take so long to design) Armament is absolutely typical of this vessel, 16 x 32-Pounder carronades and 2 x 6-Pounder long guns. 64th Scale, as I am sure someone will ask, and a hull length of around 545mm, with a lot of detail.. ETA - The hatch coamings sit on the deck beams and carlings, and not directly onto the deck, and the deck sits directly onto the deck beams, instead of ply sub deck and lime deck, for better scale appearance.
  3. For 3-d printed resin, there is no release agent to clean off, like resin from moulds, as the parts are thoroughly cleaned with Isopropyl Alcohol to remove any resin once printed – so the only contaminants on these would be from handling only.
  4. Funny you mention copy and paste renders in films. If you pause on a certain shot in the film Midway (the newer one), you will see they pasted half a dozen or so Yamato class battleships in an overhead shot.
  5. I have always wondered if they put the ladder there specifically for that occasion, for the ladies benefit.
  6. If you click on the magnifier in the picture, it brings it up almost full screen - that's how I did it and then just took a screenshot
  7. In all honesty, you do not need edge bending tools - the first planking is only 1mm thick, you can wet it and induce the curves you want using your finger and thumb
  8. Page for the launches are now live: 24′ and 26′ Launches (3D printed hulls) – VANGUARD MODELS 26 foot – 123 long x 37 mm wide - £29.00 24 foot – 112mm long x 34.5 wide - £27.00 Each mini kit has three 3-d printed parts and one sheet of 0.8mm pear laser cut parts. I am very happy to have started to produce these, and the forthcoming boat types. I remember the choices always being pretty slim (to put it mildly) for pre made hulls, usually having to settle for some generic type that was always too much of a compromise - and I also know that many have trouble, or do not like the plank on bulkhead mini kits. I am hoping these will help fill a gap...
  9. The table of contents links work for me, I click on them, and they take me the link description.
  10. Little update. I will soon have a new 24 and 26-foot launch for sale later today. These have 3-d printed hulls, windlass and stern davit, and a 0.8mm pear laser cut sheet containing knees, thwarts, oars etc. Both in 64th scale for now. I have also commissioned a 22- and 24-foot cutter, 22-foot yawl, 28 and 32-foot pinnace and another launch, so ultimately, I shall have complete pre made hull sets (along with the laser cut wood parts to go with them) for all of my kits, including future developments, as an alternative to the plank on bulkhead versions. Also almost ready are the new Nelson figures. This will be available in 72nd, 64th, 48th, 32nd and a few in 1:16th scale. These have a separate base.
  11. I would never ever use white metal castings in any of my kits again. The whole lot for Alert were thrown away and I was happy to take the finacial hit.
  12. Well, the file's been done now for that figure, so can no longer change it. I will ask for a seated officer next. What a morning, from 9am until just now I have been cleaning the laser machine after re stocking Indy and other laser cut parts. Not an enviable job..
  13. It's more dependant on the hull lines, but there are a couple of things I can do to mitigate it further.
  14. I am trying out a new digital carver, and thought it best to start with a figure. I did want another Nelson figure anyway, one that would stand up to closer scrutiny at larger scales.
  15. I have commisioned a second figure of Nelson using a new carver with more accurate facial features: These are a work in progress with a little more tweaking required. The render showing Nelson on the plinth was the first. I asked, based on previous feedback, to have dowels on the bottom of the feet and holes to take the dowels in the plinth, if people want to display the figure either on the plinth, or on the deck directly.
  16. Here is an unboxing review of Sherbourne, bt the Midwest Model Shops in the US: (Not much else to report on, just been producing/re stocking Indy laser cut sheets, which has taken an absolute age to do...)
  17. No filler blocks required. There are 17 bulkheads with a space of around 13mm between each one. Skeletal assembly is rock solid and virtually impossible to have the banana keels of old.
  18. You can give the wheel a few coats of spray primer, white or red oxide. This does help round off the edges. Wooden wheels are always way too thick and out of scale for 64th, metal ones almost as bad, and 3-d printed versions too fragile. (in my experience, at least - same applies to belaying pins)
  19. I always add just a drop of PVA to the bottom of each mast, as they will twist otherwise, and you'll be forever trying to twist them back into position - unless of course the mast is keyed into place.
