Old Collingwood
  1. Evening all, more progress starting to fit the vision blocks in the different areas on the roof, in the super detail set are self sticky block covers that are translucent and look excellent if a little fiddly to fit. OC.
  2. Just to back up what everyone else has said - good to see you back on this - this time I know you will do a Fab job if it. OC.
  3. Evening all, some more progress today carrying on with the turret details, when I brought it I also got the Update sets for it, so I have been diving into them improving some of the details - plenty of resin and PE bits and pieces going on. OC.
  4. Evening all, more work after having a day off - I have been populating the top of the turret, I started with the main sight its comes as a unit with a few parts including the clear styrene, again to shade this I painted the rear of the clear with a few coats of Red, then fitted the doors, the top/doors is just dry fitted until I mask up the glass area. I have also been adding some other fittings to it. OC.
  5. Thank uou Denis, indeed sir - looking forward to that bit. OC.
  6. Thank you kindly it’s a great kit for making my job easier. OC
  7. And I have added a wire antenna to the drivers radio I had to drill a small hole in the top of the radio. OC.
  8. Evening all more progress I have closed up the turret and cleaned up the edges Next will be all the fittings. OC
  9. Thank you kindly mate little screen keys and big fingers fun lol OC
  10. Evening all i am still not on my lap to waiting on a new charger to arrive so you will have to bare with me I have got more done the hull is completed and I have started on the turet OC
  11. Evening all not a happy bunny this evening can’t get my laptop to power up thing the charger is dead and the batt is dead OC
  12. Thank you Gary, yes just having a short break with a few other projects. OC.
  13. Evening all, I got some good progress done today - I added the Two front guards and continued to fit the different parts around the front. OC.
  14. Looking great Denis, and with your blog/story I and probably the rest of the guys will pull and extra cozy chair up - to hear it.......... "Who's got the popcorn..........."Mark" OC.
  15. Evening all, I managed a few more hours on this today - I decided it was time to offer the lower and upper hulls together and glue in place, there seems to be a slight moulding error as the lower is slightly thinner than the upper, so I worked from the front hull first getting glacier plate lined up and glued, then I worked my way towards the rear and the engine bay, again a few slight errors of lining up so it was trial and error till I reached a good half way stage. On the one side above were the skirts will be a top hatch side piece was showing a recess so this needed to be filled with putty and sanded. All in all not too bad - but the lining up miss match under neath is a surprise. OC.
