Cannons fitted out with all eyelets, rings and chains. Also i changed the kit supplied rope for some decent rope :)  They still need to be cut to correct length once i decide where the cannons will be positioned :)
Placed cannons on deck just for the sake of it to see how they look :P
Masking tape on the deck planks is there so i don't mess up the planks when i can be bothered to sand the inner gun port liners, I hate sanding :o
Bob,
"I hate sanding", guess I am not alone in this matter. :D
But your canon display is coming together nicely, I like it!
Edited by Nirvana
Respectfully
Excellent looking canons Bob! Those are going to look great in the model.
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Looks good! Nice replacement rope! You and dr. Per hate sanding? I think I'll join the club :D.
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Bob this is really nice work. I'm going to have to take lessons from you on cannons, yours are really sweet.
Ian
Thanks Ian :)
And also thanks to all those who have liked and remarked on my build so far  :)
Cannon building method is just like the rest of the build. Assume everything in the instructions is wrong, take all the parts and dry fit everything and adjust until you are happy :)
Plus the large scale makes everything much easier. Following pic gives you an idea how big they are
Thanks to you too Elijah
Always room for more members of the anti sanding club :D
Pic to demo cannon size
Edited by Cobr@
Time to do the gun port lids. The ones the kit says to make look way oversized to me far to thick. This is just my opinion, others may like the way they look :)
Kit lids
I decided to make mine 3mm thick. I cut out a 1.5mm x 30mm x120mm strip of ply
Then cut it in half and glued the two halves together to make a 3mm x 30mm x 60mm strip
Then i cut out 2 30mm x 30mm squares and once sanded they fit in the gun ports nicely
Just need to decide what colour to do them. I want to do black but that may hide the hinges as they are blackened brass but hopefully it won't matter
Bob,
Why not do a test with black and black hinges, (not attaching them) to see how it looks like. :)
Respectfully
Looking good! That cannon is BIG!
-Elijah
Current build(s):
Completed build(s):
Member of:
Thanks Elijah :)  it's heavy too :D
Gun port lids made and fitted, went with the black on black as the hinges are still visible against the black lid. Just a bit of touching up were the black has been chipped off the brass parts then i will do the rigging for them. They will not be moveable as i glued them in place because i don't want any moving parts once finished
Nice hinges!
-Elijah
Current build(s):
Completed build(s):
Member of:
Just a quick update because i have not posted for a while.
My son saw what i was building and asked me to do one for the grandson, so i got another kit and i am going to build them both side by side but i will only post updates of one of them (the best one haha :D :D ). So for a few days i am building the second one up to the same place as i am at with the first one, once i catch up i will start posting more of the progress. :)
Edited by Cobr@
Thanks for the likes and all input so far, much appreciated :)
Quick update
I have almost caught up with the other one, just need to finish off the gun port covers and rig them then i will be ready to continue on with both of them together.
You may notice that i have gone for a brown framework on this one, this is because i did not like the look of the first one in white. One coat of walnut wood dye gave it a mottled aged look which i liked so i left it at one coat :)
Very nice Bob. I too like the Walnut look better than the white wood. Very nice and clean again. Looking forward to seeing you move forward with not just one but two fantastic builds.
-E.J.
You are doing great, you and your grandson should be very happy when done
Nice job! What's it like to work on two of the same build simultaneously?
-Elijah
Current build(s):
Completed build(s):
Member of:
Hi Paul Thanks :)
I have already test fitted the cannons in place before i fitted the tables and benches, and as long as i fit the hull end block and hook first then place the cannon and then fit the cannon block, all of it fits fine.
Thanks for being helpful ;)
