Everything posted by glbarlow
Copper patinas over time and it evens out. Both my coppered ships look much better with “aged” copper. In my opinion, bright and shiny becomes the main focal point and detracts from the rest of the ship. I wiped off excess CA with acetone and left it alone other than that. Another point is overlapped copper plates may look off up close but are lost viewing on the shelf, gaps stand out. I mentioned this because I see a gap in your photo. Just a thought...
Thanks Lou, I'll give them a look. Google did not lead me to them so I appreciate the link. I think I'm going to make my first attempts with some Alaskan Cedar once Chuck re-opens his store. I'm not going to go nuts, aside from Cheerful I'll try the mast and bowsprit for Speedy/Flirt. But I do need the boxwood (ok Want the boxwood). I'll do some measuring to see if 3/8th works. 2" is way bigger than I'd ever need, though I may be able to rip it down some. I'm going to watch Derek in wonder as he makes his 🙂
- 725 replies
- vanguard models
- speedy
IBEX 36mm FLAT FINGER PLANE - 12mm BLADE. Ron (hollowneck) suggested this one. Thanks for the detailed response, I will make use of it in my prep for Cheerful, and likely the bowsprit for Speedy/Flirt. And here I thought you were just a good modeler, turns out your also a math professor as well 🙂 I may order more Alaskan yellow cedar from Chuck for practice and perhaps use on Speedy/Flirt and also see if I can find lime wood stock. I have had no luck locating boxwood. There used to be a guy, Jeff with Hobbymill. All of us miss him and clearly don’t realize how good we had it. The boxwood above the Wales on my Nelson was the last I had from him.
- 725 replies
- vanguard models
- speedy
Nice post, very informative. I've not converted square stock to mast and spars yet, but its time to learn. So: Between yours and the other couple of posts I can make the jig to hold the wood for planing. I ordered by first planer ever, it will be key to not slice off my thumb. However I don't have the means to work with metal or the metal to work with - your jig looks like an excellent tool but I don't think I can make it so I'll have to find another way to mark the wood. Where did you get the boxwood, it seems like it’s a magical wood that no one can find. This is really good work Derek, I'm looking forward to watching your masts and yards progress. I have to figure this out for Cheerful, I better start slicing some wood for practice.
- 725 replies
- vanguard models
- speedy
I built this model and know about the stern first hand. Pinning the wet/steamed wood may result in warping as/ after it dries. The method I use as I learned from Chuck doesn’t require soaking or steaming thus no warping. But if you think it’s just tapering then ok.
- 108 replies
- armed virginia sloop
- model shipways
I’ve used pear on the inner bulwarks of several of my models including Pegasus which has cherry above the Wales and on my Fair American which is mostly cherry. So far for me the cherry after 5-7 year takes on a definite sweet color, but the pear looks essentially the same (not that’s at all bad, it’s pretty wood). I was using Swiss Pear from good ole Jeff, that may be different than your pear. Either way that’s one nice looking hull, you’ve always been one of my inspirations for me to ‘do better.’
- 642 replies
- winchelsea
- Syren Ship Model Company
Those are the longest skinny cannons I’ve ever seen 😂🤣 Your hull looks great. Not sure what to offer on the painting. The Tamiya tape is usually the answer. I have a tool I use (hard curved metal end) to run along the edge to ensure a really tight seal. I’ve had the poly underneath the tape and not had a problem. At any rate you recovered nicely. Nothing stands out worse on a model more than bad paint lines, sure don’t see any now.
- 725 replies
- vanguard models
- speedy
- 108 replies
- model shipways
In addition to Ryland’s comments: Are you soaking the planks, hard to see but looks some of the warping may be due to too much soaking, or perhaps your fairing is off. Your tapering also seems, by this point there should be much more taper there by that point. The link Ryland provided addresses both issues. You can make up a lot with sanding and filler on the first planking, but as you said you want the first planking to be practice for the second.
- 108 replies
- model shipways
It takes only a small dab of CA in the center of each tile, and it’s definitely a CA job. Like Chris I keep as many together I can 3-5 wasn’t unusual. The overlap stands out to you as your doing it, but you won’t notice it all once it’s on the shelf. I’m on record, I do not like to copper. It’s way too much like work:-/
I have Cheerful, the masts and yards are square stock. I think I may be doing it next, not sure yet. Chris coming out in July with Flirt Master Shipwright version gives me pause starting Speedy. I saw the Ibex site - there were so many versions and blade size no idea where to start. https://www.metmusic.com/tools/ibex-planes/ I'll go for the one on your link - but what blade size. I'm really a novice planer, I may slice my thumb off.
I'm going to get some experience with square stock with Cheerful. So when you say planing jig...? I get the squaring off verses rounding off, but as I'm not interested in owning a lathe I'd be interested to hear more and maybe a photo of your jig. I can probably sort it out with my handy DeWalt battery powered drill, I'm all for seeing how the experts do it and any way that would make it more precise than turning my drill with sandpaper and files in hand. Your dioramas are amazing, I thought you were showing me a painting..l.
