Good Evening all, can I get a bit of advice from folks please - I am struggling with the gammoning rope trying to get a neat inline pattern, I have to run the rope (thread) up from the cutout in the beakhead then up through a slot in the grating and over the bowsprit, I have fitted a block on the top of the bowsprit but I can stop the thread from getting all bunched up and not in a nice clean line. Are there any cheats to make this (stressful job) easier? OC.
Its a fictious ship but im building it just as the wife wants it - as it is in the films, (makes it a lot easier for me that way)😉 OC.
Its just the way the film designers built the ship probably desined around the May Pole dance. OC.
Sounds and looks complicated. OC.
- 331 replies
- nuestra senora del pilar
- occre
Really impressive work on the masts - how do you hide the ends of your mast rope wrap arounds? OC.
- 331 replies
- occre
Evening all, I continued with the forecastle bits - they were painted then weathered, I then got my instructions off the admiral that she wanted the capstan to have its spindles - so hey presto I made it so - painted and weathered. After letting the capstan dry I turned my attention back to the forecastle - it ocured to me that the inner railing was missing some belaying pins, I have some metal ones so I had to drill out the rail between posts then glue in the pins with some gaitor glue. Just a couple of pics -
She is looking superb mate - so much fine work. OC.
- 467 replies
- mikasa
- wave models
Evening all, only a lttle bit of work today on the pearl - firstly I built/painted and weathered the capstan then glued it down, then I started work on the kit forecastle bits, the kit part is a complete piece - all it needed was a bit of cleaning up then a piece of decking was placed underneath to help its attachment to the deck. Just the two pics - OC.
Hiya mate, yep slightly darker but deffo showing some weathering, its a very enjoyable build and the scale 1/72 really helps - I used to make 1/72 scale Airfix toy soldiers - you know the ones that were that horrible slimmy plastic (real hard to paint) I at one stage had hundreads of then including the Battle of Waterloo battle set - had then all over the room floor ( mum was not impresed) OC.
Oh - I foregot to mention - the upper sides are not glued on yet, just dry fitted to test weathering and fit. OC.
Evening all so today was "weathering/shading day" - I gave the hull and upper hull parts a series of dry brush white passes, basically just white acrylic with a large brush with almost all of tha paint taken off the brush with a rag, than brushed all over raising the highlights and creating some age. Here's the pics - OC.
Evening all, today I fitted the two forecastle ladders then gave them a coat of paint, I then decided to close in the lower/main gun deck hull sides, this was a fiddly operation requiring some moving around of the side sectons to get them to sit properly, this caused a bit of poly cement mess around the join. After the first side was glued and supported with elastc bands - I was able to attach the other side, I set the hull aside to set while I cooked dinner - then I touched up hull join line, but also decided to give all hull parts a second coat - that to be honest is a more brown/grey/black color, but it will be weathered again with dry brushing (can use talk as the wife has allergies to stuff like that) Just the one pic - OC.
Evening all, I thought I would do some work to the rear bulkhead decorations - these are kit parts but they do look amazing for plastic, anyway first thing I did was to paint the three sections in brass paint - this was force dried with a hairdryer, then I started weathering and generally making them look aged and old, I then glued them to the rear bulkhead. Just the two pictures, with the second one showing how it will look when I attach the rear cabin window sections. OC.
Evening all, another good day on the pearl today - I started work on the wheel and assembly, the kit version is good shape and all I needed to do was to shape the frame work, after doing this I gave it a couple of coats of paint then weathered it slightly, then I attached the wheel to rudder rope - this was wrapped around the spindle then secured with pva with both ends weighted down to keep it in place. Then I attached an anchor point underneath the deck with a piece of 1x1mm, then I pused the rope ends through the grating and glued the wheel assembly in place, when set I will secure the ropes around the anchor point. OC.
