Everything posted by Jim Lad
Mutiny at the Nore 1797 - HMS Mars letter
Jim Lad replied to druxey's topic in Nautical/Naval History
Seems a reasonable price if it's original and genuine. John -
Just take it one bit at a time, Greg. You need to be able to get the derrick higher or lower - achieved with the topping lift. You need to move the derrick from side to side - use the outboard guy and the span. Maybe you need to make the whole rig a bit safer to use - make sure the preventer is rigged on each derrick. You will ceretainly need to raise and lower goods of some kind - hook on the runner and away you go. John
- 200 replies
- Transport No. 103
- Hasegawa
(and 4 more)
Greg, Everyday cargo gear is quite straight forward (heavy lift gear can be a bit more complex). First, there is a topping lift (called a span in your second illustration), which lifts the derrick to the required height and then holds it in position. There a several ways of operating this - the most common I came across was a 'monkey face' - a triangular face plate - shackled to the topping lift with a tackle (single blocks) and a chain shackled to the other two eyes of the plate. The running end of the tackle ran through a block on deck and to one of the winch drum ends when the derrick was being raised or lowered. when at its working height the chain was shackled to an eyebolt at the foot of the mast and the tackle let go. The derricks were usually operated in 'union purchase - both derricks operating together; one centred over the hold and the other over the side. The slew of the derricks was controlled by the outboard guys (slewing guy pennant in second drawing) which were shackled to eyebolts on the bulwark capping with a cleat for the running end close by on the bulwark. The span (schooner guy in second drawing) connected the two derrick heads and ran to a cleat (anywhere convenient back near the derrick heel). The preventer guys shown in the second drawing may or may not have been rigged, depending on where the ship was operating. They were required in Australia but not in most of the far east or Europe. The preventers were a single heavy wire shacked to the derrick head and, once the derrick was in its working position, the lower end was shacked to an eyebolt on the bulwark capping using a preventer stopper as in the image below. The idea of the preventer was to act as a safety wire in case the outboard guy carried away under load. Finally there are the runners - the wires that run from the winch drums to the cargo hook via the derrick cargo blocks. in union purchase the two runners are shackled to two eyes of a 'monkey face' and the cargo hook is shacked to the third eye (the mouth?). And you're all ready to load or discharge cargo. when at sea derricks were always stowed. i have done one short voyage with derricks 'flying' but not a good idea. In most jurisdictions a ship was not allowed to sail until the derricks were properly stowed. If this isn't as clear as I think it is or if you need any more detail - yell! John
- 200 replies
- Transport No. 103
- Hasegawa
(and 4 more)
Welcome home! John
Hello from Southeast Michigan, USA
Jim Lad replied to DonBMichigan's topic in New member Introductions
Hello Don, and a warm welcome to the forum from 'Down Under'. That's a very nice looking dinghy you've built. John -
hello -old shipbuilder signing in for first time
Jim Lad replied to manning16's topic in New member Introductions
Hello John, and a warm welcome to the forum from 'Down Under'. John -
Hello, and a warm welcome to the forum from 'Down Under'. John
hello, and a warm welcome to the forum from 'Down Under'. John
Hello tim, and a warm welcome to the forum from 'Down Under'. John
Hello, and a warm welcome to the forum. John
In my opinion, a vessel the size of the sphinx would certainly have been fitted with a binnacle - an essential piece of ship's equipment. It may very well not show up on plans simply because it was a usual fitting and ond would have been taken out of store and lashed down forward of the wheel during final fit out. John
Greetings from North Carolina
Jim Lad replied to PostCaptainAubrey's topic in New member Introductions
Hello, and a warm welcome to MSW from 'Down Under'. John -
Hello David, and a warm welcome to the forum from 'Down Under'. John
Hi everyone from Brisbane Australia
Jim Lad replied to Ray Durant's topic in New member Introductions
G'day, Ray, and a warm welcome to the forum from down in Sydney. You've got some very nice looking models there. John -
Hello Aurelien, and a warm welcome to MSW from 'Down Under'. John
Hello BG, and a warm welcome to the forum from 'Down Under'. That's looks like a very nice model you're building. John
Hello Charlie, and a warm welcome to MSW from 'Down Under. You certainly live in a beautiful part of the world. John
Hello Eugene, and a warm welcome to the forum from 'Down Under'. John
Hello Mike, and a warm welcome to MSW from 'Down Under'. John
