Posts posted by ndeconte
Amazing workmanship! I am so impressed with this!
- Gerhardvienna, Canute, ggrieco and 3 others
- 6
The old man looks great Igor! What did you use to sculpt the cloths?
- Elijah, popeye the sailor, mtaylor and 1 other
- 4
- mtaylor, justsayrow, Tadeusz43 and 6 others
- 9
Navigation lights were made from a piece of clear acrylic rod which had the center embossed line done on the lathe. A thin piece of sheet styrene was wrapped around the top & bottom to mimic the brass fixture.
The lenses were then painted with transparent paint which I made from clear acrylic and urethane tints.
- AON, mtaylor, popeye the sailor and 5 others
- 8
- IgorSky, captainbob, AON and 3 others
- 6
- popeye the sailor, IgorSky, NJQUACK and 3 others
- 6
- IgorSky, mtaylor, popeye the sailor and 2 others
- 5
- mtaylor, IgorSky, popeye the sailor and 2 others
- 5
- captainbob, AON, popeye the sailor and 2 others
- 5
Haven't used that before, will be interested to see how that works for you. I wonder it its "sculptable" at all? Will have to check it out.
I have used the woodland Scenics Water Effects with great final results. Was able to sculpt in pooling and waves with it.
Orca by ndeconte - FINISHED - 35" movie replica
In between remodeling our downstairs bathroom, I got some work done on the fighting chair for the Orca........
The cushions are done except for adding some cracking in the vinyl, have to wait till the primer dries completely to finish that. The pocket on the back of the back cushion is a piece of Sheet styrene that I heated up with a heat gun and stretched around the basswood to form.
Also figured out how to do the recessed area in the slide arm for the footrest. Added the mounting bolt for the footrest to slider also.
