Hi l am looking for advice I am planking the deck of my Syran model and it is bent !
Do I follow the bend with the planks or do I start with a straight line from the center of the bow to the center of the stern
I am thinking of going for the latter
It is approximately one planks width out in the center
Thanks Andy
Hello, could you show some pictures?
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Hi Andy
What stage are you at with hull. If its finished I can understand why you would want to accept the bow and try to make the best of it when planking the deck. The best solution is always to try to remove the bow. If you don't want to do this then working from a straight centre line is probably going to be easier than trying to follow the bend.
Keith
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Andy,
Looks like you don't have many options there.
I agree with your original thoughts. Don't look at the bulkheads, just lay your center plans between the center of stem and center of transom. You're deck will be wider to one side, but only slightly. It won't be noticeable unless you're looking really closely. Only problem I can see is that you're masts will be slightly off center too. Shrouds on one side will be slightly longer than on the other. But, looks like you're only talking about 1/8", so you should be fine.
The photo of your model from the side looks great, by the way.
Clare
Clare Hess
He's a -> "HE"
Hi Andy.
I gotta go with Clare's advice.
Will only be noticeable when viewed fron the Bows or Stern of the ship.
Did you have a build log ?
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Thanks Antony and Clare for your advise the only thought I had was that the deck would look odd if where the planks were nibbed intp the margin plank they would be out of sync port/starboard
but i think that would be less noticable when covered by the guns etc than the centre furniture not looking correct
Sorry Antony I havn't done a build log I have some photo's so maybe I should
Thanks
Andy
Lay out line down the center of the deck from bow to stern. Then start your planking in the center of the deck working out to the sides. Never start your planking form the bulwarks or sides and go towards the center. Sorry, but looking at the pictures, I ain't seeing no bend or warp.
mike
Hi Andy,
We all had to start somewhere mate, for every problem you have and fix is experience gained.
There is a great deal of satisfaction when a problem is corrected and it doesn't matter if help was sought, you still have to make the repair / fix.
I think in this situation I would follow Spyglass's suggestion and cheat, you just need to work out the width's of the planks either side of the centre line. You know how many planks should go in so you will be able to make the adjustments.
Good luck with the fix and you really do need to open a build log.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hi thanks for all your advice
the deck is now planked and I don't think it looks too bad
as expected it isn't even port/starboard but by the time all the deck furniture and  guns are fitted I don't think anyone will notice (apart from ME !)
Andy
Nicely done - you wouldn't notice unless told.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
