Everything posted by alde
That's a bunch of guns to rig. By the time you are done you will sure be an expert. Looks great.
- 1,350 replies
- constitution
- model shipways
You guys that take on a project like this and do such great work are a true inspiration. Your workmanship and attention to detail looks like you are an old pro. I am about 3/4 of the way through your log and have learned quite a bit of great information. Thanks for making the effort to put so much into your log for us newbies.
- 659 replies
- syren
- model shipways
I am looking forward to watching this progress. I am working up the nerve to start mine too.
- 194 replies
- armed virginia sloop
- model shipways
Tom, It's been several months since I have been on the forum or looked in on your build. You are doing a wonderful job and have made great progress. I will have to go back and read what I have missed and get caught up. I am only now getting back into the hobby after having to deal with real life issus. Now that life is a bit more stable I can start back in were I left off. Al
- 1,350 replies
- constitution
- model shipways
Sure looks great Captainsteve. I glad to be back abord to see how things are progressing.
- 625 replies
- bounty launch
- model shipways
It sure has been a long time since I have been able to join you all in your builds or work on my project. I hope everybody is well. I have had some family issues but things are settling in a bit now. I may not get back to my boat right away but hope to look in on what's going on and maybe ask a few questions. I will need to re-learn some stuff and get back into the swing of things.
You are doing a fantastic job for a first ship model. Your time building RC Airplanes has paid off. How much time do you have into your build so far? It looks like you started your build log when you were pretty far along.
- 43 replies
- new bedford whaleboat
- model shipways
Yes, the standard tool holders that go on the operator side are about 1/4" shorter so they cut from the top. The rear mount is designed to cut from the bottom and the cut off tool is put upside down.
Yes, it's the rear mount tool holder. I got it because I thought it might be better if I make several parts like cannon barrels. I have the thinner table on the way and it should solve the problem. Thanks again for all the help. I will post back when I get the new part and have it up and running. Then I have the fun of learning how to use it. Al D.
Thank you. This is just the information I was looking for. Yours is a full 0.25" thinner. I must have the wrong part on my lathe. I sure hope the part I get from Sherline works. Thanks again for all the help.
Mark, I had the slide off and could not find a part number. I went ahead and ordered the slide that should be correct for my lathe directly from Sherline. It was $35 but it will be well worth it if it works right.
Yes, and after looking at it and comparing it to pictures of other Sherline lathes and a drawing with dimensions I found on the company site it looks like my cross slide it too thick by 0.25". It was bought used. I am thinking somebody switched the slide with one from a mill or something.
It's been a while since I have been at the work bench or the computer but I have made a bit of progress on the Launch. I have started the rigging and got a new toy. I got this serving machine from one of sponsors, Domanoff's Workshop. I know there is very little rigging on this boat to justify a serving machine but what a great tool it is. Very well made and works like a champ. I hope to get the rigging done in the next few days and move on to the other details. Al D.
I just got what I thought was a good deal on a used Sherline 4000 Lathe. It runs great and seems nice and tight but there is one problem. The distance from the top of the cross slide to the center of the chuck should be .94". Mine measures .69". I noticed there was something wrong when I could not get a tool close to the center of the work and I could not chuck up a 1.5" diameter aluminum rod over the cross slide. My cross slide is .88" thick. Can somebody please measure the thickness of their Sherline lathe cross slide for me? Here is a picture of mine with a brand new rear mount cut off tool that goes over a piece mounted in the chuck. Thanks for any help, Al
I am looking forward to seeing the "faux-trenails" progress but I thought we might see the puffer fish effect. Good luck with the move. It's always a stressful thing to do. Every time I have moved I said never again.
- 625 replies
- bounty launch
- model shipways
Floyd, You might look into the 2 part resin they use for fiberglass. It sands much better than epoxy and can be thinned to a watery consistancy with acetone and brushed on. I did this for an RC tugboat hull then used red Bondo auto body filler to even up any spots. It comes in a tube and sands better than any else I have tried. Al D.
- 80 replies
- Americas Cup
- Endeavour
Oh, the floor looks fabulous. Your distressed look is working very well.
- 625 replies
- bounty launch
- model shipways
