chadwijm6
Posts posted by chadwijm6
  1. 6 hours ago, Egilman said:
    To get to specifics, the first and last pics are right on for a used engine in the hangar, the first as it is about to go into an aircraft and the last as it came out... And they are two different versions, the brass ignition ring is the earlier of the two, the last is an aluminum ring... (late/post war engine)
    The three middle pics are indoor museum displays, specifically cleaned and painted for display....
    The first and last are on USAAF issue engine stands, the three in the middle are on custom stands...
    Great pics.... Excellent pics in fact to establish the real engine... (and in specific periods of it's time, you got it covered)
    Good choices, well done..
    Fabulous. As I'm intending to build a dio that has the plane in a museum on display I'll be going for the look of the middle 3 with the brass ring I think.
    Thanks for taking the time EG, your knowledge really is a great help for me. 👍🏻😁
  2. Classic interior colour, looks great.
    I started only recently making models and got going with Vallejo paints and now I have quite a collection, amazing how quickly they build up, although I'm sure it's not a lot compared to others who have been modelling for years. On the whole I find them easy enough to use, occasional clogging but not very often. And they are pretty reasonable cost wise. I always use about 40% paint thinner, 10% flow improved and 50% paint and use their 'Air' brand in the airbrush, I have an H&S Evolution, and then their model paints with a brush. That said I've bought Chrome for Lexan Lacquer from AMMO to try on my B25 which will be interesting to try.
  3. 26 minutes ago, Egilman said:
    No problem my friend, and from what I can see from the parts images you posted, the kit is accurate as to intake and exhaust headers... So, no worries on assembly... If I remember correct, the B-25 exhausts were just elongated (flattened) header pipes routed out the cowl vents.... Some of these engines depending on application had an exhaust collector ring that dumped out the bottom quarters on each side of the fuselage, but not the B-25....
    This is going to be spectacular.... (I've got the glass nosed edition of the same kit in my stash) It's another of my favorites...
    I'll be following...
    You know your stuff EG!!
    I'll be following the build instructions for sure, glad to hear that they're accurate, I'm nowhere near being able to scratch build parts of it anyway. I'll try and get the look of it right though from a colour point if view.
  4. After a few days away from the bench doing things around the house and then finishing the Sea King this morning I've finally started.
    The landing gear has arrived and I'm very pleased with it. Looks robust and good quality.
    I've also received some figures I ordered, civilians that will be viewing the B-25 in the museum. I got these off eBay, the seller seems to 3D print them himself and even says that they will do bespoke orders.
    They look fine to me. They won't all be used in this build, I'll try to pick characters that look interested in war birds!
    20240502_122856.thumb.jpg.b883e78cc09ceed49035b5b7049b2bc5.jpg20240502_122840.thumb.jpg.aaf13b4ffdffff57a31703791b4356ce.jpg20240502_122836.thumb.jpg.0abae0a3f29f87e4d97bab3c9831c325.jpg
    So, on to the build. I'm going to display one of the engines so I thought I'd start there. Here's all the parts needed for the 2 engines.
    And so far I've been using some reference photos I found online to try and get the colours right.
    Screenshot_20240502_134529_Chrome.thumb.jpg.1bfab12e50078893c589b625a131cc01.jpgScreenshot_20240502_134450_Chrome.thumb.jpg.1ff5046f4e1f2fb57a531efff19232ab.jpg
    Here's some progress so far...
    20240502_173635.thumb.jpg.23a5df561d0cab6f017d6bc4e4078344.jpg20240502_173651.thumb.jpg.4603c105b7425a25c750d6aba31dca88.jpg20240502_173659.thumb.jpg.ba01354a05dfaaf73041572637bf7589.jpg20240502_173714.thumb.jpg.01fedc3e17d72948f2c5697d3e88de52.jpg
    No more updates for a few days as we are going to Cornwall for a bit of a break in the morning.
  5. So having done some reading and watching a YouTube build it seems that this model needs a lot of weight to keep it from tail sitting. The instructions call for 80g, general consensus is it is closer to 200g.
    And this leads to problems with the front landing gear not being able to support the weight without bending or even breaking. Later versions of the kit came with metal parts but mine had the plastic ones. And the gear is fitted before closing the fuselage so no opportunity to try it really.
    Therefore I've ordered an aftermarket replacement from aerocraft models, I came across them reading a build log.
    https://www.aerocraftmodels.com/north-american-b-25-mitchell-undercarriage-for-132-hk-models-kit-27-p.asp
    Better to be safe than sorry I think
  6. Morning all, it was the model show yesterday, an enjoyable wander around for a couple of hours. I thought I'd share some pics.
    Interestingly I didn't see a single built B-25, I did see quite a lot of Sea Kings though and a lot of Lancasters and Spitfires, no surprise there.
    There were some fantastic dio's, a world record attempt at the largest model railway, some amazing railway set ups that must have been a whole project in themselves to get them there and set up.
  7. 11 minutes ago, Old Collingwood said:
    Good work with  figures,   my  to  go  with  routine  is  -  Black  primer  (as it  works  good  for  shadow line detail)   faces and hands  with  any details  picked out  (depends on the  scale of  the figure)  then a  wash  with  high lights  picked out  and a  wee bit  of  slightly more  pink for  cheeks etc,   then  blocking in the  main colours then  fine details  like belts  and small details,   then when fully  dry  after  a  day or Two  a  wash over  the  main  body  then  fine details  picked out  -  like  over belts  etc.
    Its  all  an illusion  of  shadows  and  high lights.
    Hope this  helps.
    OC.
    Very helpful. Yours are fabulous. Thank you OC
  8. I'm painting the figures to go on the diorama and I'm very new to this... One previous attempt. So I watched a couple of YouTube videos.
    The one I've followed was to prime in black, then highlight with white. This is what I ended up with, although this figure is for a different project
    Next step was to water down the paint and apply very thinly, glaze it effectively, and then add some highlights by dry brushing and a bit of a darker paint wash to add depth.
    It's amazing how the the high and lowlights really make a difference, I've tried to capture it in the images below.
    20240426_152958.thumb.jpg.82902c001cc11d0c8e0d6d8091071a50.jpg20240426_152852.thumb.jpg.c77ecb86a7e951e60a5e7aa4d3c79fc8.jpg
  9. 56 minutes ago, yvesvidal said:
    I was lucky enough to see about 6 of them flying in formation at Oshkosh,WI a few years ago. Quite a sight, in the air and on the ground.
    Yves
    2 hours ago, allanyed said:
    One of my all time favorite planes.  Luckily I got to see one up close and personal and get on board the B25 owned by Ed Browing's Red Baron Flying team which sponsored Daryl Greenamyer's low altitude speed record flight over  Mud Lake, Nevada.   Great story and one of the greatest thrills of my life to work for one of the sponsors and be there to see it in person.  A bit off topic but for an interesting read - https://www.916-starfighter.de/F-104RB_RedBaron_AirProgress1977.pdf
    Allan
    I'll get to see one in the metal, probably just a fly over though, at the Midlands air show on the 1st June.
    I've seen lots of photos of the red bull one online, in fact that was why I wanted to seek out an all metal version to model. They are a cool looking plane !
