Craigie65
Everything posted by Craigie65
  1. Yes I tacked the chimney in place and measured the coaming around it. I have taken it off as I want to modify it with a screen for the front
  2. Just noticed that the last picture shows the coaming that surrounds the chimney needs a bit of sanding
  3. Hi Mick Are you starting a build log? Always good to see how fellow builders are getting on
  4. Timmo Thanks for the heads up as I am starting on the headrails this weekend. Might try a test fit to see if I have tHe same issue.
  5. There are three articles pinned to the start of the section you have posted this thread in.
  6. There are some good primers in the resources section on how to plank. We worth a read first. Takes a bit to get straight in your mind- well it did for me. But well worth the effort
  7. Perhaps posting a few pictures in a log might allow you to get some additional advice from the planking gurus on the site. They can usually give you advice to sort most things
  8. Managed to find time to post an update I have re done the blocks of the two cannon under the forecastle Thanks to all who helped me get this right The forecastle deck has been added and planking has been completed and the combing for the galley chimney added. I like Timmo's additions to the chimney and plan to do the same. The bow sprit opening could have been better. I do wonder if this would have been caulked to make it a little more watertight - any input would be welcome. Chimney and capping rail next
  9. Mick no need to apologise actually my turn for calling you Mike. I think these logs are as much about learning as anything else. If I had not asked for help on the blocks .... Well it would be a disaster later
  10. I can only echo Grant - amazing BBQ. Very jealous as it is mid winter here which means rain and wind looking forward to seeing your build progressing
  11. Mick thanks. As Timmo has suggested quite a bit of sanding was required to get the shape right at the bow. When I test fitted the planks close to the keel I decided to take even more off those filler blocks to make the lines smooth. Timmo thanks for the kind words. At the time I could have cursed the paint to NZ and back. However looking at the hull now I am so glad I stripped it back. As for the blocks I found the smaller ones hiding at the bottom of the box - how foolish did I feel! The packet they were in had fallen out of the bubble wrap bag I have removed the wrong ones and refitted the right ones. Looks much better. I will try and post some pictures over the weekend.
  12. I reckon most of it could be sprayed and details picked out with a hairy stick I tend to go for sub assemblies which I spray and then attach to the deck or superstructure
  13. Eric Nice to see the detail resin can bring to a kit. Do you have pictures of the hull or contents of the kit?
  14. Thank youI think you are referring to one of the earlier posts that showed the mortar unpainted. I have now painted the mortars and the cannon. I did think about using chemical blackening but this seems to be a hit or miss, so I stuck to spaying them instead.
  15. Thanks Andy I'll try the proper blocks first and see how they look. I have seen Chuck's blocks and agree they would be an improvement. If I'm not happy then I'll consider ordering some
  16. Mmm I'll check the kit again but these were the smallest in the box 2.5mm rather embarrassingly I have just found the smaller blocks that had fallen out of the bubble wrap bag into the box. Time to cut out the offending items Thanks Daniel
  17. Well that's Christmas and New Year over with. My build was interupted by 5 weeks in London but I have managed to get some modelling done over the festive period. I swithered whether to paint the hull below the waterline as I was really happy with the second planking. In the end the paint won over. However the first blast of the airbrush highlighted all the imperfections that the Mark 1 eyyeball did not. SO it was stripped back, filled, sanded and re sprayed. Not perfect but I am happy with it. Progress with the quarterdeck and bulkhead. I am no artist so stuck to out of the box. I have never used such weird decals in my life. Having to paint the rear was, well weird! Some decent water slide decals would be better as there are plenty of great products to avoid silvering. The pencil techique was used for the caulking and it looks good. The forecastle is next and decided to add two cannon. Not overly happy with the tackle - especially the one to the rear of the truck. If the gun was hauled in it would not be fully inboard. However if I move the ring back it will foul the belfry and windlass assembly. Half of me says it wont really be seen when the deck is attached - but i know it is there. Any suggestions? Finally just a few other pictures No modelling this weekend as off to the firm's ball!
  18. That's better!
  19. Seems expensive to me the UK site Cornwall Model Boats is selling this kit for £260 ($350)
  20. Plenty of choice on eBay and not too expensive either And Amazon but will need to be ordered with something else to get above £10
