It 's time to paint the hull. After protecting the topsides and all over the top, including the bridge with tapes and newspapers, I gave a first-hand live on the work of red satin enamel rust, diluted with white spirit. Everything with brush.
Then I finished the painting topsides white matt.
At this point I noticed that the color of the hull had excessive disparity in appearance: the red satin was too shiny and opaque white was too opaque. So, to even out the whole painting, I decided to give transparent satin glaze on the whole with the airbrush.
The painting of the hull is finished. Removed all the masking, finally the hull is in its final livery!
While I waited for paint dries though, I indulged with the construction of the cabins on the upper deck. After applying all the strips around windows and doors I have given two coats of spray paint matt white.
Nice progress Francesca,
beautiful paint job
Nils
Current builds
-Lightship Elbe 1
Completed
She's really coming along nicely.
Bob
Current build:  SS_ Mariefred
Hallo  :) ! Finished the interior of the cabin with wooden benches, the glass in the windows with acetate, curtains with tracing paper and red pencil for finish. I tried people sitting inside (from China...).
At this point I gave up, for now, the construction of the upper deck and started the construction of the lower deck.
Shelves that overhang the sides: in the kit are pre-cut to laser plywood  1 mm., Also of rectangular holes which are used to fix them in place on the teeth that protrude from the sides. I do not like all that  because the joints are seen  :angry: .
So, I reconstructed them with a walnut strip curved with a hot iron  ;)
I'm here  :) Sorry for silence, but I did very busy last times… :angry:
Realization of stern benches
Realization of metal uprights between the lower bridge and the upper, obtained with brass wire of 1.5 mm. on which I soldered the steel wire provided by the kit, all painted in matt white. The uprights are glued only on the lower side to permit removal of the upper part.
Finally, I painted all in white matte spray.
I, then, fix the guardrail bow: as mentioned above, provided by the candlesticks in white metal kits were truly horrendous and fragile, so I replaced them with others of the same size that I already had, in turned brass (when I can, I buy in low price inventory of accessories that can always serve ...); the wire passing from the kit supplied is 0.5 mm spring steel and I did not like because there was no way to straighten it: I replaced it with a 0.5 mm brass wire, straightened by pulling with forceps by a solid bench clamp. Candlesticks and thread were painted before laying, with spray white opaque. The whole was then glued into the holes with cyanoacrylate (superglue).
Other picts...
Lighting...
We feel after the next post, thanks all you  :)
Realiz
Very nice work going on, Francesca.   I'm curious, at what point will you add the propeller and rudder?   I would think it should have been on before doing all the deck work since you will have to turn it over.
I forgot! After glued the glass in the windows (transparent acetate), I made curtains with opaque engineers paper.
Then, on the upper deck and on the low deck, I added the passengers sitting on benches and standing.
post-20714-0-37448700-1459545169_thumb.jpgpost-20714-0-49273900-1459545229_thumb.jpgpost-20714-0-37422200-1459545267_thumb.jpgpost-20714-0-28701500-1459545309_thumb.jpgpost-20714-0-71734900-1459545343_thumb.jpg
The rudder control mechanism (not working), the rudder will be operating below deck.
Soon I will tell you something about the lighting with leds builded  to have no cables and connectors between the hull and the removable upper deck.
Bye
Francesca
Your detailing is great.  I really like the rudder chain drive.
Bob
  • 1 year later...
  • 3 years later...
Bongiorno.
My Italian is terrible, so I writers in English. I have also bought this set and startet to built it.
There is some errors in the set, but You made a terrific job.
I once bad a trip on this Wessel and IT vas a fine experience.
I Was a bit dissappointet for some of the errors in the set, so I starter on the set, but noW I´M back in the building buissniss.
It could be Nice to SEE some more pictures of YouTube Boat an hear how IT worked.
Take care.
Jon
