glbarlow
Everything posted by glbarlow
  1. My first model is 15 years old now, doesn't show any aging problems with CA, guess I'll check in another 15 to se how its doing. I'm able to wipe off and if not then sand any spillage (as long as its minor) without problem.
  2. I'm in the CA group for 2nd planking, I just don't have the patience for PVA glue at this stage and don't want pin holes and I can do it fairly neatly. Using Chuck's plank bending with my travel iron gets the right shape without soaking and keeps the planks from warping and thus easy to glue on using CA. But there are as many techniques and choices as there are modelers so... My kit is pear wood (which is a HUGE improvement over walnut), but wishing I had the boxwood option. It will be a shame to copper over that beautiful wood.
  3. How did you determine the taper width on the stern? Until I saw your complete sequence of planking, from the first one I would have guessed the stern didn't need that much taper, but clearly it did. I'm starting my Speedy soon so enjoying the learning from your build.
  4. How do we maintain the preformed rabbet slot for the second planking?
  5. I’ve become a big fan of plank bending. I’m using a travel iron as my heat source, quieter and I think quicker. I even bent planks one way and then reversed it the opposite direction just to see if I could. It worked.
  6. I’ve had my Byrnes saw a long time, it just makes stuff easier. With that in mind I’m interested in comments regarding the new sliding table. Not being a woodworker beyond my modeling I’m not sure of its purpose. What does it do I can’t already do with the sliding gauge and slide bar? Everything about his saw (and Sander which I also have) is great, how would the addition of the sliding table make stuff more easy?
  7. You’ll find all across this forum people rave about the Byrnes saw, I like everyone else love mine. I use it all the time along with my Byrnes Sander. I haven’t sprung for the thickness sander yet, but based on the seemingly shortage of quality strip wood it may be next.
  8. It doesn't really count unless while dropping it you sliced at least one finger with an #11 exacto blade. I have band aides as an essential tool near my work bench.
  9. Agree with everyone, start over, filler can't get you there from here. You can find lime wood for the first planking cheap enough. No offense but not sure you read Chucks Planking process correctly. I just followed it for my current build and had great results. I don't agree that soaking is the way to go, that can lead to warping and swelling. I think your issue is more one of not tapering enough (or at all) at the bow (and too much at the stern) and not using Chuck's sideways bending technique. Get Chuck's hull outlining .pdf to see how to measure and mark the hull. I've always managed by guesstimates on prior models but learned a lot by doing it in detail and with more precision with this latest hull. Have heart, we've all been there and we've all gotten past it. Hang in there!
  10. I have a Byrnes saw and can do a reasonable job of ripping my own, in fact I did for my current model since I couldn’t find anything and still had a few billets from Jeff. It’s just that I prefer not to, I don’t do it enough to be good at it and I don’t have the proper ventilation to rip something like ebony. Even with that, I’m still looking for a source for quality woods in sheets in 3-5mm thicknesses. I’ll try some of the sites listed. I do miss Hobby Mill, didn’t realize how good I had it with Jeff.
  11. I know how to do tree-nailing the hard way. Any suggestions on simple, perhaps historically inaccurate, but nice looking, and quick and easy way to tree-nail a deck. Pardon the blasphemy of looking for a shortcut. 😄
  12. The easiest thing to do is use water based acrylic - I use Admiralty paints but there are any number of options. No headaches with water-based.
  13. I trace the outline of half the ship (from above view) from the plans, transfer that to a piece of 1x4 inch lumber, cut out the half hull profile with a scroll saw, cut a few notches into opposite side, soak the gunport patterns a few hours then clamp and rubber band it to dry on my board. The pattern then fits the ship perfectly and easily with no risk to the hull. I devised this when building my Pegasus, it also worked great on the bows of my Vanguard.
  14. I’ve adopted the Chuck method too. It’s great. I’m m using a stream travel iron though as the heat source, much quieter:-)
  15. I checked several of the sites listed but didn’t have much luck finding milled strips for ship building, specialty in millimeter sizes. This three is from 2013, anyone have more current suppliers for model grade exotic strip wood?
  16. I see Crown Timberyard is also now out of business. Anyone have a good source still in business as of February 2020?
  17. I'll be interested to see how it comes out. My current plan is to use the engraved deck and see how that comes out. I've planked every ship with holly or ash, spent all the time doing it and then once the ship is built out and rigged its not all that noticeable. I get the master builder point and the nuance of all modelers - and the fact that before now we really didn't have a choice. But maybe on this one I'll just enjoy the engraved deck. The Speedy might be the first kit I don't bash. One thing that did jump out is how wide the planks on the engraved deck are, mine are normally 4-5mm. One point to check before you get to far is making sure the cannon still fit in the gun ports with the thicker planking..
  18. sorry, I was actually responding in terms of Chris' Instruction manual photos....
  19. I’ve not had any response to recent emails using their web system, but I have received a call back. I think as they’ve replied here there is a problem with that system. No offense, I love my Byrnes saw and sander, but their website appears to be of a very old design and could use a refresh.
  20. I'd had an interest or two in my Fair American model. The link I had in my signature line went to "another site" so thinking that might be bad form I created a gallery for the completed model here on MSW under of course, Galleries. I hope you enjoy. Sorry the HM Granado photos still go to that other site, I don't have the original photos on my computer any more so...
  21. I think this is a great idea, us average guys always have fun with rabbits and bearding lines...not me. I look forward to how this turns out applied to a larger model.
  22. As long as no copper is involved...🤣 I’ll look forward to seeing the different design and likely will be a customer despite my whining about big ships😏
  23. Sounds like a great plan. I’ll look forward to watching your development of the Bristol, I’ll probably buy it and wait for a frigate too. I think I’ll be set for the next couple of years:-)
  24. This is a small thing but great for modelers, I like to build but making round axels out of square ones many many times not so much fun. Thanks for this “innovation.”
  25. I’m sure the Bristol will be another great model, but after the Vanguard I’m not sure I’m ever going to be up for another big gun ship. Do you have any nice frigates on your radar, one of Cochrane’s perhaps? I’m reading the book you recommended, he was a fascinating guy. The Imperieuse would be a fun build...he said hopefully...:-)
