Everything posted by EdT
H Maury, I use ordinary Elmer's school paste sticks available in every supermarket or drugstore. Applied to the back of the pattern only, the patterns adhere well and they are easily removed by wetting with water, waiting 15 seconds then rubbing or scraping them off They come off very easily when wetted - almost fall off. Any remaining glue residue - usually minimum at most - can be wiped off with a damp paper towel. Ed
- 3,612 replies
- young america
- clipper
Elia, I hope you are right on the angle effect, but in any event that edge will be easy to pare back when fitting the frame. The forward frame edge will be squared off. I have just about decided to proceed with the cant frames next starting at the front. This will provide more space for the fitting work and will also allow the frames to be bolted up as they are installed. There is some lofting work needed to do that. Thanks for your interest. Ed
- 3,612 replies
- young america
- clipper
Again,thank you all for the generous comments. Again, its always easier to do this kind of work when it is held down flat at the workbench with good overhead light. I could have done this but it would have required some fancy support due to all the frames that are already installed - and needed to be installed before constructing the deadwood. Actuually this work turned out to be less difficult than I expected. I did have to remove the stem support bracket on one side at a time to get room for the chisel forward. Elia. the locaton of the sides of the scores were squared up from the points on the base drawing where the cant frames intersect the surface of the deadwood. The width of the score is therefore based on the width of the beveled "foot" of he frame pair. I did not attempt to slant the side of the score to match the cant of the frame. I expect there may need to be some adjustments needed to fit the frames neatly whe the time comes. The most canted frame - the forward one - is only angled about 17 degrees forward. I do like to mimic the shipyard when I can. Ed
- 3,612 replies
- young america
- clipper
Thanks, Druxey. I would have definately prefered to do this at the bench, but the order of construction got in the way. On these ships the keelson ran straight to the stem with the deadwood built on top. So the deadwood had to wait for the keelson and the keelson for the forward square frames. The assembly at this stage is pretty awkward on the loose. I considered dispensing with the scores, but I keep saying this is a structural model, so....
- 3,612 replies
- young america
- clipper
Thanks, Greg. Fortunately these recesses will be covered and don't have to be perfectly finished inside - just flat. Fine finishing would have required the work to be moved to the bench to get chisel clearance on all sides. I expect there may be some moinor adjustments needed when the cant frames are fit. Ed
- 3,612 replies
- young america
- clipper
Young America - extreme clipper 1853 Part 22 – Cant Frame Scores American Clipper Note: In a departure from the historical notes on the stirring adventures of these ships in service, I thought it would be a good idea to comment on some construction aspects as well. Since the forward framing is set to begin on the model, some description of that might be appropriate. The bulk of the transverse hull framing on these ships – and most ships – consisted of full breadth “square frames” whose lower timbers rested on and were bolted through the keel. As the forward (or aft) end of the ship was approached and the v-shape of the floor timbers that crossed the keel became more acute, a point would be reached where naturally grown “compass timber” could not be found to make these pieces. At that point – on these ships – “half frames” were installed. These were still square to the keel, but were made in separate assemblies for each side of the ship and were bolted horizontally through each other and the vertical deadwood/keelson structure – the backbone of the hull. Further forward, as the bevels on these frames became more pronounced, it would no longer be possible to bolt the sections of each half frame pair together with bolts “normal” or at a right angle to the face of the frame, without the bolt being exposed through the beveled side. At this point “cant frames” were used to complete the bow (or stern) framing. These were also bolted to the deadwood but were angled – canted – forward to reduce their bevel and allow the pairs to be bolted together securely. Since every ship had a different shape and since timber availability varied, it seems likely that these break points were set for each ship in the mold loft as the frame patterns were drawn out and timber supplies known. I applied this assumption in lofting the frames for the Young America model. Before starting work on the next frames to be installed – the forward half-frames – the “scores” for the cant frames needed to be cut while there was still enough room to do this. These scores provided important support to the angled cant frames by allowing them to be inset into the keelson/deadwood – rather than depending on bolts alone. The vertical joint faces of each half-frame and the cant frame extend up from the bearding line to the cutting down line. The bearding line defines the point at each frame where the frame profile narrows down to the face of the 16” wide keelson/deadwood. The cutting down line defines the upper edge of the inboard faces of the frames at the keelson/deadwood. The first picture shows a template - made from the drawing - being used to trace the bearding line on the model. A similar template was used to trace the cutting down line above this. The next picture shows the vertical lines of the scores being marked using a Plexiglas square made to slide clear of the keel retaining strips on the base board. These lines define the extent of each of the five cant frame joint faces – the area to be inset. The next picture shows the first score on the starboard side cut out. Since I plan to plank the starboard side of the model, I started this risky chiseling process on that side for practice. Planking is a great way to hide framing mistakes. I will not describe the full process here, but the next few pictures show it generally. In the first picture the vertical lines are being scored with a knife using very light cuts. In the next picture, a chisel is being used to cut into the deadwood at the bottom – just above the bearding line. The line just above the chisel is the joint line between the apron and the deadwood. The score itself was then pared out with various small chisels. The next picture shows some of that work in progress. The last picture shows three of the five cant frame scores essentially finished. Two more to go – on this side. Although it was more difficult to manage this work in place, I did it this way because the overall hull assembly is still quite weak and I did not want to risk setting it up on the workbench for that reason. Next: on to the half frames. Ed
- 3,612 replies
- young america
- clipper
Bruce, Here is a link to the type of Linen I use: http://www.johnnealbooks.com/prod_detail_list/72/2 I cannot recall if I have bought from this supplier, but this is the stuff - Barbour. Also, I cannot help you with size - the numbers have changed over the years. I mostly used the smallest size I could find -No. 100 - it may now be 100/3. The length of it on a 50 gram spool is about 950 yards. I do not see this offered and have had no luck finding it elsewhere. It is getting harder to find this. In doing a quick search I came up with a couple of other possibilites: http://www.wmboothdraper.com/Thread/thread_main.htm http://apps.webcreate.com/ecom/catalog/product_specific.cfm?ClientID=15&ProductID=18576 I cannot vouch for these produsts but they might be worth a try. Ed
I think they are the same. In any event, I tried isopropanol as you suggested and it works fine. Thanks, again. Ed
- 3,612 replies
- young america
- clipper
Young America - extreme clipper 1853 Part 21 – Keelson/Forward Deadwood continued American Clipper Note: When Young America was launched in the spring of 1853, her builder, William Webb, incensed by some critical press, issued a challenge to the owners of the fast McKay clipper Sovereign of the Seas to a two-ship, head-to-head race from New York to San Francisco. Excitement and bookmaking activity ran high. Unfortunately Sovereign sailed for China. Major disappointment all around. Work on the forward sections of the keelson and the deadwood continues. The first picture shows the second section of the lower tier of the deadwood being glued to the frames – held in place by pins with wood chocks buffers. Below is a lower view of this from aft. This view shows the pronounced v-shape of the most forward frames and illustrates the issue of securing timber to make the floor members of these. Before these keelson sections could be installed, the insides of the floor and lower futtock timbers had to be faired – at least up the the floor heads. The next picture shows this finish-work more clearly. Apart from the issue of flatness across the centers of the frames, it is difficult to do this work with the keelson in place. The next picture shows anoth piece of the deadwood being fitted over the forward end of the lower keelson. This picture also shows the mounting nut that is about to be covered forever by the upper tier of the keelson. In the next picture the forward section of the upper keelson tier is installed and anoth piece of the deadwood jigsaw puzzle being fitted. In the next picture that piece is being glued in place. Again, the dark discoloration on the wood is from washing off the excess glue. Finally, as shown below, the last piece of the deadwood has been installed. The sun has shown through the window and lightened this picture to help me celebrate the event. In the next part, I will cover the risky task of cutting large scores in both sides of the deadwood to seat the cant frames. Ed
- 3,612 replies
- young america
- clipper
Thanks for the information on the cotton, Bruce. I used cotton for the seizings and serving on Victory, but was concerned about stretching on rope over time and also strength - in hindsight probably overconcerned. I noticed that you prestretch the rope. I used Barbour Irish linen for my made rope. It is virtually fuzz free and very strong. I found that stretching it almost to the breaking point while still in the rope machine was enough to set it. If I decide to rig YA I will give the DMC cotton another look. I used mercerized cotton polyester for lines too small to be spun. I have this theory that the polymer memory in polyester will keep it from sagging. I also use an alcohol lamp to de-fuzz this. What do you do for these small lines? I too used cards for setting up the deadeyes - made from 1/16 hardwood. I used thin wire through two holes in the upper deadeyes twisted at the back to secure them. As I'm sure you have found, this method not only allows the shrouds to be tensioned with the deadeyes aligned, but also makes a convenient holder when making the seizings. Thanks again for the tips. I put a pair of those Lindstrom cutters on my wish list. Ed
Excelent, Bruce - and a great explanation. Thanks for the tip on the Lundstrum cutters - worth the price of admission. McKay was sure a belt and suspenders guy - evidently not just in his framing. Working stern to stem will be interesting to follow. The two toughest connections I had to make on Victory were the mizzen stay and the main topmast stay - seized to eyes in the deck behind all the running rigging behind the bases of the forward masts - not fun. What material are you using for your ropemaking? Ed
Great. Thanks, Druxey. That will save me trying out a lot of other things. Ed
- 3,612 replies
- young america
- clipper
Not a problem, Rob. Its a great picture. Daniel, I do not have a solution for cleaning off epoxy, but I am looking for one, if anyone has a suggestion. Liver of sulfur does not blacken brass in my experience. This is the reason I use copper for metalwork that needs to be blackened after installation - and wherever else I can for that matter. I like LOS better than the blue solution which is generally used for brass. This will stain wood. I avoid using this whenever I can. For iron bolts I ussually use black monofilament, but on bolts to hold iron knees on Naiad I sused copper wire the LOS to blacken. Ed
- 3,612 replies
- young america
- clipper
Young America - extreme clipper 1853 Part 20 – Keelson/Forward Deadwood American Clipper Note: In the last part I mentioned Flying Cloud’s record on her 6 passages around Cape Horn from New York to San Francisco before she was retired from that service. These averaged 116 days - 102 days if the last 185 day trip, during which she was dismasted, is discounted. In her long career Young America made the passage 20 times from New York, three times from Liverpool and once from Antwerp, with an average of 118 days per trip – her best from New York being 102 days – her worst, 142 days from Antwerp against persistent headwinds. Her best from Liverpool was 99 days. This was a stunning 30 year performance. So, back to the model. The remaining frames forward consist of half-frames and cant frames that bolt through the keelson and deadwood. Since the keelson is bolted atop the square frames, they must be installed first. So, with all of the forward square frames installed, the forward part of the keelson and the forward deadwood can be constructed. In the last part I showed a picture with two strips representing the two tiers of the keelson. The forward section of the lower tier – the keelson proper – houses the forward model mounting bolt. In the first picture a 4-40 nut has been filed down to fit a mortise in the keelson and is being epoxied in place. The next picture shows the mounting bolt screwed up through the keel, filler and into the nut in the keelson. It is protected from screwing in further by of the larger diameter shoulder butting against the bottom of the keel. The above picture was taken after installing the first section of the keelson. Before that could be done it had to be fitted to the apron at its forward end. At its aft end there is a large scarph joint with the next segment. Both halves of this joint were made before setting the forward segment. The joint is shown below. In all keel and keelson joints the face of the joint slanted downward in the aft direction. This is one good reason for installing the keelson from fore to aft. The next picture shows the lower keelson being glued over the filler and the forward square frames. The picture shows the joint with the second lower segment, but that piece is still loose in the picture. The wet spots are from washing off excess glue. The installed piece was then “bolted” down into the keel with copper wire bolts. That process is described below. The bolts have been filed off flush in the next picture. The next picture shows the first section of the forward deadwood being fitted. The pattern is still attached. The keelson and the deadwood is sided the same as the keel – 16”. The last picture shows the insertion of the copper bolts to secure the piece of deadwood. This piece has already been glued in, but the process being used for the bolts will also add strength to the model joint. First holes are drilled at a size that will allow a slip fit for the 22-gauge wire being used. This wire is pre-stretched to stress harden it. The holes in this case are about 1” deep, so the bolts are about a scale 6 feet long. The bolts are dipped in 5-minute epoxy and pushed into the hole. They are then moved in and out, removed and dipped in epoxy again, reinserted and again moved in and out. This distributes epoxy throughout the hole. These bolts will not come out. When the epoxy hardens the bolts are clipped and filed off flush. As additional members are added, they are bolted in a similar way with bolts as long as my drill bits permit. Later, additional bolts will be driven like this, through the forward part of the stem into the apron and deadwood. The keelson bolts are installed in like manner. In the next part, the forward upper tier of the keelson and the remaining forward deadwood will be constructed. Ed
- 3,612 replies
- young america
- clipper
Walt, this iron lattice-work extended only from the floor heads up to the planksheer. Also, the iron used was ductile enough to be cold formed either over the outer frames or into the concave inboard frames. In both cases these were scored so the plates would lie flush with the face of the frame. They were then bolted through the frames and through each other at the intersections. Hope this helps clarify. Ed
- 3,612 replies
- young america
- clipper
ancre LE BONHOMME RICHARD by Jeronimo - FINISHED
EdT replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Extraordinary work as always, Karl. Ed- 662 replies
- bonhomme richard
- frigate
Well, the mystery of the strapping continues. Rob, I am familiar with the Campbell drawings and have read the book. I don't think it is conclusive either way. John, I do think the secondary sources have not made a case either way - probably because there is no real data. To me, the best argument - until I learn something new - is that in 1856 Webb built the very large Ocean Monarch and it was internally strapped. To avoid suggestions of sources already consulted (and to provide a sort of bibliography for anyone interested) I list the sources used so far on this and other construction: Crothers, The American Clipper Ship Howe and Matthews, American Clipper Ships MacGregor, Fast Saling Ships Chapelle, History of American Sailing Ships and Search for Speed Under Sail Campbell, China Tea Clippers Desmond, Wooden Ship Building L. McKay, Practical Shipbuilder New York Marine Register, 1857 American Lloyds Registry 1859 Maclean, Boston Daily Atlas - Challenge 1851 Clark, The Clipper Ship Era Cutler, Greyhounds of the Sea Underhill, Masting and Rigging SeaGull Plans (Crothers) for Lightning, Challenge, Young America Suggestions of other sources are of course welcome. Thanks for the input on this. Ed Bruce, I have not read the book but ordered it used from Amazon for $4.
- 3,612 replies
- young america
- clipper
Hi Allan, No, the ends are not shiny when they are shaved off with the blade. They usually also get sanded - or filed - with no ill effect - unlike blackened metal. They are mostly for appearance. Its hard to get enough CA into the hole to gain much holding power. There is no reason for pigment over acrylic paint, except that I did not want to risk corrupting the glue with the acrylic emulsion. I felt safer with the pigment. But from your comment that appears not to be a problem. Paint is certainly more readily available and based on what you said I would not hesitate to use it. I assume you dilute it to get good mixing with the glue? Thanks. Ed.
- 3,612 replies
- young america
- clipper
Young America - extreme clipper 1853 Part 19 – Framing Continued American Clipper Note: On her fourth voyage, still under Cressy, Flying Cloud left New York for San Francisco in January 1854 and set a new record of 89 days, 8 hours, just under her 1851 performance. This record would eventually fall to Andrew Jackson in 1859 with a passage of 89 days, 4 hours. This new record would be in dispute for years. These matters were taken quite seriously. Given the vagaries of wind, weather and seasonal variations, one wonders what all this recordkeeping really means. Between 1851 and her last Cape Horn voyage in 1856 Flying Cloud's record to San Francisco included passages of 89, 113, 106, 89, 112 and 185 days. I am getting close to wrapping up the forward square frames. The remainder of these frames – P through U are shown below after beveling as described earlier. The narrowing of the lower hull forward can clearly be seen. The next picture shows the frames with cross-spales being fitted to U and P. The next step was to reduce the sidings of the upper futtocks and toptimbers. This was described earlier. The last step before erection is to install the framebolts. These were 1” iron, unheaded, cut off flush. They are simulated with 30 lb. test black monofilament. After dipping in CA the filament is slipped through the pin holes used for assembly. There were 3 to 4 of these bolts per timber. There are two through the rail stanchions as shown above. After gluing in, the excess ends are easily sliced off with a razor blade as shown below. The next picture shows the remaining forward square frames installed. Starting with frame R going forward the sidings are reduced and the frame spacing increased. For example the floors go from 14” to 12” and the frame spacing from 32” to 34”. Webb used this method to reduce hogging by lightening the forward structure where the hull buoyancy was less due to the fine entry. This design feature was able to reduce the weight of the forward structure by as much as 25 tons in Webb's ships. On the model the spacers have suddenly gotten larger due to the increased separation. The last two are being fitted above. Next, another picture of the framing at this stage. The next picture shows the connection of the last frame, Q, at the keel. There are two points of interest here. First, there is the filler on the keel forward of the last full frame. Frames forward of this one will bolt to the sides of this filler and the keelson/deadwood – soon to be added. Second, notches in the tops of the frames at the keel can be seen. This is to provide additional bolting height for the next few frames which would otherwise have to be bolted only at the lower 17” of their feet – not enough – in my opinion. Additional bolting space can only be added by raising the cutting down line aft of this first half frame. If this were done suddenly at frame V there would be a step up in the inboard planking, so to provide a fair bed for the planks, I started raising the cutting down line four frames aft, adding additional bolting height of about 7" for the first half-frame. The last picture - showing some strips representing the two tiers of the keelson - will help illustrate the above issue and also show the huge size of the keelson. These two 16”w x 24”h tiers ran in a straight line from stem to sternpost, bolted heavily through the frame floors to the keel. I have placed a pencil mark on the lower keelson to show the raised cutting down height. This additional height will allow one of the horizontal bolts for the first half frame to be driven through the lower keelson. The model mounting bolt and nut is about to be set into the actual lower keelson once the forward end of that that is fitted to the apron and marked for length. Ed
- 3,612 replies
- young america
- clipper
Young America - extreme clipper 1853 Part 18 – Framing Continued American Clipper Note: Flying Cloud was launched from Donald McKay’s yard at East Boston a month before Challenge. She was of comparable size, and like Challenge, bound for California from New York on her maiden voyage. Inevitably she was drawn into the great “challenge” surrounding the ship Challenge. She left New York in early June 1851 under command of Josiah Cressy. Three days later she lost her main and mizzen topgallant masts, but reached the line (equator) in 21 days. She arrived in San Francisco in 89 days 21 hours, beating the previous record of 97 days, set by Sea Witch the year before – and 18 days under the Challenge’s ill-fated maiden voyage performance. After the last post, there was a question about the dark glue that I use to highlight structural joint lines. The 8 oz. bottle I mixed up for Naiad was just about empty, so when replacing it I took some pictures to help answer the question. The first picture shows the starting point, plus two bottles of ready made dark Titebond glue. The new bottle to the right is the currently available dark Titebond II. I find it a bit light for pear. The old – quite old actually – bottle in the center is the old Titebond dark glue – just about the right shade but no longer available. T the left is an 8 oz. bottle of the standard yellow. (The first thing I do with a new bottle of Titebond is pull off and toss the sliding top, cut off the closing nib and insert a length of plastic rod that is easy to remove and replace and does not clog up.) At the front right is a jar of raw umber artist grade pigment that will be used to darken the glue. This bottle is several lifetimes’ supply. In the next picture, about a teaspoon of dry pigment was added to about a tablespoon of water and is being thoroughly mixed with the pestle-like Teflon rod until there is no sign of powder or lumps. The entire 8 oz. of glue is then added a bit at a time and mixed in. The next picture showsthe final appearance. In the next picture the empty bottle has been thoroughly washed out with hot water and is being refilled with the darkened glue. I expect this will be enough to finish the model. The next picture shows the last of the full forward square frames. The rail stanchios are about to be installed. The frame is now ready for beveling. In the next picture the forward face of the pair is being trimmed back to the forward profile line on the disk sander. The aft outer profile was previously trimmed back. The disk is kept away from that line in this step. This leaves a hump or ridge between the two profiles. The next picture shows this being removed by hand with a flat Rasp. The last picture shows the resulting bevel. The insides are only roughly beveled – mostly using a spindle sander. They could be hand finished as well, but I intend to do that after the hull is assembled. The final bevel will be refined when the hull is finished sanded. Beveling these pairs before assembly saves tedious sanding work later, makes frame erection easier and yields a more accurate hull profile. There is still some work to do on these frames before erection. Ed
- 3,612 replies
- young america
- clipper
Again, thank you all for the supportive comments. Allan, sounds like a good project. The full framing would give you a chance to exercise those TurboCad skills as well. Anyway, I am glad to hear of your interest. I have been hoping the YA build would attract some from the fully-framed set. The framing is different from the 18C RN. It is alot simpler - no chocks, standalone frames, jogged or curved toptimbers and no ports to contend with. At the same time there is more of it. There are also more judgements to make on design specifics. Although quite a lot is known and documented on the general construction, specific ship structural details have been lost. Good luck. Let me know if a novice can help. Bruce, the framing is going faster than I expected. I spend on average 2-4 hours each day in the workshop, often in more than one session. I also spend time outside the shop - on research, drawings, photos and this blog. When I start to tire, I quit and do something else. The Sovereign / YA race would have been interesting. In reading the endless accounts and passage times for these various ships and routes, it appears to me that the abilities of the captains and the vagaries of the weather - especially time of year conditions - had as much to do with performance as the differences in the ships in this class - probably more. Variation in sailing times over the same routes are considerable for the same ship on different occasions. My impression is that Babcock, YA's original skipper, may not have been the man to beat Sovereign. On that first 110 day voyage to SF, it seems he made some judgements that extended the time, but I have not dug into that. Your comment on the iron strap bracing caught my attention, particularly your positive statement that it was on the inside. I am inclined to agree, but in scouring every source I can find, have not found a definitive reference. On Crothers Challenge drawing, dated 1975, it is clearly shown and noted as on the outside - the so called Lloyds system. By the time of his book (1997) he seems to have backtracked and is not sure. Most of the ships he lists have the bracing on the inside - the Admiralty system. But none of those are Webb's. He discusses all this. I believe by the 1860's the American Lloyds registry specified outside, but in the 1857 registry inside bracing is specified. Structurally, outside bracing is better, but more troublesome to install. I do plan to install this and am leaning - currently - to inside. However, my question is, do you have a reference for this? It is unfortunate that Great Republic, as designed never got a chance to show her performance. After the fire - before her first voyage - she was cut down and given a smaller rig - but was still a good performer. Young America also had a very long - and essentially trouble-free - career of 32 years with the 50 punishing Cape Horn passages before she was mysteriously lost on her way to Trieste from Phialdelphia in 1885. Thanks, again, for your interest and comments. Daniel. I made some new dark glue and will show some pictures in the next part. Ed
- 3,612 replies
- young america
- clipper
