Really nice clean detailed work a delight to watch. OC.
- 527 replies
- caldercraft
- victory
Hi all, I managed to get outside and cut out the base board, then after sanding the edges I glued the sub - base down onto it using PVA and spring clips, I set this aside to set - While it was setting I turned my attention to the gun port lids and anchor points, the lids are opened/closed by a two point rope attachment on the lid creating a v shape with a rope coming down and attached to a spar sticking out of the hull above the port, a rope routes through the hull over the spars rounded end and down to the v shape rope link on the lid. First I drilled into the hull to accomodate the spar made from 2 x 2mm timber, this was cut longer than needed as the end would be glued and pushed through the hole drilled in the hull, on the ends I cut and glued a small piece of 2 x 2mm, then when set I rounded the ends, next I glued a section of rope on the top and secured it over the rounded edge. I finished off by gluing two of these (port and starboard) into thier positions. A few pics .... OC.
Hi jason, thank you for the comments - the windows were un-diluted PVA the gorilla branded version. OC.
Just a short note to say how overwhelmed I was with all the warm wishes that I duly passed on to the admiral. Tomorrow I will be cutting to shape the main base then glueing down the sub - base to it. Once gain a Huge Thank You. OC.
Last job of the day was the shaping/painting and securing of the three rear transom/poop deck supports. OC.
Next was to work on a sub section of the base I am building - first I cut to size a piece of thin ply, this is acting as a pre - anchor for the pearl then onto a more substantial base I have yet to cut (both offcuts of wood knocking around the house). I constructed four braces that were measured around the plastic kit frame supports, then glued down, I then set this aside to fix - then later I glued the pearl down onto the sub base. OC.
Managed some work on the pearl today - I finished putting the main masts - lower sections together, I then cleaned up the seems on them then dry fitted them on the respective decks - they still need painting. OC.
Thanks mate I know what you mean. We should resort back to our old navies a lovely diet of old meat. weevil biscuits and rum - I could live off the rum though. OC.
I can only back up what denis said - very nice work bob. OC.
- 359 replies
- prince de neufchatel
- model shipways
Any way! back on with my build - tomorrow I hope to trim the two breech ropes glued but hanging from the hulls side, then I will work out my next stage in her build stratergy. Sincerely thank you to all the replies and words of thought and care - it means a lot from my family of ship builders. OC.
Thanks ken, the trouble is - it costs extra money to eat healthily, my wife has always said here in the UK its always the poor who are the least fit and well, thankfully we have a mostly chicken and frozen or tinned vegetables, and try to get greens when we can, both of us have zero sugar or fats like butter or sandwhich spreads, same with milk we only take concentrated milk - never full fat. We should be as healthy as a sportsperson lol. OC.
