So we can go on, next photos are sorted out.
After building the stove i started with the cookhouse. I used 6 x 2 mm oakwood stripes, and glued them as walls together, the floor was made from the same material.
The door- and windows frames were made for darker wood, that I had in stock from a former project.
Then the stove took place for a short test, space enough for the cook to walk around!
After that test I layed the clinker floor and wall into the house, what was a mistake at that time. The clinker photos I used was downloaded from Google search for "clinker floor", and resized to the correct measure.
As W. E.Falck told me in another forum, the walls were chalked white, so I had to remove everything, an painted the walls with white matt colour.
Even two lights were made, this will be shown in a next post.........
Best regards
Gerhard
Problems just mean: solutions not yet found
Models in progress
SMS DANZIG
http://modelshipworld.com/index.php/topic/12842-sms-danzig-1851-by-gerhardvienna-radio-150-scale/
USS CAIRO
http://modelshipworld.com/index.php/topic/13282-uss-cairo-by-gerhardvienna-live-steam-radio/
Baby Bootlegger 1/10
http://modelshipworld.com/index.php/topic/13625-baby-bootlegger-110-radio-by-gerhardvienna/
Swiss paddlesteamer RIGI 1848 1:50, after plans from the Verkehrshaus Zürich, rescaled to original length
Anchor tugboat BISON, 1:50, plans from VTH, scratch
Finished models
See-Ewer ELBE, Constructo kit 1:48
German fastboat after plans from german Reichskriegsmarine measure unknown (too ugly to show up!)
German traffic boat for battleships WW2, 1:50, after plans from Jürgen Eichardt, scratch
German Schnellboot TIGER P6141 VTH plans, scratch
Nice work Gerhard, I like the pots and cans
Hi Paul
Sorry for that late response, The cans were simply turned freehanded at the lathe, the pots have been remains from 12 mm balsa wood. With a bit of color and a few copper wire they are now converted into their final destiny :D
There is NO waste in the shop, even the smallest piece of wood or metal can be used for just something.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi again!
First as ever, many thanks for your kind Likes :)!
As you can see in the former post, there`s light in the cookhouse.
First I soldered emailled wire to 2 SMD-Led`s, the Led`s are only around 2 x 1 mm small.
As a next step I used 4 pieces of 0,5 mm brass rod, cut them to length with circa 5mm overlength, stuck them into a piece of balsa wood, and placed a short piece of 4 x 3 mm brass tube in the middle. All was soldered together, and then the overlength filed away.
On the bottom side I stuck a piece of 3 x 2 mm plastic tube into the brass, this works as an isolation for the wires.
A first test, there`s a light (over at the frankenstein place..............)
The glass cylinders are simple tubes of acrylic glass tubes. They came from medical inhalers, wich I need for the cure of COPD.
In the end I soldered end caps of 0,1 mm brass sheet to the lamps, grinded all to shape, and glued the lamps to corner stands. As glue I used glueing silicone, this takes a bit more time for drying, but fixes the lamps best to their stands.
One of the lamps mounted into the house
The lamps need some power, as we know, so I decided to build a battery box beneath the cookhouse. This box took me more than only one attempt, until I had it finished.
This was the first version
Some working hinges were to make, the box can be opened for change of batterys
The final version of the box.
This wall-mounted lever keeps the box closed
This lever on the box works as a switch, left position turns lights on.
The cookhouse with its roof. The roof was made from the same materials as the walls.
Regards, hope you enjoy that.........
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi again & Thank you all for watching
Next to do was the chimney. I used 6 x 4 mm brass tube, a bit of brass wire and 0,1mm brass sheet for the oart of the cookhouse. First to do was tö make a rest for the chimney at the stove, this was produced with a short piece of 4 mm round wood. Then I drilled a 6 mm hole into the roof, the wooden piece was glued to the stove with that "Ramsauer" sealing glue to the stove.
As next I soldered abrass ring to the top of the tube, SORRY, no photo taken from that step! After soldering the end ring I formed the cap from 0,1 mm brass sheet. I layed baking paper between the cap and the tube, so the cap kept moveable.
For soldering I gave a large amount of flux to the cap, and soldered the cap with even a large amount of soldering wire. The photo shows the work after a first soldering.
As last step on the top of the chimney I soldered another brass ring to the tube, here was also baking paper in use.
Next thing to do was the sealing cone to the roof. I marked a ca. 16mm circle to the 0,1 mm brass sheet, marke a sector as a cutout, drilled a center hole, and soldered it to a cone.
Then the cone was stuck on the tube and soldered, while the chimney was set to the roof and stove. Mark the large amount of solder flux and the ring of soldering wire aruond the tube. Evev here was baking paper used, this time to keep the roof clean.
The soldered cone and the finished chimney.
There is still more to come......................
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Gerhard slow down I cant keep up, don't you have to go to work?? nice work on the chimney though kitchens looking good, get some tung oil on that oak roof and it will look awesome!!!!
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Hi Paul
As i wrote at the beginning of this report, that`s all just a review. It took me about 6 Months or so, to get all that things done.
As I`m a lucky retired guy, I dont have to go to work  a045.gif , but at the time I`m renovating my home, so I can show only the things done until now. As W.E. Falck (he is also here in the forum) gave me as a hint, the houses of prussian warships of that period were painted white, so the cookhouse will be coloured that way. But painting the outside walls and roof will be done, when the hull is built, to keep the coluor in the same condition. The hull will be outsides painted black down to waterline, and coppered below. Will be a lot of work, to place all that copper plates on a 1,5 meters long hull! The inside paint and deck will be made as the original model from the London museum of science did show. I have permission to show that photos from the museum, but only the "low resolution" pics they show at their homepage, here is the link to the model http://www.scienceandsociety.co.uk/results.asp?search=1&screenwidth=1270&pixperpage=50&searchtxtkeys=Dantzig&lastsearchtxtkeys=&withinresults=&searchphotographer=&wwwflag=&lstformats=&lstorients=All+Orientations&captions=
I will continue later with a bit more from the cookhouse, so far
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hello to all interested, here we go again :)
The next thing I made for the cookhouse was the door. I took some old wood of 6 x 1,5 mm that i had in stock, carved about 1 quarter out from one side, and glued then a frame from that material.
This frame was then filled with  1 x 2 mm stripes from balsa wood, then i grinded the door down to ca. 1,5mm. The balsa stripes are now just 0,5 mm thick.
Then I soldered hinges for the door, they are made from 1 x 0,5 mm brass tube and 0,1 mm brass stripes
The hinges were glued to both door and frame, I used superglue for that, and the door was strengthened with wooden stripes
Every door needs a clasp, soldering that was not really easy. A I always do, I used a bit of baking paper when I soldered the whole thing at the door.
The outer door handle was transormed into a knob
The door can also be held open by a hook.
Two yokes were made to the roof, they will keepthe house in position, when it is fitted to the deck
Best regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Almost done with the cookhouse, there is one last part from that for the moment.
The cook will need some food in store, so I decided to make some barrels, the first one is finished.
All parts cut from 1 mm plywood
Framework glued
First stave mounted & goes on..........
Barrel closed, the stripes on top are just carved grooves
"Iron" rings made from black carton
That was all about the cookhouse so far, next time will be a bit more of brass works,
Thank you all for watching & your nice likes!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi to All  and back again with the last parts of the review.
The last things i made for the DANZIG until now were the davits for the wheelhouse mounted boats. I used thedrawings '233 from the "Atlas du Genie Maritime" for that, parts Nr 4, brought them to correct scale, and made 8 printouts for the 4 pairs of davits.
The copys were glued to  a sheet from 0,5 mm thick brass, and cut out.
Between the 0,5 mm parts were 2 x 2mm brass bars placed for soldering
First pair of davits after the first soldering
The next step wasmuch more difficult, soldering the rounded parts. I used stripes from 0,5 mm brass sheet, bended them to shape, and layed the stripes between the rounded upper ends. This section was supported by a piece of 3 mm plywood, also the eye in the middle was filled with plywood. Here will a roll be built in, even at the top, so this parts must be kept clean from any solder.
The soldered davits were cleaned from soldering dirt with a rotating brass brush
Both pairs done,
So this was the last part of my short review to the SMS DANZIG, from  now on we are in present times...........
I hope you will enjoy it, I`ll be back :D, with the next parts for the davits and hopefully a lot more!
Best regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Just ... just ... just ... fantastic!
Can I join to learn?
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Hi Nenad
Absoluteley, you`re welcome! As everyone who wants to visit this report! Thank you for your kind comment, I am always searching for new methods to do several things better, next steps will take a bit more time, with a lot more of soldering work. As this is from now on a realtime report, things will go more slowly.
But now a short "in the report" report, what I have done the last days, what stopped me from working on the model. I have decided, that my SMS Danzig will need a new showcase, the old one was not large enough. So I built a large case for my different tools and materials, and a display case above, the lower case is 78 cm high, 2 meters long and 60 cm wide, the display case above has the same measure with 1,50 meters high.
The lower case from left side
The display case "as built"
The same, with a background photo set in , this was done with open office, just to have an impression how it would look like then.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi Gerhard,
nice detail work, it seems you are not anxious to do a large variety of soldering parts together. Do you preferably use a das torch or the electric soldering iron ?
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils
I`m just using a normal 30 watts electric solderin iron, bought at Zgonc here in Vienna, for about 19 Euros  :D. For the Steam engine  and boilers I will have to learn hard soldering with propane gas and  oxygen, I`ve never done that before. More pics will come maybe in the evening, curios how far I can go today.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi again
Just to keep you informed, I`m not too lazy to do something for the Danzig, I was a bit busy at my home improvement. But between that I could study how to make the next davits, an tried to figure out how the soldering form to make. It`s on the way now, photos will come tomorrow, when the parts are made.
Best regards
Gerhard
Edited by Gerhardvienna
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Here we go again, but first of all many thanks for your interest, and for your kind likes!
At the time I`m working on the davits, this time the davits for the small boat. I use plans from the "Atlas du Genie Maritime" again, this time plan no. 244. The left one is used for the small boats davits, the right side drawing will be used for the larger boats.
As usual, I made some copies from the scaled plans, cut the shape out with a bit oversize, glued them to 0,5 mm brass sheet, an cut 8 pieces from that
First 3 pieces, the basic shape is same, the differents are intentional.
Then a soldering form had to be made, the form is screwed, it will be used later with some changes for the following steps, when once the basic davits are soldered.
All cut pieces and the soldering form
The form filled with the first 4 pieces, the davits are to be made mirrorsame! Mark the two cutouts at the center pieces, a roll will be installed there!
Next steps will be the soldering of the davits, the changes at the soldering form, and the final steps to the finished davits.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
The small davits, Part 2
The brass parts are ready for soldering, the plywood piece is used as a spacer to keep the axle holes and the space for the rollers clean.
First soldering done
Then the form was milled out for the next stp of soldering. 2 more clamps will be soldered here, this is for the outside rollers
Even at this step are wooden spacers needed, the needle holds them in place
The upper ends of the davits are ready, just the rollers missing.
Next to do are the lower ends for mounting the davits to the ship, this will be done tomorrow.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi Paul
Thank you! It took me a lot of time, to get where I am now, here is another example of what can be soldered, the screws of my tugboat Bison, this is another recent build on my wharf.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hello again
Here comes the next part of making the small davits.
After the top ends of the davits were done, I had to make another change at the soldering form. the mid part was cut down, and the outer parts were carved for a 0,5mm "seat" for a small brass ring.
The davits soldered with the lower bolts, just the rollers missing.
Best regards & thank you for your kind likes
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
The next steps are done, this time the for lower levers to the Wheelhouse davits.
As first I had to make a soldering form, and to produce some parts for the levers. They are between 3 an 45 mm in scale, all made from brass 0,1 mm sheet to 1 x 2 mm, each lever is to be made from 11 single parts.
The pieces for one lever
First parts in the form
One complete lever in the form
Next to do is to mill the form a bit lower, and set two spacers at the space for the rollers, and then solder all levers. This will happen tomorrow, hope it will work as I thought.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Two days of preparation have paid out, the four levers are ready done. I`ve milled the form 2 mm lower, so soldering was much easier to do.
The milled form with the first lever before soldering
The first lever done
All four levers, the rollers and mounting parts are still missing, they will be made the next (few?) days.
Regards, thank you all for watching, and comments!
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi Ken and Bob :cheers:
Thank you for your nice comments, I`m trying to do my best :) .
But I see myself still as a learning individual, discovering almost every day  something new.
This days I spent with thinking about, how to make the mounting angles for the levers, the soldering form is done, the raw parts also, tomorrow I will soder the parts together.
The raw stripes, paperforms glued on.
The bended angles, holes are made
One angle in the soldering form, before soldering, the eylets missing.
The eylets are cut and grinded to shape, more photos will come next time!
Thank you for watching, and your nice likes!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi again, and many thanks for your kind comments & likes!
As I started yesterday with the mounting angles I continued today. Some of you may wonder, why the parts look like forged, but they are not. This depends on the way i make the holes in such parts.
Mark the holes with a larger spike, then grind the "nipple" away
Bend the part back to straight, then repeat with a thinner spike
All eyelets are done, and the completed Angles. They were soldered in the form shown earlier.
The completed levers with mounting anlges, the levers are moveable!
Best regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Very impressive miniature metalwork, Gerhard!
Hi druxey
Thank you, and thanks to all who like that kinda work!
There are still more of such small things to come, all that little fasteners still missing. Next to do will be the clamps for the davits, started ysterday with them.
More will come later, today I start with the second part of my home improvement too, so there is just litttle time for the modelworks :o
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
I just found your build log.  I like how you make every part work as it should.  Then you teach us how we can do the same thing.  Keep up the fine job.
Bob
Current build:  SS_ Mariefred
