I foregot to mention, I have also been battling with a fiddly little thing in the shape of an extinguisher frame to support Two bottles, these need to be built up using the two sides first and held in place by a cross pole, would it stay in place and glue - not a chance, it kept falling away, anyway after about Ten Million tries I eventualy got it to stick enough to attach the top handle and bottom section. I then left it well alone to set. OC.
Evening all, a small amount of poregress - I have built the ammu bench, its designed I assume to put the ammunition onto belts ready to be fed into the wings in Spits and under the belly in Mossie fighter/bombers, so I have decided to pack it in the trailor as it been kept there while the crew have been dropped off. OC.
I always thought the Mighty Hood looks great as a waterline model due to her unique shape and freeboard on her rear deck (constantly wet) she has that slim lined look also makes her look really elegant but also deadly. OC.
Evening all, more progress this eve, first I found some thin grey-ish wire I cut it into lengths that seemed about right, then I drilled a small hole in the end, then I pushed it over a plastic pole protruding from the front part of the starter, then I coiled it around the handle and added a touch of ca to hold it in place. Next I assembled the oil bowser tank, after painting I did the same with the hose as I did the wiring earlier, this time I coiled it round and looped it around the drum of the bowser and connected it to the feed assembly. So here is a family photo showing all the bits done so far. OC.
Hope all works out for you mate, fingers crossed it will. OC.
- 436 replies
- vanguard models
- alert
