woodrat
Posts posted by woodrat
  1. I think the colour is very good - it points up many detals that would otherwise be missed in a darker vessel, and the contrast is in keeping with the original Trombetta picture - and I find it interesting that the deck beams and the wales aren't in line with each other near the bow, just as in the Trombetta picture.
    The fact that the beams cross the wales confirms to me that Zorzi Trombetta drew his sketch from life and probably while the nave was in drydock( hence the unplanked area between the main wales). This is one of the reasons that I chose this sketch as a basis for a model. Most other paintings are by professional artists interested in aesthetics whereas Zorzi was primarily interested in recording the craft of shipbuilding.
    Doreltomin. Thanks for the scholarly breakdown on the derivation of Carrack, with which I substantially agree. However, when you say: "The nao being primarily a merchant vessel while the carrack was primarily built for war", it does not take into account that in the late middle ages, mediterranean round ships ( naos or naves or nefs) were sometimes hired or recruited as warships even though they were built as merchant vessels. This is because it was soon realised that the high freebord of the round ship was a great protection against the low slung galleys of the corsairs. Only later were purpose built round hulled warships developed. It is a fascinating topic, isn't it? :)
    Dick
  2. First I want to say thank you for your comments and your help
    Dick, so I need to rejuvenate the false sternpost, the sternpost and the knee, is that right? ore only the knee, I have already glued everything together.......... now I have a problem  :(  :(
    nil desperandum, Tom. No need to remake the knee.  Much as Karl has shown, after you have completed and fitted the transom timbers, fashion piece and last 2 frames, simply fit some timbers below the lowest transom beam and shape them in situ with your friendly Dremel drum sander. Dick
    Another point. Please note there is a step at a slightly lower level for the step of the forward half of the full frame. It also has a hole for a dowel. You do not appear to have done this. :)
  3. Tom, I highly recommend that you construct frames to rigidly hold the stem and stern posts. also take care that the keel is held by wood planks which go almost up to the rabbet line of the keel. here are some photos of the ones I made
    post-848-0-36423900-1401536877_thumb.jpg stempost clamp
    post-848-0-43696200-1401537542_thumb.jpg sternpost clamp. Note the allen key in the top of the clamp to tighten the bolt thereby holding the sternpost down.
    This will reduce the risk of twisting of the hull over time :) :)
    Dick
  4. Many thanks, Christiano.  At your suggestion I have renamed my log. S. Penzo's nave tonda is magnificent and puts mine in the shade. I have his book. I did try to contact Signor Penzo a couple of years ago but he did not answer the email. Maybe I should try again. One of my ambitions is to work up to a fully framed nave as S. Penzo has done. But it is a massive project. Perhaps I could do the Contarina I ship. At least the plans should be available. I will soldier on with the Trombetta nave tonda. :) Dick
  5. Sorry, Steven. I cant access that link. But I think I know the image referred to. As you allude, many models of carracks underestimate the length of the mainyard which is made of two timbers fished together like  lateen yards.
    Here are some pictures showing the bracing for the transversal bitt. The bitt is not bolted in but is wedged in placed. This allows some slight movement of the bitt which protects the side timbers. It also allows removal of the bitt if required.
    post-848-0-30420600-1398665745_thumb.jpg  the stern timbers incomplete
    Dick
  6. These pictures show the transversal bitt in place although not fixed in place. These bitts were a typical feature of the carrack and were probably not meant to be rigidly fixed to the toptimbers. They were however quite massive.
    post-848-0-41632200-1396449520_thumb.jpgHere is a picture of the Mataro nao showing the transversal bitt.
    post-848-0-34457300-1396449217_thumb.jpgThis shows the step for the foremast
    Dick
  7. Thanks, Vivian and Steven. Here is the progress of planking to the level of the turn of the stringer at the outer end of the floors
    post-848-0-28890100-1396173333_thumb.jpgFitting the stealers
    post-848-0-15624000-1396173457_thumb.jpgstealer glued in position
    post-848-0-50112700-1396173460_thumb.jpgplanking complete to first stringer
    Here is another similar carrack. Note the triangular topsail and the forward positioned foremast. I will base my rig upon this illustration
    Dick
  8. Maybe will be interesting photo of  this model I take this summer in Maritime museum of Kotor, Montenegro
    Model is based on ships used in Venetia, by famous middle age traders of Venetian republic
    In Serbian/Croatian language, for this ship is used name "karaka" and you can google it for deeper research
    Nenad
    Thank you for the link, Nenad. The model shown is certainly a venetian carrack and is quite old. It looks somewhat like the carracks in Jacopo de Barbari's panorama of Venice.
    Good idea to get information or pictures of models from Dubrovnik, Split and Rijeka. They, as you say, were on venetian trading routes for centuries. The Trombetta nave certainly would have visited them regularly.
    Cheers
    Dick
  9. Thanks Tarbrush, Bob and Nenad M. I am learning more and more about carracks. For instance, this carrack forecastle from late 15th century shows how the carpenters built the framework for their awning assymetric to allow for the foremast. This may explain the somewhat bizarre appearance of this framework on the Trombetta drawings. The position of the foremast also forced the positioning of the bowsprit to one side or other of the mast. These were no nonsense working ships and often aesthetics took second place to practicalities. also, as this illustration from the battle of Zonchio shows, round ships were often co-opted as warships in mediaeval times as their high riding hulls gave them a height advantage over galleys. Cheers, Dick
  10.
    I just posted this on Vivian's caravel log but I thought it might be useful to you too as a rigging reference..?
    Dan.
    Thanks, Dan. The original book is beyond my price range but there is a softcover reprint. What concerns me is that I am unsure whether my carrack had two or three masts. It was a large vessel so three seems more likely but the fact that the bowsprit is displaced to starboard suggest a foremast. However the framing for the awning on the forecastle suggests otherwise. What do you think? :unsure:
