shipaholic
Posts posted by shipaholic
  1. Pat, Mike
    Yeah Nah, thats exactly what I thought too Mike. I have no problem tying the clove hitches, over the years I have become quite adept at tying knots with tweezers. For the ratlines I am using linen thread I got from a sewing shop, its different and thicker than cotton and just the right diameter, it isnt fuzzy and forms nice neat "spliced eyes" by folding it over with a tiny drop of pva glue to hold the end and form an eye. I use the thinner cotton to tie the eye to the shroud and if trimmed close its really neat. I use a precision electronics wire cutter for trimming, brilliant. For all my rigging work and other small stuff I put a small amount of PVA glue into a small tray or stubby lid and use a piece of copper wire to apply a small drop of glue to the article. After a while you form a small mountain of dried glue, when I built my last ship I had a glue mountain about 20 mm high!!
    Cheers
    Steve
  2. Hi Dave
    Re the tiller
    Here is a pic of how I set my tiller up, I didn't fit blocks to the tiller like shown in the AOTS, I set it up like the full size replica. I cannot get my rudder to go hard over but I don't think it would foul with the chimney.
    The other pic is from the April 1768 draughts showing the "arch", its also shown on two other draughts so the arch definately exists.
    Cheers
    Steve
  3. Nice work Dave, I did the same thing two different style pumps for the reason you stated. Actually the original pumps are shown on the draughts done before the refit, and their position is shown on the deck plans. In the photo you can see the pumps on a ship model from the same period as Endeavour, they look similar to the ones on the draughts.
  4. Haha yes Paul I did exactly the same thing, when I was a teenager I spent a couple of weeks building a free flight glider. First flight I towed it up like a kite using a fishing line. It got into a thermal and just kept going up up and away, never saw it again despite chasing after it in a car with my dad.
    Anyway heres a pic of the ship, ready to fit the ratlines
  5. Thanks clogger
    I chose the colour scheme for a couple of reasons. I wanted my Endeavour to look like like an 18th century Admiralty model, hence the fairly light shade of the side planks and no white bottom. I also studied lots of old paintings of ships of this period in the 18th century. Marquardt In the AOTS book states that the bottom was covered in "brown stuff" not painted with white lead, so in that respect painting the bottom of the hull would be wrong anyway.
    A lot of Endeavour builders try to make them look like the full size replica vessel, but I am not. Its the builder's choice.
    For filler on the first planks I used spakfilla, I sanded the first planks fairly agressively (thats what theyre for) so I only needed to use filler where there were depressions. See pics below.
    Cheers
    Steve
  6. Thanks Mike
    I wondered why you hadn't posted in a while. I used to make those plastic aeroplane models, and ships, even rockets and a lunar module when I was a kid, yeah the painting is the hardest part. That led me into the flying planes, building balsa wood planes and crashing them a lot. Then I built a couple of larger plastic ship models, the Revell USS Consitution, and the Revell Cutty Sark. I still have the Constitution. My mum still has the small scale plastic ships I built as a kid on her wall unit -theres a Mayflower, Bounty, Constitution and Victory.
    Cheers
    Steve
  7. Its been a few weeks since I did anything, but I managed to get a few hours in this weekend. Finished doing the mizzen catharpins and futtock shrouds then I blackened the rest of the shrouds. I used flat black enamel diluted with turpentine to make it wick through the rope better and not be too black so it looks nore like real tarred rope
  8. Hi Chris
    As Paul said the Endeavour is a hard hull to plank because of the boxy shape. If you look at my build log on page 1 and 3 you will see that I needed to use a lot of stealers and tapered planks. The top layer planks are thin so they don't like curving laterally, therefore I just let them lay how they best could on the darker lower planks.
    For the sides above the main wale I wanted to simulate the upwards curve of planks on a real ship and it was a real task, when you try to curve them laterally they want to kink and buckle and it's hard to keep them flat against the hull until the glue sets. I had to use lots of clamps to keep the planks from buckling, fitting one plank at a time then waiting for the glue to set.
    Cheers
    Steve
  9. I have built the AL Endeavour and am currently building the partwork equivalent of the Occre. The AL was twenty years ago so the kit has changed a bit. The Occre is bigger in size but the wood and a lot of the fittings are poor quality. If you value the look of nice walnut then the preference is the AL, if you want to paint the model then the Occre may be better.
    Cheers
    Steve
  10. Hi Ron
    This Occre model is the same as the one I am building, and I am positive that the scale is 1:51, and Pat is right royal navy ratlines were usually 13 inches apart. So the spacing should be 13 x 2.54 = 330mm divided by scale (51) equals 6.5mm
    Re the catharpins, I don't know how fussy you want to be but I served mine all over, but the important thing is to get them all exactly the same length so that they all pull equally tight when the topmast shrouds via the futtock shrouds put tension on them by wanting to spread the lower shrouds. I made the catharpins with an eye at each end then tied them to the futtock staves with thin cotton.
    Cheers
    Steve
