I have been planning this build for a while, and I have done extensive research. I am now comfortable with all the information gathered to start this build. This version is the one designed by Cap'n Nate (1912 ) Here are some of the drawings to give you an idea of what she will look like. Here are the results
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
I started the day by laying out the Keel on 1/8" Bass wood, Next I lofted out all the frames , I then laid out the 3/32" Bass wood for the Frames , Next I cut out the Keel and Frames, then did a dry fit. so far She's coming out right on the money . Next will be to true up the frames and detail them along with the Keel . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Ought to call you "Rocket Pete" the speed at which you pull these boats together. The beginning looks great.
Michael
Thank you Harvey, This is one that I have wanted to build for a while now
Thanks Michael, I dont know about that " Rocket Pete" , however I do appreciate the compliment
Thank you John, This is one of my favorite boats I bet they sail great
Thanks Jay , This feels like one of those builds that just fall into place ( I can usually tell right from the start if it's going to go smooth or be a struggle)
Thanks Patrick, ok maybe " Rocket Pete "  ( Kate thinks its great ) I love the Herreshoff designs, I hope to do this one justice
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
You have a good start on a lovely boat.
Bob
Current build:  SS_ Mariefred
Thank you Cap'n'Bob , The Alerion is definitely a beauty
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today , I started the day by detailing the Keel. I then detailed the frames wich make up the Cockpit. ( I only cut them down to the top of the seats , and will cut them down to the Floor once the Hull has been planked.) I then trued up all the frames and fit them into the Keel. I then glued the Frames in making sure that everything lines up ( remember plumb is plumb and level is level) I then turned my attention to the Deck . I started by laying out where all the frames are as per plan. I then laid out the Cockpit section. Next I attached the Deck to the Keel and frames, again making sure everything lines up. ( So far she's right on the money ) I then started fairing the Frames ( I am very close at this point ) next will be to work on what I feel is the most challenging part of this build the Transom. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
She looks to be a beauty Pete.  I have a book on Herreshoff yachts and his stuff is unique as well as nice.  Mind if I pull up a chair to learn something?
David B
Thanks David B, I have always liked the Herreshoff designs , by all means pull up a chair
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today , proved to be a good challenge, I started by getting the Transom laid out , next I framed in the transom section and then faired it in with the frames. I then added a piece of Birch ply ( wich will be stained a cherry red ) I then turned my attention to planking . I did the first 3 rows , and then detailed  the cockpit section. I then ran the next 3 rows of planking. Next will be to finish the planking. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
You can see the beautiful shape of this little yacht even on the frames!
John
Thank you John, She is starting to take shape , I have been enjoying building this one
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
What lovely lines she has.  Herreshoff was a master.
Bob
Thanks Cap'n'Bob, Capt' Nate was definitely a Master , and His son L. Francis was no slouch either
Best Regards,
Pete
Edited by Pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Just managing to hang onto the edge of my keyboard, wow I'm afraid to blink in case I miss something :D :D
Looks beautiful.
Michael
Thank you Michael, she's going together really smooth. ( practically building herself ) so it goes pretty quick
Thanks David B. , mine is not painted yet ( I know that Ive been called "Rocket" ) I am not that fast. The photo ( posting # 18 ) is from the Mystic seaport museum
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Patrick, This boat has been a pleasure to build ( to this point ) every thing has gone very smooth, A beautiful design that was Nate's personal boat
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I started by finishing up planking the Hull, Next I faired the Hull sanded up to 400 grit ( starting with 220 grit )  I then made the cradle. Next will be to seal up the outside of the Hull and start detailing the Cockpit. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
You know it Patrick , The transom was the trickiest part of this build, ( it was a challenge to say the least )
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
The lines of these Herreshoff hulls are difficult to make any better, they simply exude grace.
Michael
Thank you David B. , I am thinking of a white Hull , Sea Blue ( flat ) Bottom Paint , Sand Color for the Deck , and trimmed out in a Cherry Red stained wood ( It give's it a Teak look )
Thank you Michael, You hit the Nail right on the Head,  I could not say it any better myself
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
After taking a day to work on my full size Boat ( M-15 ) I started by making the Keel ( center Board ) and Rudder. First I laid them out as per plan and I then cut them out , Next I shaped them to the desired shape , then sanded them up to 600 grit sandpaper. Next I installed them on the Hull . I then turned my attention to the inside of the Cockpit, I started by cutting out some Mahogany and a piece of Birch ply for the sides , I then installed the parts, and Stained the completed center board box and Transom a Cherry Red. I then brushed a coat of Titebond 3 to the entire outside of the Hull. Next will be to sand the Hull up to 600 grit and get her ready for paint. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
