Old Collingwood
  1. Evening all, more progress this eve, first I found some thin grey-ish wire I cut it into lengths that seemed about right, then I drilled a small hole in the end, then I pushed it over a plastic pole protruding from the front part of the starter, then I coiled it around the handle and added a touch of ca to hold it in place. Next I assembled the oil bowser tank, after painting I did the same with the hose as I did the wiring earlier, this time I coiled it round and looped it around the drum of the bowser and connected it to the feed assembly. So here is a family photo showing all the bits done so far. OC.
  2. Evening all, another item was made earlier in the shape of a ground power unit - basically a power transformer in a box with a handle on wheels, I still have to come up with the power lead - this I will make from some 5amp black wire. Next up will be a oil tank. OC.
  3. Afternoon all, after more progress with the tractor - now we have Two vehicles finished. OC.
  4. Better then to mask off the (Painted wings) and not have to mask the polished fuse. OC.
  5. If you can - do the wings first in the paint finish you want - then concentrate on your magic on the fuselage after, will be easier to mask the wings to then do your metal work than the other way round - just my 10 pence worth. OC.
  6. It reminds me of the old (80-90s) American Airlines polished metal scheme (used to love that scheme on MD11's. OC.
  7. She looks great Denis - credit to you for keep going and overcoming some of the hick ups you had, she really looks the part now. OC.
  8. Evening all, I managed to get a bit more work done on the tractor, I am basically making it look quite bashed up dirty with lots of use, as I asume they would be. OC.
  9. I agree also it looks really good, I think what might be distracting away from the fine finish is not having the rest of the plane completed - then it will really shine through and look mighty impressive. Your doing a fine job bro.👍 OC.
  10. I have owned two french cars a Megane and a Citroen ZX, both quite decent cars. OC.
  11. Thought I should mention that at 1/48 scale these things including the jeep are actually quite small, the jeep is about 2 - 3 inches long, and my pics are quite close up showing more than 1/1 scale. OC.
  12. "Hey brother" - I'm liking that, I so get where you are going with this it will look Stunning. OC.
  13. There a faded grey/black but deffinatley more towards a black side than the RAF Blue - the light (strong from above) probably didn't help. OC.
  14. More progress this evening - first I bashed up the Jeep with washes and high lighting, then I painted and added "Red" the setter, she jumped up on the jeep and is sitting on the rear seat waging her tail, excited by all the activity. Next I continued with the tractor adding more washes and building the engine that was then fitted in place. Pic shows the dry fitting of the engine cover. OC.
  15. Hi mate, yep I have a bit more weathering to do to it yet - but not too much my dad used to tell me "if its still - paint it - if it moves still paint it". OC.
