So reminds me of this piece of Artistry - OC.
- 321 replies
- Finished
- Flower-class
Amazing Wonderful work - speechless levels of detail. OC.
- 321 replies
- Finished
- Flower-class
By the time I have spent some hours in bathroom - I'm to tired to do anything on my build. "I Will be Back" OC.
Hi all, sorry for my lack of updates - real life events have taken me away from playing on my Hood - in the shape of decorating our bathroom, I have been re painting from the old tired sand colour to a fresher apple Green colour, that has required several coats over the top (but I have picked up a useful technique - dry each coat with a hairdryer) this way I can tell if the layers have dried smooth or patchy and gauge how many coats are needed (about Three is doing it). I am nearly finished but its kept me away from my build. OC.
Based on your ability and the inherent difficulties with card kits - this could be one of your very best builds - take it steady Kevin. OC.
- 24 replies
Hope your able to recover from this Kevin - I know I would have been gutted and boy would the air have been Blue. OC.
- 79 replies
- SD 14
- Marcle Models
Evening all, a wee bit of progress today, I have left the Vallejo primer for over Three days so I thought it would be ok to mask up the boot line ready for airbrushing, I measured Two strips about 1.8mm wide - roughly 8 feet eqv, a bit akward to cut as they needed to be longer than my ruler - so I had to slide it along carefully keeping it in place, then I placed them and burnished them down using a cloth, it has taken a bit of the primer away (more a rubbing smooth than flaking) so top coats should go over the top ok. OC.
She is looking really nice Alan - tell you a little trick I did on my railings on my Warspite build painted the wire rails in-between the stanchions Black as I understand there were that colour and still are on UK ships to date, it would also make them less obvious. OC.
Thank you kindly Mike, I am leaving the Primer for a good 3-4 days to fully harden but will also try that trick with my tamiya tape. OC.
Thanks Mike, I think what good about the Vallejo Primer is the way it shrinks down onto the surface, I have been spraying it with vallejo flow improver (just a few drops into the cup) what I will do is give it a good few days before I mask up the hull for my other paints. OC.
