MrBlueJacket
Everything posted by MrBlueJacket
  1. I know our kit does not show this. In general, sheaves were put in topmasts so a line could run from the mastcap thru the sheave and back up to a block on the mastcap. This line would let you lift the topmast so you could take out the fid and hence lower the topmast.
  2. Moving to the stern, it is time to add the mahogany bench seats that ring the aft end. Next will be adding the bulwarks to them.
  3. So with the pilot house sides filled and primed, I decided to add door outlines. Using .010" x .100" styrene, I think they look pretty good. I left space at the bottom for a 1/4" step
  4. I'm going to put windows in, since it won't be burning the boiler. I decided on inner frames to make a lip for the acetate to sit up against. Here's a shot of the inside and outside. And of course, more putty and filling.
  5. After three coats of primer and filler, the hull is painted. Next comes the waterline and dark green paint.
  6. So while I'm filling, sanding, priming (repeat several times) on the hull, I decided to start on the deckhouse/pilot house. Here are the two sides being assembled. Back in the day the parts were band-sawed, so at least one side of the windows had to be open.
  7. So during this past week, I have painted and installed all the deck furniture, lined the cockpit well, and started on the masting. Really taking shape now.
  8. After installing the gratings, deadeyes and fife rails, I put some of the other deck furniture on to see how it looks.
  9. The solid railing is on, and mis-matches of the seam are covered with Bondo. The false machinery well is installed and painted, along with two steps down from the pilot house area.
  10. And of course, with the coppering finished, it is time to hang the rudder. I used thin strips of Britannia metal, and pinned the rudder in two places.
  11. During the past week, I have put on the caprails, installed the bowsprit, Sampson post and winch assembly, and drilled holes for the masts and fife rails.
  12. And just to take a little break from the copper, let's put in the timberheads! Then we'll sand them flush to the bulwarks and add the caprail. Almost getting to where I really like the build - adding deck furniture and masting and rigging. I consider the hull a necessary evil to get to the fun stuff. Oh, and did I say, our client wants sails? We'll do those from silkspan. Stay tuned......
