1 hour ago, popeye the sailor said:
looks really good OC  :)
Thanks mate:)
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Hi folks   I have probably shown this before - but this is the stage I am building her from  - 1944  D Day   off the French coast.
OC.
Current builds
Completed works.
Folks I thought I better say - I havn't given up on the ole girl,   Im just having a bit of a break and working on my other project  HMS Greyhound  1720s  RN Frigate,  pop along and say hello.:cheers:
OC.
Current builds
Completed works.
thought never entered my mind  ;)    I'll have to look into your Greyhound build........
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
See you over there  - bring a chair plenty of room still  and free Jamie Dodgers ......yum yum.
OC.
Current builds
Completed works.
  • 2 months later...
just catching up on all the logs i follow
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you for looking in,  although  im not working on her at the moment, its great having you have a look at what I have done so far.
OC.
Current builds
Completed works.
Hello everyone,  I had a look at the the ole girl yesterday  and thought I really should summon up the courage to have another go on her, my hands are no worse so perhaps I will be ok,  need to get some more supplies though first as I have no super glue but might be tempted to get gorila glue if I can get it from ebay, and my Revell poly cement (the bottles with the fine needle)  well the needles have jammed up in both of them and I do not have a fine enough wire etc to clean through the needles.
I will try to get some thing sorted though.
OC.
Current builds
Completed works.
Hello OC, I'm still plowing through your build log and now you may be abandoning this magnificent ship?  Sure hope you have second thoughts and complete her. That last photo you showed where HMS Warspite is delivering a few shells at the Normandy Beach at the invasion, reminds me of Hr. Ms. Java's sister ship Hr. Ms. Sumatra. They used the "Sumatra" as a breakwater for the invasion, an honorable end for that nobel girl.
I'l continue looking at your progress though, it's very inspiring to me.
Hope your hands are not getting worse so you can continue with your model till she's finished.  My wife Gwen also has similar hand problems and will get a second operation next week. Two fingers keep locking up on her that's very painful.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
21 hours ago, cog said:
OC I use a lighter to declog the revel glue, if yours has the metal nozzle you can try it. You need to take care with the flame though
Thank you carl,  I will try that.
OC.
Current builds
Completed works.
Cheers,
Hi pat,  Thank you for looking through my build,  im sorry to hear about your wifes hand condition, mine comes and goes but I was suffering holding the small parts,  but I will try to carry on with the build.
OC.
Current builds
Completed works.
if you tire of watching you glue tube,  looking like a tiki torch,  just use a drill bit of the same diameter.   I'm a no fuss guy at times......in those times I just shove a pin in the hole,  and let's go!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 4 months later...
Evening All,
Im returning soon  - so dont go away,  im just finishing off my sub build, then I will return here as I have restored my mojo for my plastic builds, and my hand is not playing me up to bad.
So recharge your pop corn and drinks (whatever your poison may be)  and please make a  slow return back to your seats.:dancetl6:
OC.
Current builds
Completed works.
I cured my stuck glue tube with some heat  - you know those attraction car displays with the flame thrower exhausts..........:huh:   only kidding, I used a gas blow tourch.
I realy used a lighter to heat up the end of the tube.
OC.
Current builds
Completed works.
So!    it continues  -  my object was and is  to work from the stern moving piece by piece to the bow,   so my first return to her was to work on the two aa gun tubs nearest the rear bulwarks where the nameplates are.
Same build process with these resin pieces - cleaned up then two pe ammo boxes where bent to shape then glued in place with ca glue, then a door was fitted to each.
So here is the first pic of my return.
OC.
Current builds
Completed works.
And here she is back on the work bench.
OC.
Current builds
Completed works.
Thought carl might like this - oh and greg,    Warspite refueling HMAS Nestor.
OC.
Current builds
Completed works.
1 minute ago, cog said:
You have some serious superstructure to build mate
Yep,   bit by bit  taking my time,   I  guess it will take the next 30 - 40 years to finish  (I dont like rushing)
OC.
Current builds
Completed works.
OC, you may want to consider working from the center-line of the ship out to the bulwarks. The superstructure looks like a mountain, so you may want to work from the middle out.
Ken
Started: MS Bounty Longboat,
Thanks ken,   thats kind of my thinking also  - working from stern to bow but also working from the center outwards, but as we do  aslo working on the sub assemblies  off the ship to save any damage from working over delicate parts,  the masts will be a later instalation as I will hope to build these from brass rod.
OC.
Current builds
Completed works.
good to see your back working on her........really nice paint work so far  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks denis,   I decided to give her another bash as my hand condition - Dupuytren's Disease   is not too bad at the moment, and my sub caused me no problems at all.
Take another seat there are plenty left (they un filled due to lack of interest)  hoping this time  with a new vision and mojo, should be a better adventure.
OC.
Current builds
Completed works.
Good seeing the big boat back on the bench OC.
Cheers,
                       VOC Ship Surabaya
Cheers,
Thank you piet.
OC.
Current builds
Completed works.
Nice to see you back with her, she was a great ship
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you kevin,   she was my favourite ship of ww2   and what an amazing service she had  only ending in cornwall  when she refused to be sent to the scrappers and dug herself in on the rocks.
OC.
Current builds
Completed works.
