I hope your are keeping up mate - I will need a crew soon hope your ship shape my hearty...... OC.
Evening all, thank you all sincerely for all the likes and replies, today I had a break from the canon building and started work on the catheads, in the kit these are plastic and attach to the outside of the hull, but I decided to make them from wood stock 2 x 2mm, these sit on the deck of the forecastle deck and protrude through the railngs there, first I had to file away a square cut out in the hull using my box file, I kept testing with the timber till I got a flat cut out. Then I cut the timber to length and drilled two holes in the end for the anchor support ropes. Here's the pics - OC.
Excellent - you could almost do an "Under Siege" scene with the baddies arriving by chopper. OC.
I used (later stages anyway) gaitor PVA glue, I applied a small amont with a thin dowel or sharpened tooth pick to the area, then placed the part with tweezers and moved into place using a small dowel/tooth pick type thing. OC.
- 140 replies
- the sullivans
- trumpeter
It deffinatley helps to heat up the enamel paint to force dry it, I used to work for a cycle manufacturer and when we painted the frames with enamel paint it was (in effect) backed on with heat on a slow moving track with heaters either side blasting hot air at them - hence why I use a hairdryer on full and hot setting. OC.
I painted enamel (humrol) on all my brass effect parts, and just forced dryed them with a hairdryer then did acrylic washes over it and dry brushed highlighting again with acrylic - straight after the enamel, with no lifting or reacting of the different mediums. OC.
Hi all, not much to report really - I have duly started on the rest of the canons, so four more have been made prior to painting and weathering. OC.
So job for tomorrow (must keep the momentum going its for the wife) do I make and install the ten canons on the top deck, or continue with the lower gun deck port covers and ropes (as these are being closed) Decisions - decisions. OC.
I had a few of those days as a kid trying to build and paint my first models - my late farther was less than understanding though, normally got a right back hand for it. OC.
- 122 replies
- tamiya
- King George V
Thank you sincerely, I am trying to make her as ghost like as possible (for the wife) OC.
Would love to get this kit in the future and build her as the Flying Dutchman - Pic curtosy of the net. OC.
- 106 replies
- deagostini
- finished
Evening all, thank you again for all the likes and comments - like everyone else it really inspires ones building, so last time I had assembled the wicked wench, it was now time to weather her same as I had done with the other brass bits - first I applied a coat of enamel brass, this was force dried then I used a diluted black and brushed that over into all the nucks and crevices, again force dried that last I applied a dry brush of white to highlight and age the lady. Here are the pics including her fixed in place. OC.
Hang on! was the Airfix 1/24 the huge one with that sliding canopy? if so thats the one I ment when I was young my late farther took me to my first airshow and there was a Harrier GR1 flying there, he then took me to a model shop and treated me to the Airfix kit and duly did most of the building of it as I was about 8 then. OC.
Welcome back mate - now she is looking the business, really sharp details and very tidy paintwork. OC.
Good day all, abit more progress today - I have been working on the two main deck port covers, I cut the two covers from the fret, then fed the rope through and glued the ends at the back, when set I trimmed the ends then glued it to the openings on the hull, after it had set I as able to tie a knot where the two sections of rope meet, after adding a blob of pva and heated with the dryer - I then trimmed the end. I then painted and weathered the lid/bracket/rope. Then it was the turn of the other side - same procedure, but this time I have left the port lid slightly open, the ropes have been attached in the same manner - just waiting to tie them. I have also neen lucky enough to get a replacement figurehead (the good lady wicked wench herself) I have joined the two halves together and cleaned her up slightly - just waiting on some brass paint and weathering the same as I have done to the rest of the brasswork. A few pics - OC.
