Everything posted by Craigie65
Thanks Rob. I think I will send the Admiral shopping or visit the local Hobbycraft store
Some great tips here - where can you buy bees wax in the UK?
Thanks Timmo I'm thinking with the deck and cannon in place they may be hard to clean up from the inside. Then again I am not sure they will be seen.......
- 366 replies
- granado
- caldercraft
Glad to hear it. I am about to spend a fair bit of time in London over the next 5 weeks. I wonder what will rub off on me? Gin probably
- 57 replies
- rattlesnake
- model shipways
Mog I really like the "feel" of your build. It reminds me very much of the ships you see in many stately homes here in Scotland - an ancient and solid feel. I don't know if that was your intention but I really like it.
- 57 replies
- rattlesnake
- model shipways
Best Gold Paint??
Craigie65 replied to demonborger's topic in Painting, finishing and weathering products and techniques
Brain, True scale colour does vary from real life. Copper plating on a vessel was only that brilliant when brand new, but most seem happy with it. Personally I think if it looks right then it is. You can always tone it down with a satin coat if you think it is too bright -
Best Gold Paint??
Brian confession time - I was trying to use a quote from Andy who posted the link - sorry Andy! Norman Alclad have their own black primer which sprays beautifully, dries fast and as Andy points out - nice and shiny Mind you I have never tried it on wood - might need a coat of another paint to seal? -
Thanks Joe for the kind comments Just doing the spirketting just now. Busy 5 weeks coming up at work including a fair bit of time away from home. So output is going to slow down for a bit. Thank goodness for a winter break in my sport which means I might get Saturday back, unless the Admiral mentions those dreaded words - "Christmas shopping"
Hi Timmo, Just putting in the spirketting at the moment and thinking ahead to the hawse holes. The instructions would seem to have you drill them late on in the process yet there is a picture of the forecastle sans deck that clearly has the hawse holes drilled out. I don't know if you have reached that stage but would be interested in your thoughts. In the meantime I am going to look at the plans to see if there is a hidden tip there.
- 366 replies
- granado
- caldercraft
Lucky you To be honest I was way too sore after playing two games of hockey yesterday. So after a soak in the tub I snoozed on the couch will try to move my Granado forward today
- 98 replies
- baltic ketch
- corel
Best Gold Paint??
Actually, I remembered this stuff: http://alclad2.com/ Bar none, the best metal finish on the market. Provided you follow the instructions explicitly! I have only used the aluminium versions of Alclad2 on model aircraft. You really do get a very realistic metal finish. I would hope that their gold also works. One disadvantage is that it needs to be sprayed. Lots of masking! Second disadvantage is that metal paints tend to show up every imperfection if the surface is large; although I imagine that should not be a problem for you Casey? Brian I like the idea of gold leaf - Is it expensive? -
Best Gold Paint??
Goes without saying that a black undercoat will help the gold shine. Vallejo has some excellent metallics but they need thinning. -
Okay part two - During Strictly Start of the second planking. I wanted to try to use some of the techniques that I picked up on the forum. Some success but I struggle to vision the layout of all the planks and drop planks. I think I was trying to look too far ahead: but I have a better picture in my head for the next build - whatever that may be? And that is the first planking below the wale After this shot I used a bit of dark filler and after a sand down it looks okay - to be honest it will disappear under a coat of white paint. And the inner gunport patterns and planking above the wale all done. I have lined the ports without lids and will be lining the ports with lids shortly. The sweep ports need a bit of work to get the right size. Of course I could not resist to see how the forecastle would look The camber does not look right at all so a bit of sanding is needed - later!
Casey, Lucky you. I have to put up with the X Factor. I wonder if I can sneak off and do some sanding...........
- 98 replies
- baltic ketch
- corel
Hi, Been meaning to do this for ages Kit was a family birthday present and arrived late July minus the bulkheads but with 2 keels. a quick email exchange and a call or 2 to JoTiKa and they arrived in August. My first kit was HMS President by Sergal - I could not believe the difference in quality Here is the first of my pictures -playing hockey today so will post some more later today or on Sunday First planking done, gun port patterns and the wale. Bow with water line marked. The blue thing is a wine cooler that I use to soak my wood. Unfortunately I dropped it when emptying it - so new wine cooler on the shopping list for Christmas. And to complete the set the stern While I was waiting on glue drying i had pressed ahead with the mortar housings. These were great fun and little kits in their own right. These pics don't show the ring bolts very well but I experimented making my own by winding wire around an PE tool that i have. At this scale there was not much difference in quality so for the sake of saving some time I used the method in the instruction. Also I had read of the mixed results members have had with chemical blackening - so I decided primer and pain was the way to go. Admittedly the ring bolts need a touch up here and there but I am happy. And the last one for now all the components that make up each housing TTFN
Casey, Needle craft 101 for you! I'm sure there must be a "how to...." In the resource section of the forum. After all there seems to be a thread on most topics
- 98 replies
- baltic ketch
- corel
Where Do You Keep Your Working Plans
Craigie65 replied to BubbleHead's topic in Modeling tools and Workshop Equipment
Pinned to the wall. Although if I make to many more pin holes I am going to be made to redecorate by my Admiral
