it's been awhile since I last looked in......good to see you've made some really fantastic progress on her.   four years really isn't a long time,  if you look at the detailed rigging and tackle........some really phenomenal work!
 keep up the good work.....she looks superb! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Denis   🙂
I'm glad to hear from you again. yes I think you have long since finished the fishing cutter "Norden". so what are you building on now? I am still preparing to raise the mast but there are many shortcomings I have skipped earlier which must now be done before it is to raise the mast - otherwise it will be inaccessible to reach. Here is the main mast stays attachment on the deck, which I made this morning - I have run into a little dry time so I am now on the computer. :)
I had to remove the bench to get to
the brackets consist of a brass nail, one piece 2 x 2 mm plate from my brass platter and then some cut-off from some billing bots fiting.
It all happens here at the rowing shop
one piece  soldet
here with 1 mm brass wire bent to rings252253154_formast2(15).thumb.JPG.51d5ab4540672b7ffa4cda5e303c6460.JPG
and then just wait until they are dry 😁
Cherrs All.
Jens .
even if they don't come on yet, I just have to do a test. and, as feared, the space is very tight - but it might just be there
1043389315_formast3(5).thumb.JPG.e0bec79b5ec5599b69a4f50b2bed2720.JPG1623190331_formast3(4).thumb.JPG.f537a784b3b5f56b50eaacd7768835ea.JPG
Edited by samson
I guess one could call them shackle cleats........common name is eye bolts.   nicely done!  I see what you mean by tight space ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Jens, thanks for posting this thread. Excellent work.
I have just joined up to the site, and I have many questions for you... But first of all, I'd just like to acknowledge the fact, that I'm a coffee drinker/ with no interest in the tea trade 🙂
Look, I'm a complete novice when it comes to wooden ship building, however I went through this entire post several days ago... and I felt happy, and somewhat excited.
It felt like I was almost 15 years of age again, entering a cinema again... watching the film Titanic again.
I feel that you have introduced a living theme? Like James Cameron did, into the movie Titanic.
Anyway, my first question is about your power supply, it looks like a tesla coil? I have seen this wireless power supply during training before, and its impressive.
Is that why you chose to spray copper paint? Because real copper planks could interfere with your power supply?
I Am genuinely interested in your lighting philosophy, and the rest :) you're bringing something to life again. You're also casting new parts, in the age of the internet. I respect this 100%.
I do not intend on finishing any model ship, but if I was to try, your work will be a standard I will strive for. Thanks for your help, and please continue your post.
John/ Kiwi John
Hello John
thank you for the nice words about my model .I am very surprised and honored to be compared to one of the great filmmakers,
 but I can see what you mean by being cast in another time and place - it is a big part of building model.
that with the power - there I must disappoint you - the power supply is cable connected, but with very thin wires,
which is not seen in the picture
unfortunately i have no battery now - it is made for 12 wolt when i used dasbord bulb in the beginning. later i found out i
could use led light .
the current goes via cables ( 0,3 mm virer )to the cradle where the plus and minus are at each end and attached to a small screw when the model is right in the cradle the
screws touch two metal plates in the bottom of the keel.
87961469_strm(2).thumb.JPG.e68ebffa405cb19aa61dfd4d47ba67c6.JPG1182060012_strm(5).thumb.JPG.e1ed95135470825dec314a1041bc6644.JPG613106723_strm(6).thumb.JPG.39a7b691ced773e156b1866a7f6fc1fa.JPG1966110255_strm(7).thumb.JPG.2ece47baa855c654976512cb9ab0318f.JPG
I hope this detection does not disappoint you - even though I thought it was brilliant to be able to use vieres for cable
- the navigation light is powered by the support for bulvork where the plus and minus are twisted together as a support and
 painted white
Well but I hope this is understandable what I write - it is with the help of google translate and therefore it can be a bit strange - I hope it works
Cheers .
Jens
Åbn i Google Oversæt
Webresultater
Edited by samson
Jens,
I consider myself a very happy person, however... I feel Very disappointed! (please excuse my attempted humor) 😁 - I'm actually very impressed!
Thanks for the in depth reply, your work and photography is impressive. There is a known saying: 'imitation is the sincerest form of flattery'.
And, if you don't mind, I'd like to imitate some of your work.
Cheers, John.
On 1/3/2018 at 4:47 PM, samson said:
Hi All
A little update in the neverending story. I will roughly make all yards and make all the brass rings and fittings before I finally fix the masts - the 9 rings shown on yarde have taken 10 hours to form roughly 1 hour piece
Jens
Excellent work Jens!
hello etubino  :)
thanks for your comment i appreciate it
I am currently raising the mast - here are just a few pictures of it. I also just made me a new space holder for the rat lines (modifede the old more pricese ) which I will soon be busy with.218939203_formast(6).thumb.JPG.26014283e4191dbf1ca8b6460a4e0782.JPG1868339842_formast(7).thumb.JPG.7be2b27d56097157b5c140531b0e9b1d.JPG
Her is a pic. of my old space holder but the drills always catses the tread , and get stok in the other riggin . so now i changed the dril with to small woodstiks - hope it wil bee bedther .😁
the old one
Cheers
Awesome work Sir!!
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
Hi Hof thank you for commenting - I appreciate it  :)
I have now started on the rat lines. I have further modified my clamp by making a leash brake - the first knot has always caused me torment, but now it goes like a breeze.
1659508277_formast(14).thumb.JPG.eb4c65900617b79b29ba331c54f59e64.JPG666418179_formast(17).thumb.JPG.e73d58749dd8ae6586c276df15a09558.JPG1267330565_formast(11).thumb.JPG.cdc8d5f4ca6d2c9c6b3663531352950b.JPG
Cheers
Jens.
look'in really good Jens :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
very nice progress :)   is that the Revell Cutty on the sill?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Jens,
Just looking in and am really impressed by your model. I also had a look at kpunts Cutty Sark just now and its amazing how this model gets the treatment by various modellers. A real inspiration for me. I am envious that you are working on the masting and rigging already. You have done beautiful work in prepping the masts and yards. I wish I had your talent for making all the fittings for them.
All the best going foward!
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
sweet looking model Jens..........superb job on sails and rigging! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Peter
Thanks for your comment  :)
yes I am finally raising the masters - it is almost 2 years since I started doing the masters  . - but it is something you do when you have time and mood so there have been long breaks along the way.
Cheers
Jens
Hi Guy  :)
thank you for your nice words - it is fun to hear you have been in vordingborg, the last 2 years i have visited the city in week 28 where there is a "party week" with music performance and food  - and ofcours Beer.csm_Gaasetaarnet_af_Per_Rasmussen_-_Redigeret_af_Tage_Klee_40f6a3d07a_350d81b972.jpg.a26ac58299ffb1ac9441c548f426d81d.jpgDSC03439.thumb.jpg.49cb434a48ea2474210a9b9d344734ea.jpgDSC03522.thumb.jpg.5fa09f986f7c51f69a47fe7688c73dfc.jpg
unfortanly it has been  canceled this year due to corona
Cheers
Jens.
impressive work Jens.
I am building on other scratch forum  massive cutty1:24 but only low masted understandingly,here and there reworking many parts, occasionaly taking inspiration from  work of others as well. I have to take hat off before you small scale builders guys im impressed how many details even on stern you are able to make. looks lovely with all that chain applied. very nice work on standing rigging eyebolts near masts. congrats.
Vlad
rigging looks great Jens........amazed with the amount of chain :)   it really makes the rigging look more interesting.  wonderful job!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Vladimir   :)
Thank you for your nice words. Yes, we are gradually some people building on a cutty sark. I've seen your build log - and it's an impressive project you're on. and your richness in detail make you honor. i'm a little curious about where you should have it on display ? Is it for an exhibition of some sort. ? it will certainly attract attention wherever it stands.
Cheers
Jens
Hi Denis :)
Thank you for your input, yes it is really delicious with all the chain, I myself absolutely love it. However, I have a problem I have approx. 5 m chain I probably need at least 8 m, but of course it can be obtained.
Cheers
Jens
Very nice work !!!!!
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Hi Jens. Thanks for looking at my log. Your model is very nice and well built, I hope mine looks the same when I get a little further with it. I too am new to this site and indeed to ship modelling, I have a lot to learn but with builds like yours and the other wealth of fantastic models, advice and tips, I am sure to learn a lot here. Keep well and safe. Martin.
  • 2 months later...
