Alex-Ks1
Everything posted by Alex-Ks1
  1. this has nothing to do with this thread, I tryed to start a topic and it says its SP spam protected, I couldnt choose what type of topic . Can any one help. I looked at the web page for this spam page and will not download any thing I know nothing about
  2. Jim, start where you think it will be ok for you. If by looking at a photo of ANYTHING and it looks complicated to you, then by all means look at a lesser kit, weather it wood, plastic or all aluminum. You have to be the one that says you're a 1,2, 3,, or lever 12 builder. I build them for the enjoyment of seeing a bunch of plywood that ends up a wooden ship, I really could care less what people think of what I do. I have even sold 3 so far, and have given some away, My wife doesn't t want these dust collectors in the house, I have one, a 6 ft hull of the Flying fish on a chest of drawers in the dining room. Look at all the builds here there is a ton of info to use.
  3. there is a company MSC .COM that supplies all machine shops, they may have end mills that small. I know they supply my shop, they have a large on line catalogue
  4. what I use is a aluminum angel from the hardware store, then cut them in pieces to brace your bulks to the main frame with spring clips , always square and they will last a life time
  5. I do a lot of auto body work in my shop besides building the electric vehicles. after the base work is done as you think it is, you can buy a can of sandable primer. comes in gray and brown, put on from front to back , no X,ing it . then sand it smooth when you think its OK, Its usually not. Then take a can of black lacquer spray, spray the area fast to give it a light coat, we call this a guide coat, when you sand, the high spots will be gone, the low spots will remain. fill or sand. till its all smooth, your color coat will be very smooth, I keep most of the plank lines visible, not to look like a all fiberglass hull. if you want a high gloss look spray the color coat with clear, about 4 coats, then you can wet sand with 1,000 Grit wet /dry paper then buff. It will look like its wet, just like a new car look, . Sand to much or to hard and it will burn through.. its only for large solid areas
  6. Carl Sagan once said ," If you want to make an Apple pie from scratch , you must first invent the universe" Same goes for the ones who try and make a perfect creation of a model ship , when you actually come down to it , it's impossible . What type of paint are you using ?? ,It may be the right color but no way can you reproduce the exact formula . This isn't about anyone or anyone's model just my observation. As much as we want to do the best we can , things just won't go right .. Take this .. when a drawing is made , for want ever , by the time it's done there may have been 30 changes to it , and none of the changes show up on the original drawings . This must be true when building old wooden ships let alone modern ships . Just how many changes ?? We,ll never know . The new modern kit models come real close , but it's a close rendering . I don't buy kits , to me that's building some one else's model . I don't try for perfection, I'll never achieve it , accuracy is important , but I won't lose any sleep if it's not 100% .I do it for the joy of doing it . The thing is there large and my wife is getting to the point these dust collectors need to go . But then she changes her tune when I sell them lolololol
  7. for what its worth, I used a PVC pipe with end caps. this way I put a bunch of planking usually 3 ft long, and hot soapy water , cap it and let it sit, Believe me, you can almost tie it in a knot after 2 or 3 days soaking
  8. very nice indeed, Im about ready to build my Niagra, I bought a 4x8 ft sheet of 1/4 inch marine plywood and a same 3/8 sheet . I also have a 3D printer for a lot of things that cant be bought from any supplier, Like 6 inch long cannons . your doing a very good job...
  9. Hi, its a nice ship, dont be intimidated by the plans, go slow and steady, and YES do ask questions . Lots of experience here at this site rigging and planking can be very trying on ones patients . put up a log, let people see and you will get a response .
  10. welcome, If you think it looks good, than it is, even the first pyramid was lopped sided
  11. Thanks will call Monday,
  12. I have a precision small table saw, it uses a very thin diamond blade, this dose not put the rips in the wood, it looks more like it was uses with a hot knife. Very smooth, no rips,
  13. ok who can I call there to talk to about this matter, i down loaded the plans from the place in Maine, there not exactly what I wanted. 30$
  14. Yes, I want to call them on Monday
  15. Bluejacket doesn't sell plans , I called them , they wanted to sell a kit or a finished model.
  16. welcome , For me its been a long time since I was here. every time I retire, they drag me back . It seems we all wanted to start with doing a big project then reality sets in, it did for me. I always wanted to build something with my hands as a kid, Like the whole Navy, then end up doing a canoe.
  17. Thanks ,I'll give them both a try ..
  18. I will call after the holidays , here is my FLYING FISH. I finished it a number of years ago .
  19. looking for plans for the CHARLES P NOTMAN. I don't build kits only from scratch. and about 300% over size Does anyone know of where I can get a set of plans. This might be my last model, age, eyesight are against me. So this one will be on a 8 foot hull size. Thanks in advance
