alde
Everything posted by alde
  1. They look really good in a natural finish. Black looks good too but red would be too much IMO. Maybe nature trucks with red axles? I ordered the Cheerful starter kit today. I am really excited but need to be patient and finish a couple more kits before I start it.
  2. Ouch, that is a major re-work. It did look darn good the way it was but you need to be happy with it.
  3. Elijah, Kurt's cherry veneer should be perfect for your planking. You will learn so much and have great rewards for it. You really seem to be willing to take on a challenge and working through things.
  4. Tim, Maybe it's my fairing but at the plan width they would be way too wide. This will at least be a good lesson on laying out the planks. I will still use the patterns as a guide.
  5. Nigel, Thanks for putting a second set of eyes on it. it looks like if i use the plank patterns on the plans they will note close to fitting at least at the bow. they are way too wide. I am using my tick strip at each bulkhead and dividing it by the number of planks in the belt. I know this may seem elementary to some of you seasoned plankers but it's still voodoo science to me. It will be slow going but it looks like it will lay out according to the plans.
  6. Well, I got all my deck beams in and that was easy enough but now it's time to plank the hull. I have read and re-read the instructions, read the Jim Roberts planking book and some on line information as well as some build logs. I'm still not sure I have a firm understanding of it. I have sectioned off the 3 belts per the instructions and ran my battens. It looks to have a good flow and seems to match the plans pretty well. The plans have plank patterns and I may see how those fit but I want try spiling my own planks too. I have a proportional divider so I thought I could use it and tick strips. Am I going in the right direction? It seems that some of you guys pick this stuff right up and do a great job. I seem to be really planking challenged. Of course if I just did it and quite worrying about it I would be better off.
  7. Greg, If you don't mind I would like to jump aboard for you build log. Good luck with your build.
  8. That's so cool. I love the snub-nose cannon. Did you use a needle fine to cut the belaying pin/quoin?
  9. The fairing is going pretty well. The bulkheads are pretty thick which is really nice. It makes it much easier to see the hull shape up. I don't want to take much more off so I am checking it often with a piece of planking. Please excuse the messy bench. Maybe I will get it straightened out before I go much further.
  10. Sal, Your masts and rigging look great so far. I can't wait to see the yard arms come together and be shipped. Will you start from the top and work down? I have seen people completely build out a mast before they install it and also do like you are where you build it up on the ship. I can see advantages to both methods. I love the detail of the rigging.
  11. Heck, a 1/1 build is still a build. Your Pinky will be there when your ready. I will look in now and then to see if you are back to it.
  12. Elijah, You are doing great. You are thinking things through and taking your time with your build. The rewards will be worth it. Keep it up.
  13. I can see that fairing the bulkheads is one of those things that's easy to do but difficult to do well. Slow and easy is the way to go for sure.
  14. Thank you all for the likes and joining in. Please don't hesitate to point out errors or just point and laugh.
  15. I got the hull halves together. The fit was pretty good and it went well. I have started fairing and that is going slow but pretty good so far. I really like the lines of this little ship. After the fairing the supports for the cabin and cockpit. Some of my bulkhead supports might be in the way but they should be easy to shim. I am a real wood butcher compaired to some of you guys but it's getting better.
  16. Chuck, I am pretty new to ship modeling and have started my second build and am about half way through reading this build log. It's seeing beautiful builds like this that got me interested in the hobby. When the plan and bulkhead set is available again I will be ordering it to put aside for when I feel I can do it justice. As you suggested in your log, I need to learn to slow down and take my time. It's not a race to see how many ships we can build. Al
  17. Ken, thanks for the great copper plating tutorial. Your Connie looks fantastic.
  18. These are pretty little ships and your off to a great start. I am looking forward to watching this progress.
  19. I have been using a 6" wooden block for fairing my bulkheads on my new build. I have tried the flexible sanding boards and they work well but are hard to hold on to and curve around the bulheads. What do most people use for this? It's going OK with the solid block but thought a flexible sander might be more precise.
  20. I'm making a wee little bit of progress but nothing worth pictures right now. I am getting the bulkhead supports in and will get them nice a faired next. I will get a couple of progress pictures before the halves go together and another after. I am looking forward to getting the planking started.
  21. Mundie, Your Connie is looking great. I wonder if some rubber cement might work. You know, the kind you brush a thin coat on both surfaces and let dry before you stick them together. Elmers makes it.
  22. Tim, I have read through your Pinky log. It's going to be a great help in my build.
  23. Here we go with ship number 2. I am almost done with the Bounty Launch but wanted to set it aside for now to start something new. I had the Glad Tidings and the Armed Virginia Sloop on the shelf and decided to go with this one. I love the lines of this little schooner. I got it started with no trouble so far. Cutting the rabbit went pretty well. All the bulkheads are in place and the supports are going in. I should have the 2 halves together very soon and will start to plan the planking. I hope to learn as much from this build as I did the Bounty Launch. I will do my best to keep the log updated and take as many pictures as possible. Sometimes I get carried away and forget. I'm sure I will have plenty of questions. I sure wish I had the skill and nerve to jump into a bigger project but I want to take it slow and build my skills. I also need to learn to slow down and take my time. Thanks for stopping by. Please don't hesitate to point out anything that looks out of place or to ask questions about the kit or what I am doing. Al
