Spent a bit more time on the table today - preparing a couple of the rear deck boats, next i decided to start the mind numbing job of removing the pre moulded deck detail in preperation for the forward section of wood decking, this was slow and careful work wife a fine knife blade and small file, afterwards i started on the decking sheet cutting out the obstructions with a sharp blade. I finished off by dry fitting both deck sections with the dry fitted wood deck sheet with its backing still attached. Here is a couple of pics just to show how it is shaping up. OC.
This is gonna be very interesting my friend OC
- 342 replies
- dreadnought
- zvezda
Have you seen the Film Battleship? it show cases the Mighty Mo in great detail, Love that film. OC.
- 187 replies
- new jersey
- trumpeter
Looking Fantastic Hank - just shows how slowly slowly does the trick, if you are like me I do a little bit then put it down till I kind of get the urge to do more, my Warspite will probably take about 5 years to build at my pace. OC.
- 187 replies
- new jersey
- trumpeter
More work today finishing off the Rear Block by adding the Derricks, and the two small buildings that where glued down on the deck area, I then fixed the block down to the deck. Heres two pics showing the completed work on the deck secion so far. OC.
Looking Superb Greg, it just goes to show - that the camera never lies and has a habbit of showing up every detail, your close work passes the test with flying colours my friend OC.
I dug deep inside my work bag today and found the box from the kit, I was looking for a couple of frets to add some more stuff, I found the hull sitting at the bottom so I decided to do a dry run with the mid deck section, and the rear block i am finishing off, I put them together with the other deck sections. Hers a pic. OC.
I have nealy completed the rear block except for the mast, i added the two derricks and touched up a few areas of paintwork. Here are a few photos of the progress - OC.
Just a quick look at what i had done by fixing the rail down in a small puddle of slightly watered down PVA, and its stuck nicely, i will do the same for the other side then touch up as needed - i can relese my breath now onlt been holding for about 4 days lol. OC
It looks good on the fret and is easy to paint etc - tillI have to take any off it off Cant I just leave it on the fret please folks .....? OC
I was affraid to use CA as the type i have is the brush on variety with the brush attached to the cap that screws into the bottle, i was going to try applying a small bit from the brush to the bottom edge of the railing before placing it, but i worried that if I missed it would attach itself somewhere else and cause all sorts of trouble OC
Its Slowwwwwwwwwwwwwwwwwwww Progress this PE work, it wasn't till today that I had a peak at the single tiny section of railing, i gently peeled away the low tack tape that was holding in place while the PVA glue was setting but - Shock Horror it started to loosen the rail from the deck. So onto plan B or is it Z? i decided to sit the rail in a puddle of PVA that i had proffesionly added to the deck my way of my paint brush tip - lets see if that sticks the little blighter I worked out at this stage - I will be a bout 90 when i finnish the Ole Lady and I'm only 10 now OC
I did a few limbering up exersises then took some deep breaths and dived in head first into my PE railings to go on the rear block, i cut them from the fret under my mag glass stand, then offered the one side up, but found it was to long - so a small section was cut away, i then gently bent the end that wraps around the face of the rear block. I placed some blue tape along the edge to grip the rail then applied a watery PVA seam with a fine brush (while holding my breath-and bitting my lip), but it stayed in place so i gently took a couple of pics - then put it away to let it set fingers crossed Heres the pics
Two pics showing the brass etch that I have painted twice and added a coat of varnish to the stairs and hand rails, I will leave these for a good few days to harden fully before attempting the interesting part of fitting with shaky hands - OC
Thanks for that greg, i am using the Lifecolour Acrylics and they do seem to dry very tough also with the acrylic varnish, i am hoping this will be both flexible and tough? OC
Managed to get an hour or two on the table today - i decided to paint the brass fret details - rails ladders etc, the idea is add the top coat laquar when the paint has dried so hopefully the paint wont crack or come away when i fit the individual pieces? OC
THe true sign of a model making genious is when it can sail through the scrutinizing view that a camera shows worts and all, Fantastic Work Greg. OC
Makes one wonder - with all those hammock nets etc creating almost a solid section, with Turners Trafalger pic where he showed solid Bulwarks on the forecastle, could he have mistaken the hammock nets for them? OC
Incredible - I take my hat off to you and watch in ore open mouthed and think - i will never be able to do stuff like that to my Warpy..... :o OC
Really interested for obvious reasons - keep up the great work its looking very nice. OC.
- 22 replies
- kirk
- orange hobby
(and 4 more)
Thanks mate - yep its coming on i think bits and pieces slowly does it rome and all that lol, i painted a bit of etch on the fret giving it about a year to dry before i handle it(dont want that pesky paint rubbing-peeling orf) OC
