Everything posted by chris watton
Checking figurehead in relation to bowsprit, and the fit of the new stove. Pics not too flattering, but this hull is only used as a basis to check important parts and finalising the more important aspects of the hull designs. So now, I know that the whole hull goes together very well, all the gun and upper deck beams fit perfectly, and the bulkheads will give a nice run for the outer planking. Also inner bulwarks shown, these do take an age to get right, due to curves and the amount of upper deck beam slots. These are cut and checked using ply, but kit version will have pear versions, engraved and all positions marks or cut for all inner bulwark fittings - I always hated having to plank inner bulwarks, very awkward and there was always the real chance of some planks splitting or breaking off when filing the ports - not anymore!
The decks will be 0.8 or 1mm limewood laser cut and etched as standard in the kit, as this is what it will be designed for. however, as I have said before, this does not stop anyone wanting to plank the decks themselves using planking of their choice. They can use either the laser etched decks or printed full size deck patterns on the plans as templates if they so wish. I used to use maple veneer, which was really nice - problem was I could not have enough sheets in a nice neutral colour tone, so reject rate was way too high. All of my kits have pear as the finishing planking for the hull, be it in pre cut or planking form.
As a rule, double planked. Inner bulwarks will be fully pre cut and etched parts, though. Decks will be laser etched and cut limewood with no ply sub decks needed. I am thinking of just doing a single pear planking for the upper outer hull, and double planked at and below the thicker plank line (roughly where a main wale would start on an English ship) - But not sure yet...
And back to Surprise. These pics show the checking of the inner bulwark template (no gun port cut outs yet), and how it aligns with the upper deck beams. Once I know the fit is as good as it's going to be, I shall do the next version with gun ports and then check again. (Ply gun deck is not part of the final kit) For this design, I beefed up the bow structure a lot more than usual, as I know this can be a weak point when planking..
And now for something completely different. When I need other people, more skilled than me in other disciplines, to do work for me for future developments, I like to get these aspects sorted way, way before I start the project myself. Here is such an example, a set of cannons and a 17th Century brick stove/fire hearth, that were sent to me last night and printed overnight, for the very first check of parts – all went together pretty well, I think.
Yes, the books, not the movie. If you wanted a Surprise based off the movie, then Sphinx would be a better starting point, as they were designed for the same amount of guns and thus very similar dimensions. Here is the real difference in size between the film version and the real version, the latter being the one above: (The main wale lines for Surprise are erroneous, and will not be on the actual model, being French)
I have had quite a few enquiries regarding Surprise, asking if it is the film version. No - it is NOT the film version. It is being developed using the original Admiralty plans of Surprise (Unité of 1794, captured 1796) and he sister, the French Sixth Rate frigate Tourterelle (1794) If I were to develop Surprise as per the film, Master and Commander, the hull would be almost 20% smaller, being more Sphinx size, it would be around 18 foot shorter along the gun deck. This is because the film Surprise is that of a replica of a Seaford Class 20 gun ship of the 1750's, somewhat smaller than the actual HMS Surprise - and by the tail end of the 1790's, Surprise was considered very small for a frigate (hence why some refer to her and her sister as corvettes rather than frigates).
I had my new laser machine delivered and set up yesterday, a few teething problems, but to be sorted. I now have 2 large machines, with the new one picked specifically for the larger kits I have in mind in the future. This is by far the largest investment yet. Damn, I need more space.... Pics are a little too bright, shutter doors were open and sun was shining in!
Working area not much bigger, 1016 X 610mm compared to the 960 x 610mm of my current machine. However, that extra length does mean I can put 12 x 100x500mm sheets on the bed, rather than 10 sheets, plus I won't have to cut off 50mm off the ends of my larger (1000mm long) sheets to get them to fit. Current machine is an 80 Watt Sealed CO2 Laser, whereas the new one is 100 Watt (my first one, which is being part exchanged for the new one, is only a 40 Watt and a 635 x 458mm work area, so no good for Indy or Surprise, but got me started and it did cut the first few kits fine, if a little slow...)
I am sure I have already answered this a few posts ago. I have commissioned 3 figures (along with 2 figureheads). 2 figures being Aubrey and Maturin playing their instruments, and another figure with Aubrey in standing pose. Not cheap to commission, but I always had this in mind for Surprise and think they would be cool to add. These are being worked on right now. I know some will ask for more, like Killick bumbling into the cabin with a tray of food, but the ones I am having done are expensive, so perhaps something to add at a later date.
She looks fantastic, Bob, and I love the figures, they give the model 'Life'!
- 207 replies
- vanguard models
- Duchess of Kingston
I am hoping to have this a couple of hundred Pounds cheaper than Indy. A new box will be needed, a little smaller than Indy, at around 850mm length (largest laser cut sheets will be 800mm) OK, for the main pumps, I cannot run away from the fact that the real thing had 6 hand pumps, 3 per side of the Main Mast. This fact is even mentioned in one of the books I am using for reference. As with the Indy and her hand pumps, I cannot ignore this, so this is what my Surprise shall have as standard. However, I shall try (as in remember) to include an alternatve chain pump set in the kit, to give the modeller the choice. For the main armament, however, I will include as standard 24 x 9-Pounder carriage guns, and offer the 32-Pounder carronades as an optional extra (cannot include both in the kit, as the price would be higher) But, early days yet, still a lot to do...
Most of the parts are just MDF for this first build, as I know this is just to test what I have already done, and a few things will be tweaked, and the hull then thrown away.. There are scale deck beams for both the gun deck and upper deck, which will be in 4mm thick pear for the kit. There will be a little detail on the lower deck (although you will not be able to really see it) This will be my first design that does away completely with a ply sub deck. With scale spaced beams, a sub deck isn't really needed, so a 'Floating' laser engraved deck will be included (Or you can discard the supplied deck and plank as you like...) I have also designed the bow so that the gun deck isn't cut off by the forward most bulkheads, as is usually the case, but goes all the way forward. (Including the bow chaser/bridle port being framed) . Am yet to see how well this works out... Overall length will be around 1176mm including the bowsprit and mizzen boom. Oh, and I have my new laser machine arrive a week today!
