Now that will be nice to see - cant wait to see you start it OC.
- 75 replies
- scharnhorst
- dragon
Yep do it please, I for one would be very interested in following you , and I know the other good folk on here would do the same OC
- 75 replies
- scharnhorst
- dragon
Just a quick update of what i will be tacling next when I can get past all this house painting, well I will be working on the boat deck, I had al;ready thined down the profile of the boat stands, and next will be some detail work on the fittings on the deck area where the boats sit - First off will be to construct roofs for the larger engine room vents-two of these, next will be two smaller vent roofs and details that will be made with some plastic/wood sheet, next I will move the two amo cuboards as they should be more shared between the thwo Pom poms on both sides, the small ladders will also be filed off, along with some extensions to the armour around the most forward Pom pom stations, including the ends being turned in 90deg. Here is a pic showing the un altered deck with shaded areas to show what i will be doing(the original boat stands on the pic do not show what I have done). OC.
Hi there - another plastic builder like myself and a few others here, Great Stuff OC
- 75 replies
- scharnhorst
- dragon
Totally Superb greg, your eye for detail Blows me away :o I am sure I am not the only one who holds his breath with building at such scales, but when you achieve what you do - The sense of pride is Huge. OC.
- 342 replies
- dreadnought
- zvezda
Only asked greg as on my warspite build the original plastic decks had raised planks - you could feel the detail with your fingers, thats why i decided to give the laminate planking a good flat keyed area to stick to. OC.
- 342 replies
- dreadnought
- zvezda
Did you file off the original platic deck boards first before laying the wood laminate? OC.
- 342 replies
- dreadnought
- zvezda
Looking Great mate - the detail really stands out, Im so missing doing mine as she is packed away upstairs while I'm decorating the house OC.
- 342 replies
- dreadnought
- zvezda
Finaly for today anf possibly a few days due to decorating, I decided to have a go at the screws, I have gone with the kit ones as they look quite good, I tydied them up a bit then gave them a coat of paint while off the shafts, then dried them with the normal hairdryer and glued them in place. OC.
I also attached the breakwaters to the 6Inch mounting deck, this was done with a light application of PVA then painted. OC.
Right folks here are a few pics showing the prop shafts and the paravane mounting after I drilled out the holes for the linkages. OC.
I will take some tomorrow I promiss i will then have to pack her away for a few days possibly a week as the room needs decorating and I need to get it done before playing with my toys OC
Just a quick update folks - I finnished off fitting all four prop shafts, then touched up the colour then added a couple of coats of top coat to blend it all in, then after finding out what the block on the bottom bow was for thanks to folks on here, I drilled out the two small holes taht would have had chains attached. I then returned to the 6 inch gun shelf and sorted out the port and starboard waterbreaks, these had to be cut from the etch sheet then the bottoms of these needed bending 90 deg's to act as a ledge, I then sat them a small amount of watered PVA then when dry painted them as they should be. Next will be two ladders leading down to the 6inch battery ledge from the Forecastle deck. OC.
Looking great greg, really tidy detail work and clean paintwork OC.
- 342 replies
- dreadnought
- zvezda
Hiya, thanks so mutch for finding that out - I had wondered for the past year what it was for, I kind of stupidly thought it might have been somekind of counter weight or something. OC.
I started on the Rudders and Prop Shafts, I needed to do a bit of studying to see which shaft is which, but after looking at the instructions and dry fitting - it all came clear, I fitted the rudders first just a slight bit of drilling out for the rudder arms, then I glued them in place, next was the shafts, afterwards I touched up the paint around them. I also fitted the bow bottom fitting (A counter weight)? not sure of its purpose. Here are a few pics folks - OC.
An update folks - with pics I carried on layering the top coat on the hull, and decided to dry fit the deck parts for a bit of a photo shoot. OC.
Like I said to the wife - its should be like a metal version of a painted surface - although mat in colour still smooth metal. OC
- 342 replies
- dreadnought
- zvezda
Just a bit of lightning with almost like a artists powder white - just to catch the high points and details, but if you are like me I want my hull red around a dull satin colour, best achieved by buffing a mat sheen I think, , thats my approach with my hull and I would think yours is not far off that. OC
- 342 replies
- dreadnought
- zvezda
