Old Collingwood
  1. Thank you for the help all - really appreciate it your intervention stopped me from binning it, I decided to attack the black first - I thought I had brought the eqv tin acrylic as the Tamiya rattle can, so I used my softest/widest brush watered the paint very sightly with distilled water (just a few brush drops into the tin) then proceeded to apply some thin layers all over the black - wide brush with thin layers dried between each seems to have helped a bit. On the side where the scratches was under the cockpit that still needs a little light sanding - I will attempt that tomorrow when the paint has fully hardened. Here is a pic showing the better of the two sides after the touch up. OC.
  2. Thanks Craig, here are the pics - not sure about the best option for touching up the paintwork as I dont want to have to re mask the areas so I can spray the affected areas, I could de cant some paint out of the sprays into a small glass by spraying a liitle - then brush over the areas but as thin as possible (not sure if the difference will show between spraying and hand brushing) I have some 800 wet and dry - some well used pieces that I could try but have nothing finer. Here's the pics - OC.
  3. Right - I got the chance to lay another coat of Green over the wing and fuselage, then let them dry aided by the hairdryer - I then put them aside to harden, I also put a coat of primer on the other wing and stabs. Then this afternoon I decided it was time to remove the tape and reveal my paint work - Not good I am not happy, contribution of factors lack of man shed or building area, wrong tape (I should have invested correctly by getting Tamiya Tape) Also using Tamiya rattle cans out doors in between rain showers and wind and bugs - is not ideal as I had to very quickly throw the paint down to beat the elements. The finish has left a couple of areas of miss match paint - some scratches and a hard ridge where the black/camo demarcation line is. Seriously dont want to have to paint my other kits this way as its just not the way to go.😞 OC.
  4. My next project should be a fly carrying truck - but guess there will be enough room for nats and midges as well. OC.
  5. He's long gone now - spray day number two latter today with any luck - just need those rain gods to have a day off and no wind - also no flying things please. OC.
  6. Yep I said #########$$$$$$$$$.........Out of hear your history. OC.
  7. I just took some pics showing the painted parts in the box and the box. OC.
  8. Hi all, so when I spoke last I was waiting on good weather so i could get out and do some spraying - its that frustrating time as I had some chores to do first then our twice weekly shopping deliveries to the house, then I got the time to step out the back to try some spraying - "Rain" not heavy just that drizzly stuff, but I had nothing else on mossie to do till this painting was done, I kept my eye on the weather till later in the afternoon I spotted a dryer spell but with a little bit of wind - so I went for it, I have one of those 12 inch long plastic storage boxes with a hinged lid, I took the parts with me in it - got out the wing first and sprayed the Green - It went down very well until I noticed a flying thing nat or something had landed on the wet paint, I put this in the box and did the same to the main fuselage - that went down the same but with no thing's stuck to it, I put them both in the box closed the lid and was able to take them in the house without a worry over paint fumes. Later after a couple of hours I was able to inspect the damage off the insect - I was able to scrape it gently off - but it will need a small section of primer then another coat all over the Green areas - the fuselage will get a second coat of green also as I did the same with the Grey. No pics though. OC.
  9. Looking smart now she is attached to terra firma. OC.
  10. If the weather is good tomorrow I will prime the tail planes/right wing/spinners and do a couple of coats of Green on the masked areas, then I will pop them in a box with a lid to let the smell go off a bit before taking them indoors. OC.
  11. This is a walk down memory lane for me as I built this kit when I was about 10, I t will be interesting to see what you do with it. OC.
  12. Right I had a go at the spinners just by using a sanding stick and working around towards the tip. OC.
  13. They are the right circumference just not quite pointed enough they are kind of like a ball shape. OC.
  14. Question - any ideas how I can make my prop spinners more pointy and less rounded, as the kit ones do not form enough of a point. OC.
  15. Masked up ready for primer, also a little scribing of panel lines I also drilled to make a couple of additional vents below the exhaust manifolds (that reminds me they need masking). OC.
  16. Sorry to hear that craig - but well recovered she is looking superb. OC.
  17. Thank you kindly Mark, forgot to say I have also been working on some of the panel lines. OC.
  18. Thank you craig, I understand the Revell Mossie kit is renowned for being a bit of a pig to fit in some areas namely the Engine/undercarriage nacelles, and at the same time the joins with a little care are bang on. OC
  19. Small tip - when your parcel arrives from china - sanitize it - just in case. OC.
  20. HI all, I had a battle on today - trying to manipulate the engine/undercarriage nacelle to fit the wing (its a notorious bad fit) I had to dry fit - dry fit - dry fit etc etc etc and file/sand away till I managed to get it to fit requiring just the smallest amount of filling. Firstly I glued the front end and aided by the hairdryer and some gentle pressure it glued down, then I pushed down the back end and secured with a seam of fine glue. The idea with the hairdryer is to make the glue mimick a heat gun by where the glue sets quicker by being hot, and cools quickly as set. OC.
  21. Count me in - I too have done some Armour in the past from 1/72 diorama's to Tamiya 1/35 scale tanks etc. OC.
