Thanks mate, yep its not always easy to make a round smooth object detailed and interesting, but I will give it a go. OC.
- 229 replies
- trafalger class
- airfix
Hiya mate, I will continue to buile up the base color first and attack the bow area where there is a gap, then I will look at simulating some tiles with tape masks. "note to self - look on flee bay for that flast coay rattle can carl mentioned" OC.
- 229 replies
- trafalger class
- airfix
Right I decided to attack the sub (no pun intended) by closing up the hull, this was quite a tidy job but needs a bit of filling near the bow, any way I also put the two halves of the sail together, then glued this to the hull, when set I lightly sanded the hull to create a key, but also masked off the top section, then I started to apply the first few brush coats of dark navy grey. It will need quite a few coats (all thin coats) to build up a smooth finish. Here are a few pics. OC.
- 229 replies
- trafalger class
- airfix
That is some service beneath the waves, I spent a day at Dolphin in 81 school work experience based at Collingwood for the week, facinating experience taht led me into applying to be a WEM the year after (didn't make the grade though). OC.
- 229 replies
- trafalger class
- airfix
This sounds interesting lou, would love to follow this build. OC.
- 1,090 replies
- showcase models
- vendetta
Not pinching my goodies I have stealth (im invisible) OC.
- 1,090 replies
- showcase models
- vendetta
Great photo kevin isnt that the boat you was stationed on/in? OC.
- 229 replies
- trafalger class
- airfix
Some other T boats appear not to have the channels on both sides, just want to work out if I can paint them in the same dark greay color as the tiles. OC.
- 229 replies
- trafalger class
- airfix
Change of plan for my next stage as I am not happy with the finish so far - I decided I will join the bottom and close the hull, and possibly construct the sail and fit it, then I will be able to work on the join seam and sand as needed, then I will mask to where the generic waterline would be be and give below it a few fresh coats of paint by hand as I dont have a sprayer. The sail will give me something to hold onto while hand painting and the masking will help with even brush strokes, then I will polish with soapy water and a sponge as before to smooth out any brush marks (well thats the idea) OC.
- 229 replies
- trafalger class
- airfix
Im not sure about replicating the tiles and missing ones, I might be able to tape up a few bit by bit. OC.
- 229 replies
- trafalger class
- airfix
Its all in the finger control and the telescopes we use OC.
- 1,090 replies
- showcase models
- vendetta
I have this pic (again not one of mine) It shows more detail including the pattern on the sides that is completely without any tiles - but looks intended that way. OC.
- 229 replies
- trafalger class
- airfix
Thanks kevin, wonder if that is red oxide paint they paint where the tiles are missing - cant imagine it being rust, also what are this two zig zag panels where there are no tiles on Trafalgar. OC.
- 229 replies
- trafalger class
- airfix
I will have to look on flee bay for that rattle can It will be real useful for my sub. OC.
- 1,090 replies
- showcase models
- vendetta
A little more progress just picking out some deck details with my brush(its easier to do this while the hull is still in two halves) as Lou said its brings the details out on what would be just a cigar. OC.
- 229 replies
- trafalger class
- airfix
Thanks lou, I thought the same as subs do tend to be slightly detail shy, she has a few bits and pieces to go on her yet. OC.
- 229 replies
- trafalger class
- airfix
What matt top coat medium will you be using - your own sprayer or rattle can? I am interested as I will be seeking to do a flat top coat on mt sub when its all finnished. OC.
- 1,090 replies
- showcase models
- vendetta
Perfect job carl - the depth markings look spot on and the paintwork so nice and tidy. OC.
- 1,090 replies
- showcase models
- vendetta
