So I had done drilling and lost a one of the HSS drill bits in carpet, when I found it it looked like this.
Most of my bits going of like this has been broken.
Take a look and ponder about it.
Edited by Nirvana
Respectfully
What size is that drill bit? I have had a couple small tiny drill bits bend on me before.
Regards, Scott
Completed builds:
Awaiting construction:
I've bent some HSS at times and other times they break, but I find the carbide always break.  That one looks like it's been stepped on.
I thought in order to bend a bit like this you need some heat..... maybe a carpet is good enough...
The length: oh sorry, total length only 2 3/4 inches ( about 6.2 cm) long.
​Could have been stepped on, never felt it though......
:huh:​
Respectfully
It looks pretty thin then...  Did you run over it with a chair?  I've bent some #65's by stepping on them on carpet but then again, I'm a bit of a bull in a china shop.
If you have a spot of flatness around, e.g. some steel or a granite countertop, then try rolling the bit between the hard surface and a piece of hardwood such as maple.  And even if you don't have a hard surface, then try rolling it between two pieces of maple for a while.  It might likely work for you.
You might also reduce the driving pressure when drilling -- let the bit do the work.
Edited by Bob Blarney
Try heating the bit red hot (hold it in pliers), and then stir it in vegetable oil to harden.  Let it cool.  Then bake in oven at ~400F for 30' or so.
You can tell when it's hot 'n ready to dunk in the oil when it is no longer attracted to a magnet, but don't heat the bit beyond that point.
Bluenose2,
I think it will be much much cheaper to dispose the drill and get another one than having it re-shaped.
Think I could some 20+ drills for some the shop price, or even more... :)​
Respectfully
Jud,
I still have the drill, maybe I will try it someday.
Respectfully
