Everything posted by AON
Completed my first attempt at a keel rabbet V-notch scraper. I used a piece of a left over ceiling tile perimeter L support frame. Laid out the keel side and top surface lines. Marked of the 4" thickness of the planks = thickness of the notch (OMG it is tiny) Punched and drilled a 1/16" diameter hole slightly off centre, more so inboard then outboard. I folded over the tabs so a soft edge would contact both the top and side of the keel. Rough cut the V cutting edge with some tin snips, filed one side and ground down the other with my dremel. It took about 15 or so passes to get a good deep notch and it doesn't look half bad! The notch should be closer to the top of the keel... I guess I was a little too heavy with the dremel. I might try a spacer to pull the notch closer or make a new scraper. I'll need to sleep on this.
Saturday 19 March 2016 Once again had to wait until the weekend to work on my build. Started off with an unrelated disaster in the bathroom shower plumbing first thing in the morning which delayed progress further... but on the up side (thanks to Google search and videos) I now know how to extract the glued end of an ABS pipe out of a shower drain plumbing socket. Seems the third try was the charm with the 18" square keel. I assembled the pieces and I am very happy with it this time. You can see I still utilized my metal straight edged scale as an aid to keep everything as near perfect as I might. On closer inspection I noticed the foam backing on my scale bulged out and nudged the keel sections out of alignment so I trimmed this back a bit. I did not clamp it to edge of the metal scale this time. I used finger pressure and held it for a few minutes. I also made the 7" thick false keel sections and wood glued the "tar and hair" black tissue paper to the top side of the pieces. The false keel is made from my eastern hemlock (fir). I found a #10 scalpel blade works best for trimming the excess. At first I thought I might stain it to make it stand out more but when I did a test I saw the hemlock is naturally a shade darker than the boxwood and looks appropriate without stain. The boxwood is above and the hemlock is below. The left side of the hemlock is natural and the right side is lightly stained. I hope to mark off and scrape out the rabbet line in the keel today then bolt the scarph joints of the keel sections. The next step will be to wood glue the false keel to the keel, and nail and staple it. We shall see how far I get
I have just heard back from NMM regarding the stealer top timber "Waldo" and post a small portion of the response from Nick Ball, Assistant Curator of Ship Models. "...I would probably call it a ‘filler top timber’, but not sure if this term is really correct, as a filling frame is actually any single frame spanning the breadth of the hull, as opposed to a double frame, i.e. two frames joined together which span the breadth of the hull." The message continues with multiple examples of this occurring. Now I am torn... stealer or filler... or more affectionately: Waldo?
filling pieces between frames
AON replied to AON's topic in Building, Framing, Planking and plating a ships hull and deck
spikes now that makes sense thank you -
Hoping someone knows the answer. I just seems to me treenailing (dowels) would be easier to drive home from one side only but the contract specifies bolts and I cannot imagine how Last century rivets had to be red hot to hammer the heads to a tight mushroom shape (bridge construction) so I imagine it was the same in the 1700s (for ships) How could they pre-insert a red hot bolt, get the timber in place, and then hammer the end over before it was too cool and still support the inaccessible far side head of the bolt. Stuff like this keeps me awake a night -
Thank you all for your help. Here is the exact wording... [Page 4] FRAME --- It being of the utmoft confequence to the strength of the ship, that all the timbers of the frame should be as much as poffible be preferved from being cut by the ports of each deck, a difpofition for that purpofe is made on the faid draught, and as a further means to obtain it, the faid timbers appointed to make the sides of the ports being continued up to the top of the side, are to be framed in bends, 1st, 2d, 3d and 4th futtocks and top timbers together (as diftinguifhed on the draught) and faftened with three bolts of 1-1/4 inches in each scarph, and that the firft futtocks be bolted to the refpective floors of every bend, with 3 bolts of 1-1/4 inch diameter, that the stations of the faid frames fo diftinguifhed, are to be preferved with great exactnefs, and fo fuch of them as ftands afore and abaft the square frames, and are to be canted, thefe alfo are to keep their stations, at the breadth, and what is required to give the fafhion piece and beakhead timbers a proper flight, or cant,.... (continues)
My build contract states "... are to be framed in bends, 1st, 2nd, 3rd, 4th futtocks and top timbers together, and fastened with three bolts of 1-1/4" diameter in each scarph..." Was there a pattern for laying these groups of three out... possibly diagonally over the length of the scarph (height of the frame)? Anything I find shows two laid out diagonally but there is no source to suggest this is correct FYI: Floor timbers are sided 13-1/2" to 16" Top timbers are sided 10-1/2" Futtocks would be anything from 16" to 10-1/2" Futtock heads and heels are joined with chocks whereas top timbers employ a plain scarph.
Okay So the very first set are easy to do. Then a third frame goes up.... Presumably the hole was bored through the second and third frame, and the bolt installed in the second frame, before it went up as the bolt could not be installed after. How do they brace the bolt head to hammer the other end? Did they use metal plates and wedge shims in the space? -
Framing filler pieces Construction of the English Man of War 1650-1850 by Peter Goodwin, pg 17 states: "The filling pieces were made ..... and were bolted in place in the fore and aft direction." As bolts were more like iron rivets with a ring washer how did they hold the one end in while hammering the other end to mushroom it over the ring? Particularly when the space was 1/4" or 1- 3/4" or even 2-3/4". Did they insert a temporary metal filler to hold the bolt in place?
The reason for rejection is obvious.... It is facing the wrong way!
- 641 replies
- greenwich hospital
- barge
Completed a number of non-related projects on my "to do" list this weekend, including sharpening some tools, but did manage to try the spot of black water based paint mixed in the yellow wood glue. I must confess I did not like the results so I did it again with the paper and had better results this time. Trimmed it with a scalpel before gluing the other section of keel to it. I also worked on one half of the boxing scarph joint at the bow and it turned out pretty good. No photos though as I am not satisfied with this overall attempt and so will be redoing the whole thing. The material is not scrap, just won't be the keel. I am not disappointed, feeling good about the whole experience. Found myself wanting to jump ahead, fighting the urge... taking a breath and working on one piece at a time... this part is difficult for me. To use to multitasking.
I am anxiously waiting to see how you trim her out
- 641 replies
- barge
Good morning Allan Thank you. I thought it was the bestest (is that a word) idea ever! I cleaned it up and the paper looks fantastic... but ... I should have trimmed the crepe paper back first as the assembly of the two pieces has a small rise to it. The crepe paper folded over (?) against the ruler when it was clamped I am presently soaking the joint in rubbing alcohol to take it apart and do it over as this tiny little lift will nag at me forever.
For years I laboriously sharpened my chisels by eye. Then I saw someone use this neat contraption so I acquired it. Now I find my chisels have a wonderful round to them. I spent another long time removing this round with the new contraption. Now I have to polish the back side to a mirror finish? Yes, I'm shaking my head.... but...If it is going to help me do it right consider it done. It has also been suggested I practice with a square block backing to get a better feel for the perpendicular angle. I am game to try this also. Thank you. Alan
And we start (again) Saturday 27 Feb 2016 Ripped a couple pieces of castello boxwood to about 20" (1:64) on the table saw then milled down to 18" Sliced of strips from it to about 20" and then milled them to 18" square. This is the stock material for the 4 keel pieces The foremost section of the keel with the boxing scarph joint for the lower stem post needed to have the strip cut made wider, about 40", as it stands taller forward than aft. Using a longer piece than necessary, using a sharp soft (HB) pencil lead, I marked of the length, depth and angle of the scarph on the top side of the stern most keel section. The depth of the scarph joint was carefully cut on the scroll saw and using a freshly sharpened chisel I attempted to cut it out in very small slices. I seem to have a huge problem keeping my chisel perpendicular to the stock to get a clean square cut. To remedy this... until I master my chiselling skills... I cut off the bad scarph joint (scrap) and remarked the stock. I clamped it on the line on my flat faced woodworking vise. Using a fine toothed saw I cut the depth perpendicular to the stock. Using the same saw I cut the length somewhat parallel to the surface of the vise. Using my chisel I cleaned it up and then sanded. I repeated this on the mating piece and this resulted in a good joint. I did not invent this method... I saw it somewhere in a build log on the forum. Thank you! Sunday 28 Feb 2016 I used this same method to cut down the 40" height of the foremost keel section aft of the boxing scarph joint to 18". The scarph joint shape was transfer to the stock using carbon paper. The carbon paper was place on top of transparent (see through) graph paper. The carbon side faced up to the graph paper. My template was placed over top of the graph paper. I traced the outlined of the scarph joint shape with my pencil which transferred it to the underside of the graph paper. The transparent paper was placed on the stock and the carbon line (on the underside against the stock) was traced once again with my pencil resulting in the line being transferred to the stock. This is much more work than cutting and gluing but I am trying to preserve my templates (and eliminate any need to spend more money on another copy) This shape was roughly cut out on the scroll saw and then cleaned up with a drum sander attached to the drill press. The boxing scarph joint has yet to be cut. The stern post mortise hole was drilled out and cleaned up as best as I can manage for now. Black crepe paper (representing the waterproofing tar soaked felt) was cut oversize and glued to one outer set of joints (toe/heel). When this dried the two pieces were glued and clamped. This paper has yet to be trimmed back to the keel surface.
