Everything posted by archjofo
@giampieroricci That's really a very nice compliment. Thank you for it. I also admire your wonderful models. It is always a pleasure to see that there is still interest in my report because of the many LIKES. I am pleased. After a little excursion to the anchors i continue with the shrouds for the mizzen mast. So in the first step the lower shrouds were aligned. Afterwards I start with securing the lanyards.
@Ainars Apalais @Jorge Diaz O Hello, thanks a lot for the nice words and all the others for the many LIKES After a short break I am about to put the smaller anchors with the iron stocks on the anchor bearings. The larger one was used as a reserve anchor; the smaller one was used as a throwing anchor or warp anchor. Contrary to the drawing by J. Boudriot I decided to place these anchors according to the Paris model. So these anchors are placed on the port side. Soon we will probably continue with the ratlines at foremast and cross mast. To be continued ...
After finishing the futtock shrouds for the main mast I need some motivational work in between. Therefore I prepare the fixing of the anchors, which were stowed away in front of the channels of the main mast. But the wooden anchor stocks made many years ago no longer meet my expectations. Therefore, they have been rebuilt as in the original. The hoops are made of brass sheet 0.3 mm, no longer of black paper. The anchor ring had to be equipped with puddening and seizing. I decided to use the Petrejus version, which can be seen on many contemporary models of the Musee de la Marine. Source: E.W. Petrejus „Das Modell der Brigg Irene“ Source: Manuel Du Gabier, 1866
@Bluto 1790 Hello, Jim, the keel aying of the original La Créole was done in 1827. In 1829 she was equipped and put into service in 1830. I hope that the information in J. Boudriot's monograph on La Créole, in conjunction with my research, led to mostly correct details. Thanks for the commendation. @Gahm Hello Thomas, I also want to thank you for your compliment.
Hello Gregor, excellent detail work . I am very interested in the rigging work.
- 121 replies
- la jacinthe
- schooner
As can be seen in the Parisian model of La Créole, Petrejus' "The Model of the Brig Irene" shows that the futtock shrouds, coming from above, run upwards around the lower shrouds and downwards again in front of the futtock shrouds. In La Créole, the ends of the futtock shrouds run over three ratlines and are fastened with three tapes. It is also interesting that the ratlines in this area are under the futtock shrouds. Source: E.W. Petrejus "The Model of Brig Irene" p. 192 At first sight one could assume a mistake of the model maker. However, after extensive research I can state for myself that obviously both types of design must have existed here, at least continental. Therefore I orientate myself also with this detail at the Paris model. In connection with the catharpins, the futtock shrouds were placed alternately on both sides and only attached as an aid to make corrections.
Roter Löwe 1597 by Ondras71
archjofo replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Fantastic work ! -
Hi Karl, congratulation for this topmodel!
- 87 replies
- royal caroline
- yacht
Today I came across this building report by chance. Since I myself am very interested in French shipbuilding, I am very pleased to see such a beautifully built hull from the Le Cerf. In the meantime I have also looked at several of your models and admire your skills. Therefore I am sure that the Le Cerf will be a wonderful model.
