Posts posted by ndeconte
I'm also looking to do a scratch built of the Black Pearl....... I just recently contacted Modelshipmaster.com about purchasing the blueprints and was told they don't sell them, told me to do a google search and I'll find them. The only thing I have found are low res of them.
Does anyone have a lead on high quality prints of this ship?
Hey Everyone,
Hoping someone out there can help me out.......
Looking for reference photos of the mounting brackets that are on the underside of the seat of this model of Rockaway fighting chair. this is for the 36" Orca replica that I'm building..... I have had no luck finding reference for this bracketry!
Any ideas on where I can locate? I've gone as far as Emailing some owners of some I've seen for sale on line, but no luck.
I'm looking to replicate the wrap that is on the top, curved section of the ladder in the attached reference photo.
I got the coxcombing figured out, just can't figure out this other section......Looked on line, but with my limited knowledge on this, I'm not getting anywhere.
Any help would be greatly appreciated!
Just stumbled across your builds and I'm very impressed with your workmanship!
Thanks for sharing!
Following!
- CaptainSteve, mtaylor, GLakie and 2 others
- 5
- mtaylor, captainbob, ggrieco and 5 others
- 8
Hi Everyone,
Hope all is well on your end! Thanks for all the likes and comments on the Orca, much appreciated.
Quick up date here......
Here's are the finished barrels. I sculpted one which was shown earlier in the log here, that was molded then cast in Urethane. These were then base coated in a Lacquer based black paint, then topped with an acrylic based yellow. Once dry, this was scraped off in areas to show wear. Two different thicknesses of string/thread was used to replicate the ropes.
I was also able to find the time to get the shark jaw that is mounted on the front wall of the upper wheelhouse. This was sculpted in a wax based clay. This will also be molded and cast in urethane.
Some progress shots.....
Hope you like!
- ggrieco, popeye the sailor, AON and 4 others
- 7
Thanks for the kind words Guys!
JerseyCity Frankie, I'm building this for a Jaws fanatic (my stepson) so I'm trying to get this pretty damn close to the original. As far as the color.... It helps when you have a section of Hull from the Orca II which was the actual 3 paint colors on the inside of it, which isn't faded!
so, as you can see, haven't got this to my step son yet!?
Still working on it, always takes longer than you expect......Not rushing it!
Since my last installment I got the interior buttoned up, well enough to get the roof secured. Got the railing around the barrels done and a lot of the weathering done overall, D rings created out of brass rod and 00-90 washers, rigging started. Also, it took me a few tries, but I finally got a tension adjuster built for the rigging that I'm satisfied with!
hope you like!
Leaving tomorrow morning for Marthas Vinyard, getting gravel from the movie location of where Quint's shack was...... thought that would be very appropriate for the base.
- hexnut, BLACK VIKING, ggrieco and 6 others
- 9
So I've made some progress and I'm somewhat happy with how it's all turning out:
Door is painted and weathered:
Fly Bridge is built from scratch for the third time since I wasn't happy with proportions and scale. Hold downs for roof built from sheet styrene, brass rod and pin heads. Liferings cut and shaped from high density foam and covered in fabric. Base paint is on it's way:
Interior:
CB radio cut from high density foam, wire lead for mic, made from solder:
Cushions sculpted in high density foam. Rib added with solder wire and the buttoms are styrene rod with the end rounded off:
Second louvered door set built and primed. detailed down to the door knobs, latch and pad lock:
- Omega1234, avsjerome2003, GuntherMT and 3 others
- 6
ThanKS for checking it out guys!
The Old Man and The Sea by IgorSky - FINISHED - BOTTLE - Scale 1/72
Amazing craftsmanship at a tiny size Igor! Very well done!
Can't wait to see the completed piece, I'm following the progress now after just finding.
