schooner
Everything posted by schooner
  1. Thanks for all the kind words Carl, Nils & JPAM. Foc'sle I placed the anchor windlass in position and added the anchor chain. I was a little surprised to find no evidence of chain stoppers on the Liberty's, apparently they just let the anchors ride on the windlass brakes - must have made for some excitement in heavy seas. The forward gun tub was next to be added. I'll wait on adding the guns to the very end of the build because they are fragile and I don't want to have to try and dust them. There are a few more items to add in the bow area and then I will probably add the main deckhouse.
  2. Time to paint Between “new house” chores and trying to hook a few more trout before the streams get too hot there hasn’t been much new with the model. I did get the stack put together and I scratched some “J” vents for the fuel tanks that will go along the bulwarks and the superstructures I finally stopped stalling and broke out the airbrush and got to work on that. I chose Model Master's Ocean Gray since the early Liberty's were painted darker than Navy Haze Gray and given the scale effect this is what I was looking for. It has a little more sheen than I wanted but I'll be giving everything a coat of Dull Coat at the end so it should not be a problem. With most of the big parts painted things should start moving along at a more respectable pace now.
  3. Greg, When it comes to realistic super-detailing you are without equal. Stunning work. Your always entertaining comments are a real plus. Thanks for taking the time to share all this. Tim
  4. Thanks for the kind words Jean-Pierre. I have seen very realistic anchor chain links in 1/100 scale, as you said, but I have not been able to find any in this 1/192 scale so I'll just have to stick with this simple chain. I think that many of the problems you found with the old Liberty ship kit have been corrected with this new updated version, so far I have been very happy with the accuracy and fit. I agree with you about solid hull versus plank on bulkhead, once your learn the tricks of POB it is easier to work with - my next kit will likely be a POB.
  5. Anchor Windlass - final The final details have been added to the windlass. The capstan heads and hand wheels are after-market, the brake bands, hand cranks and other stuff are scratch.
  6. Anchor Windlass After a hectic 3 months we are now settled enough in the new house that I can break out the model and get started again. As I said in my last post, I wanted to replace the kit-supplied windlass with a scratch one that would be more to scale with regard to height. I made the bedplate, steam chest and pistons out of sheet, rod and I-beam styrene. The main shaft and gear wheels are a combination of tubing, rod and a bag of watch gears I found on the internet. Next up will be the capstan heads, brake controls and gear controls.
  7. Anchor Windlass (and last post for a while) The kit provides a 1-piece Brittania casting for the anchor windlass, nicely detailed: I was all set to go with it when looking over my pix from my visit to the John Brown I noticed that the real thing stands about 4-1/2 feet high whereas the kit version, while correct for length and width, scales out at only a little under 2 feet high as you can see by the comparison photos (BTW my model will not be red - I just have not painted the hull its final color yet - the red is overspray form the red, underwater section): I hope to be able to scratch build a new windlass and that job was made easier after I found a bag of used wristwatch gears online for about $2, with some plastic I-beams for the foundations it should hopefully turn out OK. This will be my last post for a couple of months since we are in the process of moving to North Carolina and all my model stuff needs to get packed up. Hopefully I can resume work in April or May.
  8. 4-inch gun With the exception of the earliest Liberty’s (like the Hopkins), almost all of them were fitted out with a 5”/38 gun for their main battery. The gun was power-operated, fast firing, and when paired with a fire-control system and VT-fused ammunition it was very effective against aircraft. Installed on virtually every class of US warships it was widely considered to be the best naval gun of the war. The kit provides a nicely cast Brittania metal gun. Unfortunately for the Stephen Hopkins, the 5/38 production line was still working up when she was launched so she had to make do with a WWI leftover. The 4”/50 was mass produced after 1914 and was primarily fitted on the “4-piper” flush-deck destroyers. It was manually trained and elevated and did not have the capability to fire anything but basic point-detonating ammo, making it useless against aircraft. However, as I pointed out in my first post, with a trained crew it could be deadly against an unarmored ship at close range. When looking around for materials to scratch build one I found that toothpicks scale out perfectly for the barrel, assuming it could be narrowed near the muzzle and built up near the center and breech. I chucked one up in a Dremel and tried to trim it down but it quickly splintered. Soaking it in diluted white glue did not work. I tried thin CA and with some trial and error, reapplying CA after the surface layer was filed off I was able to get what I wanted. The CA also allowed for the drilling out of the muzzle - something that an unreinforced toothpick won’t stand up to. The areas that needed to be built up were wrapped with thin tape as needed. The rest of the mount was assembled with sheet and rod plastic and brass rod. One item that I have found very handy for scratch building is this little set of punches for making discs. I had been using a set of hollow punches but they always produced ragged edges - this set does not. Here’s the finished gun:
  9. After seeing this I can never whine about tiny PE again! As far as tweezers go, I've had some luck wrapping the tips in 1 wrap of masking tape (sticky side toward the tip - not the work piece) helps keep small parts from being propelled into a parallel universe when I squeeze too hard at just the wrong time.
  10. Small deck fittings I added the bitts and roller chocks and replaced all the scratch cleats along the cap rail since they were not secure. Some of them will be under tension from the rigging so I made new ones and drilled holes for them in the cap rail rather than just glueing them. The small white things on the deck are scratch pad eyes for the mast shrouds and stays, most of them are pinned in place since they too will be under tension. I had hoped to paint the hull today but the temp in my garage is now in the 20’s so I’ll have to find more small work to do while waiting for the weather to improve.
  11. Main & Mizzen Masts Just like for the Fore Mast the kit provides dowels, laser cut wood, blocks, vertical ladders and eyes to make up the masts. They are basically the same except for the addition of the topmasts. Here’s what the masts, minus the ladders which will be added later, and the eyes which I replaced with scratch pad eyes: I added additional details to include railings, the Aft Range Light, jib for the flag, pad eyes for the stays and shrouds, cargo blocks for routing the jumbo boom rigging, rings for stowing the 5-ton booms in the vertical position, and working lights (lenses for the lights will be added after the final painting).
  12. Masts The kit provides dowels, laser cut wood, crow's nest, blocks, vertical ladders and eyes to make up the masts. Here’s what the Fore Mast looks like, minus the ladders which will be added later, and the eyes which I have replaced with scratch pad eyes: I added additional details to include railings, the Forward Range Light, halyard blocks, pad eyes for the stays and shrouds, cargo blocks for routing the jumbo boom rigging, rings for stowing the 5-ton booms in the vertical position, and working lights (lenses for the lights will be added after the final painting). Here’s the finished mast dry-fitted to its mast house:
  13. Thanks for all the likes and comments. Cargo Booms The two “Jumbo” booms (50 and 30 tons) are made up of nested tubing. I departed from the plans by making mine thicker for most of their length, which is how they look on the SS John Brown. The plans call for 2 eyes on the end of the boom but since I hope to go totus porcus on the rigging I will need 4. The eye bands available from BlueJacket work well so after drilling out the flanges they were easy to add. The ten 5-ton booms are also made up of nested tubing. Here I also need 4 eyes on the ends but the eye bands looked oversize so I made individual ones from strip plastic and 3/32 split rings. It got pretty tedious to drill, cut, shape, assemble, glue, drop into the carpet, cuss, and repeat 39 more times but I’m happy with the outcome. One less happy discovery was that the 5-ton booms would not fit into the kit-provided eyes that I had already attached to the mast houses. Even when opened up with pliers they still did not work. I found that the pad eyes from the BlueJacket catalog worked fine. The only problem was that their circular bases were too wide but they were soft enough that I was able to trim them with a Dremel sander. Here’s the replacements on the left, the original eyes are on the right:
  14. Stunning work Rod - your build is one of the few that can stand up to close-up photos. The stand is a nice finishing touch - doesn't distract from the model. So, what's next?
  15. Hatch Covers Not much progress on the model itself lately. I've been building and finishing the display board and running it out to a plastic company who made the display case for me. I needed the display board done this early because right after I paint the hull I'll mount it on the board so I don't have to handle it anymore. The kit provides 2 laser cut pieces to form each hatch coaming and cover, the covers are etched to show the individual hatch covers - you can find them as tables in the cocktail lounge of every cheesy seafood place with a name like “The Rusty Scupper.” I built up 3 of them for the 3 hatches that I will leave closed/covered. For the 2 hatches that will be (hopefully) either full or partially open I had to scratch the coamings. After several attempts I got 2 that are square and the right dimensions. I’ll add details like hatch beams, etc, later on. Next up will be the final sub assemblies and then it will be time to paint the hull.
  16. Forward Gun Tub (cont) The kit provides laser cut pieces to form the supporting tower for the gun tub. The pieces are nicely formed but for anyone building this kit you should check the height of the central piece - mine was about 4mm too short. It was an easy fix to add a piece to the bottom. The tub itself had to be scratched to accommodate twin vice one gun. I kept the length the same as the original and just adjusted the width. Most of underside support braces are scratch. After it is mounted on the model there will be additional pieces such as ladders and stanchions.
  17. Forward Gun Tub After a great trip out West it’s time to get back to work. The next item on the to-do list is the forward gun tub. This marks the first departure from the kit in that the kit provides a nicely cast 3/50” AA gun which was the standard gun for probably 95+% of the Liberty’s but since the Hopkins was one of the earliest of the line the “standard” Liberty weapons were not available so she was fitted out with whatever could be scrounged up. She ended up with a pretty peculiar choice of dedicated AA guns - they were obtained from the Army and consisted of 2 37mm guns. The original design of the gun was as an anti-tank weapon: It proved to be notoriously ineffective against German armor and was withdrawn from AT service in 1943. Someone thought it would be a good idea to make an AA version of the gun that could be mounted on a trailer: Although the gun had good range (8000 yds) and rate of fire (90 rpm) it had a huge drawback in that it did not fire airburst or tracer ammunition. This made it almost impossible for the gunners to tell if they were getting close to hitting an aircraft, and more importantly, there was nothing to deter or distract a pilot on his attack run. Nevertheless, that was all that was available and 2 of them were loaded on the Hopkins and fitted to jury-rig mountings (during a storm in the Indian Ocean both mounts broke loose.) As it ends up, they proved to be deadly when used against a ship at close range, as the Steir found out. Before I could determine the shape and size of an appropriate gun tub I had to scratch build the guns. There is not a lot about them readily available on the Internet but after a lot of digging I found a 1944 Tech Manual for them. Why someone would take the time to scan and post almost 300 pages of an old maintenance manual is beyond me, but then again whoever it was probably thinks building ship models is strange. After getting the dimensions of the guns I made the major parts out of brass and plastic: After adding more details and painting (I figured they would have been left in their Army Olive Drab paint scheme) they are ready to go:
  18. Hi Rod, Sorry for the delay in getting back to you but we are on a looong road trip (currently in Oregon) and I finally remembered my password for this site. As far as spray paint to match the haze grey I've had good luck with spray primer, usually from an auto parts store but some times from big box hardware stores. I can't remember a particular brand (they tend to change frequently) but the good news is that the stuff is cheap compared to hobby paint. I recommend you paint a small piece of cardboard with your haze grey, mask off 2 or 3 areas of it and then try a brand by spraying it on the cardboard. If it is not a good match spend another 2 or 3 bucks on a different brand. I've never had to make more than 2 tries. Keep up the good work on your Burke - she is coming along great! Tim
  19. Thanks Bill. It has been a real help having a Liberty nearby, even though there are a lot of pix on the web the real thing helps. I've been thinking about BJ's T-2 Tanker but close-up, detailed online photos are pretty rare so I'm not sure I could do it justice.
  20. Caprail Details During my visit to the SS John Brown I was struck by the large number of eyes and cleats along the cap rail of the bulwarks, mainly in the vicinity of the hatches. I used a diagram of the main deck proved to visitors to mark their number and locations. Later, while doing research on the cargo rigging I discovered there was a need for so many so that wherever the cargo booms were positioned there would be a securing point for the boom vangs reasonably perpendicular to the boom in order to exert maximum control. You can see a couple of them here: The eyes were easy to make: just place a nail of the right diameter at the desired distance from the edge of a board, bend the wire around it and clip it at the board edge. I was able to make about 15-20/minute. The cleats were more time consuming. The wire was too small to solder easily so I just cut a slot in the end of some plastic rod and glued the wire in place. Unlike the eyes, they won’t be under any tension when I rig the model so I’m comfortable just going with glue. Between the bulwark stiffeners, eyes and cleats that makes for over 300 small pieces just along the bulwarks so this is a good time and place to take a break for about 6 weeks while we go on an extended road trip. When I return I can get back to work with larger, less repetitive pieces.
  21. Caprails I used some strip wood (soaked in hot water to fit the curves) to fashion the cap rails. They scale out to 18” wide which is what I saw on the SS John Brown. The pencil marks are where the 90+ scratch eyes and cleats will go.
