Posts posted by Craigie65
Hi Robin,
I have the same difficulty with these bulkheads.
For the stern the planking runs all the way to the keel, so for bulkheads 13 and 14 the measured length includes the area to the keel. For bulkheads 15 and 16 these only have a few planks running from bulkhead 14. Therefore I just use the plank width measured at bulkhead 14. You may need a stealer in this area.
For the bow, the 1st bulkhead is usually similar to number 2. I think of it as part of a sphere with bulkhead 1 at 90 degrees to bulkhead 2.
Hope that helps!
good luck
Lovely work Kevin. Great to see this mammoth task completed. You should be very proud!
- Ryland Craze and Kevin
2
Excellent Kevin! Have a beer or three!
- Kevin, AJohnson and Old Collingwood
3
Sorry to hear about your broken fingers, hope you are on the mend.
You are on the right track using an electric drill/screwdriver to help shape the yards. Just take your time avoiding putting too much pressure on the yard arm nearest the screwdriver chuck. Once you get the taper close to where you want it, just proceed by hand using sandpaper.
- Stuka, AJohnson and Ryland Craze
3
Andrew,
Sorry to hear about your health, hope you are on the mend. Please take care of yourself.
I am sure the warmer weather is just around the corner, and you will be back in your shipyard soon. 😁
- Mr Whippy, hollowneck and AJohnson
2
1
Really taking shape now, Robin.
We have all been there with snapped drill bits. It’s fun digging them out 😡 The fine bits cannot take a lot of lateral pressure. Apparently HSS bits are stronger than the tungsten carbide ones, although the former are more expensive.
You should be able to source suitably sized walnut dowel to replace the stock you used on the pumps.In the UK Cornwall Model Boat stocks various sizes. I am sure you will find somewhere closer to home.
- Ryland Craze and Stuka
1
1
Glenn,
Ouch!!
Paul’s tubing idea made me think that you could “fish” the mast and call it a battle damage repair!
- Oboship, Glenn-UK and Paul Le Wol
2
1
Andrew,
Learning a lot from your build. Those really are mighty tight curves, hope you have enough spare planks to complete. Would be a shame to hide the excellent job you have done with the planking under a coat of paint.
- Oboship, AJohnson and chris watton
2
1
Hi Robin,
I think you have a bit more sanding to do, fun eh?
Run your finger down the hull, if it feels a bump, catch or a depression you need to fix it, otherwise the second planking will show every imperfection.
- AJohnson, JacquesCousteau and Stuka
3
HM Brig-Sloop Speedy by Stuka - Vanguard Models - 1:64
As for stealer, the trick is to have additional planks that are wider than those provided in the kit. You can then have a wider plank at the stern. I have a stock of pear strips from Hobbymill.EU. The owner, Vahur is a sponsor of this site. Worth a look if you are going to build more?
